General Forestry => Ask The Forester => Topic started by: whitepine on December 28, 2005, 12:50:28 AM
Title: cuttings from pines for transplant????
Post by: whitepine on December 28, 2005, 12:50:28 AM
Doing a google search about tree growing ran across an article for a grow unit and they claimed to grow transplants from douglas fir ( Not familiar with it but  I thought thats a type of pine?) from cuttings? Can one take a cutting from any tree and get it to grow roots? I was under the impression just a few trees are capable of this but  dont know.  What about pines , cedars? I figure most hardwoods would : straiten me out here Thanks Tom
Title: Re: cuttings from pines for transplant????
Post by: Ianab on December 28, 2005, 01:23:47 AM
Most trees can be grown from cuttings, just some are a lot easier than others.
With willow or poplar you can just poke a stick in the ground and it will grow, others need to be treated with rooting hormone and grown in a glasshouse environment untill they get established.
Radiata pine is grown from cuttings on a commercial basis here in NZ. The idea is that the nursery will plant out their best seed grown seedlings and observe how they grow for a few years, looking at the form and growth rates. They will then take the cuttings from the best of the trees and sell those for commercial planting. All your seedlings should be genetically good stock. Another bonus is that the seedling grows in an 'adult' form instead of the normal seedling. This produces a better tree 'form' than conventional seedlings, smaller branching and bigger spacing between branches.
Cheers
Post by: whitepine on December 28, 2005, 08:11:36 PM
Thanks the article I read also mentioned the cuttings were better than normal seedlings I still dont see why except maybe because of size and one could pick superior stock. Thanks again Tom
Post by: Minnesota_boy on December 28, 2005, 08:57:41 PM
When you take a cutting, you are creating a clone.  You know how they should turn out.  Seedlings are a crossbreed.  Some may be inferior, some the same, some superior.  You find out in 20 to 50 to 100 years.
Post by: Ianab on December 28, 2005, 10:01:12 PM
Having consistent 'clones' of a known good tree is one advantage, the other is the seedling is already 'aged'.
http://www.trc.govt.nz/PDFS/info_land/06_radiata_pine2.pdf
QuotePhysiologically aged cuttings are often considered anadvantage to seedlings. Aged cuttings are collected from tree stands or nursery beds and are propagated from older material (1-5 years old). They develop roots in the nurseryand superficially resemble seedlings. The cutting then appears to recognise a "biological clock" so that a cutting from a 3 year-old tree knows that it is 3 years old and grows differently from a seedling. Advantages are smaller branching, less forking, straighter stems, they are sturdier, less likely to have distorted roots at planting, and are expected to have less taper and bark thickness
Cheers
Post by: whitepine on December 28, 2005, 10:44:46 PM
Great explanation I get it now Thanks Tom
Post by: jon12345 on December 28, 2005, 11:00:55 PM
cloning baaad  (sometimes) - what if u clone a tree with weak immunity?   :o
Post by: Ianab on December 28, 2005, 11:59:53 PM
Quotewhat if u clone a tree with weak immunity?
Yeah... that would be a baaad thing.
I guess the idea is that by looking at the original seed grown trees after 5 years growth you can pick out the ones with genetic defects (poor form or susceptable to fungus etc.) So your cloned cutting trees should be better than the normal random selection from seed.
Just dont clone the dud ones ..
Post by: SwampDonkey on December 30, 2005, 07:32:52 PM
Most seed orchards here that produce spruce seed where established from rooted cuttings (clones) from material taken high in the crown of mature trees, or seed from selected 'plus' trees. The slip is rooted in pots then out planted to establish an orchard. These orchards were established with trees containing desireable traits. The seed orchard is monitored in 5 year intervals and usually contains families of the same species taken from different geographical locations.  But some of our seed are taken from wild 'plus' trees in heavy seed years to ensure high genetic and physiological quality and from individual trees or a number of trees in order to have a representative genetic sample of the population. Our provincial nursery produces 20 million seedlings annually in 30 green houses. It's the largest in the maritimes and all seedlings are used to reforest crown lands that are insufficiently stocked (<20 %).
Even though alot of effort is put into improving seed, I still find the odd tree in plantations that behave rather oddly in their growth habits, but that could also be environmental (insects, disease etc). ;D
Kingsclear Forest Tree Nursery and Seed Centre  (http://www.gnb.ca/0079/pdf/Kingsclear_Forest_Tree_Nursery-e.pdf)
Post by: whitepine on December 30, 2005, 07:38:17 PM
That explains where they are getting their seedlings from the nursery I get from was  elusive about their source. Would you happen to know the brand name or the chemical they use to stimulate root growth. Thanks Tom
Post by: SwampDonkey on December 30, 2005, 08:06:45 PM
Quote from: whitepine on December 30, 2005, 07:38:17 PM
I once asked what they used for root grafting balsam fir and they said one ingredient was bees wax, but said the formulation was a guarded secret. But, root grafting is something else. Two compounds mentioned in the article below are: Naphthaleneacetic acid (NAA) and indolebutyric acid (IBA), which are the compounds most commonly used to promote rooting of cuttings. And two commonly sold preparations are Rootone and Hormodin.
Veg Propogation of cuttings  (http://cru.cahe.wsu.edu/CEPublications/pnw0152/pnw0152.html)
Post by: jon12345 on December 30, 2005, 09:22:11 PM
I think I just found a new project  ;D Now I won't have to find seeds for all the trees I wanna plant.
Post by: SwampDonkey on December 31, 2005, 07:25:20 AM
Those are the one's to avoid. They either don't know or their source is usually from a latitude further south that will have a negative impact on thier development and growth further north. Any forest tree nurseries I've delt with always give me thier source, but some of the smaller private ones can be a little evasive. They want you to keep replacing the ones that don't make it I guess.
Post by: Don P on December 31, 2005, 09:51:29 AM
I'm misunderstanding something I think. If you take a cutting from new wood on a mature tree, it is in my thinking still juvenile wood. Does that cutting switch to producing mature wood sooner than a natural seedling? In other words, at harvest time does the boxed heart timber contain more stable, stronger wood?
Post by: SwampDonkey on December 31, 2005, 11:36:43 AM
Quote from: Don P on December 31, 2005, 09:51:29 AM
Morphologically yes it's juvenile, but physiologically it's mature. It will produce viable seed sooner, but the tree will appear young. Young black spruce for instance will produce seed, but they are not as viable and often times the seed cones are sterile. The main purpose of collecting cuttings is to control the breeding or to insure you get some of the traits you want, even if they are not pure. You can have two of the best trees selected for cuttings, get them growing and they can still produce a small portion of seed that are undesireable. You have no idea which trees were the original parents. Remember Mendel and his garden peas? ;)
Post by: jon12345 on December 31, 2005, 02:43:48 PM
So, if ya took a cutting and turned it into a bonsai, would it make tiny seeds? :D
Post by: whitepine on January 01, 2006, 08:13:34 PM
You all are sure helpfull. I am considering trying something with northern white cedar (and red if I could get some cuttings as they are not native to here just a bit south) the nursery I get them from is out this year. I also  have a friend who said I could have all his trimming from his small hybrid poplar farm so will soon have something to try this year.
Post by: Shamus on September 13, 2007, 09:25:58 AM
Just curious if you tried growing cedar from cuttings and how it went? I also have trouble getting cedar seedlings out here (only need 1,000 at a time), and have been thinking about propagating cedars from cuttings taken near the tops of 4' tall trees, and using rooting hormone. I am going to do some experimenting with it in late October. No greenhouse, just planted in 5 gallon pots outdoors...
Post by: SwampDonkey on September 13, 2007, 06:47:52 PM
Can't get them from DNR or a forestry company that plants trees on their crown forest license?
Post by: semologger on October 21, 2007, 10:43:08 PM
i am good about asking what the. on this forum here is another what exactly is a cutting? i need to change my name to cantfigureout.
Post by: Tom on October 21, 2007, 11:12:12 PM
Cutting has taken on a new meaning lately with children and some adults, slicing themselves up with razor blades and knives to satisfy some psychological problems.
Plant cuttings are what most of us are familiar with.  It's a leaf, twig or small limb removed from a plant and nurtured, either in the ground or some rooting medium, until it develops roots and can be planted with the chances being good that it will be self-sustainable.
Usually we think of cuttings being taken from flowers, like Roses.   It is a means of vegetatively propagating a plant to produce fruit or flowers true to the original plant.
Conifers don't generally propagate like this very well.  It even takes a very technical individual and a lot of luck to propagate conifers through grafting.  Most cuttings of pines that I'm familiar with usually end up being called fence posts.
Post by: SwampDonkey on October 22, 2007, 05:29:16 AM
Black spruce layers naturally in the wild and has been rooted from cuttings by the ...well too many to count.  ;D
Northern white cedar (eastern white cedar) also layers if a tree gets wind blown or a limb, in an area devoid of deer, touches the soil for some time. I have not seen many layered cedar. I have seen a lot of layers spruce especially on dry sandy sites that were devastated by fires and covered in caribou moss. You get the mother tree in the middle and a ring of small trees growing around it. I have also seen white spruce grafted as well as balsam fir. Most all the white spruce grafts I've seen turn into a limb crawling across the ground. This habit seems to depend on the location in the crown the cutting was taken. I had an albino white spruce that was from a rooted cutting. It would flush almost white and gradually turn green over the growing season. The lawn mower and it had a battle and the mower won.  ;D
Post by: tonich on October 22, 2007, 08:36:10 AM
Norway Spruce layerings is the only possible way of regeneration at the upper forest line in my region.
(https://forestryforum.com/gallery/albums/userpics/14451/DVD_0.18.02.24%20%28Track%2001%29.jpg)
(https://forestryforum.com/gallery/albums/userpics/14451/DVD_0.18.24.23%20%28Track%2001%29.jpg)
(https://forestryforum.com/gallery/albums/userpics/14451/DVD_0.18.42.17%20%28Track%2001%29.jpg)
(https://forestryforum.com/gallery/albums/userpics/14451/DVD_0.19.19.06%20%28Track%2001%29.jpg)
(https://forestryforum.com/gallery/albums/userpics/14451/DVD_0.17.34.04%20%28Track%2001%29.jpg)
This is all layerings, my dear!  ;)
