General Forestry => General Board => Topic started by: Corley5 on September 05, 2006, 12:10:45 AM
Title: Deutz Air Cooled Diesels
Post by: Corley5 on September 05, 2006, 12:10:45 AM
I've never had any experience with these engines.  How are they for performance and longevity ???  We're kinda interested in a C4 Tree Farmer forwarder that has one.  So much for the skid steer.  Gonna go big ;) ;D
Title: Re: Deutz Air Cooled Diesels
Post by: UNCLEBUCK on September 05, 2006, 01:53:32 AM
I owned one of those manlifts made by JLG ,it had 4 wheel drive and a 45 foot boom and it had one of these motors and it ran flawless . One of the highlighted selling points many people asked me when I sold it was everyone that looked at it was very pleased it had the duetz diesel air cooled .  It would start anytime and ran perfect .
Thats all I know about them as I never had one problem with it .
Post by: ScottAR on September 05, 2006, 02:29:48 AM
One of my favorite customers runs a diesel shop.
They mostly do irrigation/generator engines and the Duetz
is one of his favorites.  He tells me with regular oil changes
and cleaning of the oil coolers/grills they'll run nearly forever.
Post by: amberwood on September 05, 2006, 02:36:23 AM
same news here..every report I have is that with good oil they will run forever.  Just a little noisy.
DTR
Post by: TW on September 05, 2006, 02:41:50 AM
One of my previous employers has a Deutz D25 or D30 tractor. He says that it is almost impossible to start in the winter. Otherwise it is good.
Post by: mometal77 on September 05, 2006, 03:10:09 AM
I have heard from people in the trade i am in they are some of the best motor in the market.  If put on a welder even better.  Very easy too work on.  A neat vehicle i once say with a six in them was a samil 20 look it up.  I would love too have one.
Post by: gary on September 05, 2006, 04:43:21 AM
I have one on my mill and it runs great. It is almost 10 years old.
Post by: Max sawdust on September 05, 2006, 08:59:14 AM
My father has had a 80HP Deutz farm tractor for 20+ years.  Virtually no problems.
Max
So personal experience says they are good.
Post by: sawguy21 on September 05, 2006, 10:46:27 AM
I remember them in Pacific trucks, they were good engines but noisy on startup on a cold morning.
Post by: isawlogs on September 05, 2006, 11:32:44 AM
 We have one on the farm , my brother  Norm bought it , has a 100 hp and it never ever had anything done to the motor , oil changed and filter change is all it ever needs . If it is plugged in (oil pan heater ) it will start easy in the coldest of winter .
I have a few pics of it in my galery , I used it to help around the mill while sawing some logs for the house .
I sure would not hesitate to get one .  smiley_thumbsup
Post by: Coon on September 05, 2006, 05:29:11 PM
I have got a Deutz D50 here.  Use it all of the time.  Plenty of power and generally will not burn more than a gallon of fuel per hour.  I have to pull start the tractor all of the time because of wiring problems.  With one little tug it is going no matter how long it has sat for.  This summer while haying I averaged 1/2 gallon of fuel per hour while making square bales with an old JD 24T.
;D Brad  :o
Post by: Aroostooksawyer on September 05, 2006, 06:24:53 PM
Have one in a Rayco dozer.Lots of power, 1200 hours and no problems. A dream to drive.
Post by: Reddog on September 05, 2006, 06:41:15 PM
The only thing I see to add is just like a Detroit, Do Not Lug it. They need lots of air to keep them cool. Like others have said a little hard to start in the winter with out plugging in.
Post by: VA-Sawyer on September 05, 2006, 10:31:38 PM
Interesting that you should ask... one of my tree guys just blew up his Deutz 40 HP engine on his chipper. I have been doing most of the maintenance on his equipment for a little over 6 months. I did some work on his chipper about a week before it did itself in. You can look on one side of the engine and see daylight out the other.  I spent a few hours looking everything over, trying to figure what went wrong.  Best I can figure... the V-belt that drives the fan and altenator started slipping to the point that the engine overheated and ended up throwing a rod. I have no idea why the low oil pressure/ high oil temp shutdown system failed to shut it down before  the engine blew up.  I had told the owner twice twice before when I worked on it, that it needed a new belt and he needed to order one for it.  Guess I should have just pressed my case harder.
I was very shocked when he told me it had trashed itself because it impressed me as being in very good shape. Good oil pressure, and very little metal in the oil filter. ( one of the cleaner filters I have opened for inspection )  The one quirk I noted was the need to clean the debris from the oil cooler on a very regular basis.
VA-Saywer
Post by: Quartlow on September 07, 2006, 12:19:06 AM
Barring doing something to it they are bullet proof, When i was working in the rental business we had a Genie boom that had 13,000, yes thirteen thousand hours on it and it was still going.
Also had a customer run gasoline in one for 3 days before calling in and complaing about it running rough. Flushed the system and filled it with fuel and it went right back to purring right along.
Since it was a new machine I called the Deutz Factory Service department, the told me not to sweat it.
Post by: moosehunter on September 07, 2006, 07:48:59 AM
 I used to go to truck/tractor pulls quite often. One time at the Syracuse Nationals the Super Stock tractors were on fire and the sled that was supposed to stop (at least slow) them could not stop them.
If you have never seen Super Stock Tractors pull, it goes something like this;
The owner takes off the injection pump and opens up all the passages, does the same with the injectors, then they put 3,4, or 5 turbo chargers on the engine :o
Awsome sight! 50 foot black smoke pillar when they rev them up, then they inject water into the intake and the smoke turns white, then when the smoke starts to clear up they start pulling.
But back to the Deutz.
Usually these tractors pull 2-3 times in a show. These guys went 5 rounds. 2 droped out because of over-heating problems. One GREEN tractor made alot of bad noises and then lost all of its oil on the ground. In the end an AIR COOLED Deutz won the show.
That was impresive.
mh
Post by: Coon on September 07, 2006, 01:08:29 PM
I just talked to the previous owner of the Deutz D50 tractor that I own.  His father bought it brand new from the dealership.  The tractor has in the general neighbourhood of 15-16,000 hours on it and still going strong.  Leaks some oil but still doesn't seem to burn any.
Brad.
Post by: Corley5 on September 07, 2006, 04:18:41 PM
Thanks for all the replys 8)  I assume these engines use glow plugs ???
Post by: Reddog on September 07, 2006, 05:37:05 PM
Alot of the older ones had nothing. That was why they start hard in the cold.
Post by: Corley5 on September 07, 2006, 05:57:14 PM
This one is in an 80s model Tree Farmer C4D forwarder located in Da U.P. so I would imagine it's got them ;D :)  Dad is going to check it Saturday 8)
Post by: Reddog on September 07, 2006, 09:59:13 PM
Well if it doesn't have plugs.  It will most likly have some sort of preheater. Some used a propane fired heater under the engine. Others a oil fired. Everyonce and a while they would turn into Skidder fires, if you had nice oil leak. :D
Post by: Frickman on September 10, 2006, 08:48:00 PM
I got a Deutz five cylinder in my Tree Farmer forwarder. It is a very, very good engine, better than I expected it to be. I bought it in southern Alabama, and it has no glow plugs or preheater. That doesn't stop it from starting in the winter. I've started it down to 15 degrees with just a shot of ether.
Post by: Faron on September 10, 2006, 11:09:00 PM
I like what I am hearing.   8)We have a Duetz three cylinder engine on a generator that was given to us.  We haven't had time to get it running yet.  Sounds like we better get it up and running.
Post by: limbrat on September 11, 2006, 08:09:18 PM
Ran 3 of the 65 hp. on Magnum X riding pavement saws and groovers. They saw a lot of abuse before we were able to match up operators. very strong lite weight and dependable and these were self priming. In 3 yrs we never killed one. In the same time period we wore out 2 milwauke 65 hp gas engines on 3 walk behind saws.
