General Forestry => Chainsaws => Topic started by: parrisw on January 15, 2007, 10:59:27 PM
Title: Husky L65 help please
Post by: parrisw on January 15, 2007, 10:59:27 PM
Hey, I am wanting to try to fix my old Husky 65, last time I used it it quit on me, so I took it apart and found that the cam that opens and closes the points was free to spin around the crank.  Now how is it supposed to be held in there, is the woodruff key seperate from it or is it built into the cam itself.  Here are a couple pics of it.  Thanks for looking.
(https://forestryforum.com/gallery/albums/userpics/13521/DSC02251.JPG)
(https://forestryforum.com/gallery/albums/userpics/13521/DSC02252.JPG)
Title: Re: Husky L65 help please
Post by: Kevin on January 16, 2007, 12:09:41 PM
The key is separate.
Post by: parrisw on January 16, 2007, 08:52:32 PM
Ok, thanks.
Post by: Simonian on January 16, 2007, 09:23:46 PM
I checked IPL for the 65 and could not find a key only the cam which not possible to get.
If the flywheel has 2 magnets, you can switch to electronic ignition. If it has 3 you have to stay with the points.
YOU may have to weld or braze a new key to the cam. this is where your craft skill comes in. Like the way cars were built before mass production
Post by: parrisw on January 16, 2007, 10:52:29 PM
Yes, thats what I though, it looked as if the key was part of the cam and it broke off, and yes the local dealer told me its unavailiable, how would I convert to electronic ignition??  What parts would work off of what saw??
Thanks allot
Post by: Simonian on January 16, 2007, 10:54:35 PM
How many magnets are on the flywheel?
Post by: parrisw on January 16, 2007, 11:25:18 PM
There are actually 4 magnets on the flywheel.
Post by: Simonian on January 16, 2007, 11:35:24 PM
I do not think the Nova electronic ignition will work
What metal is the cam made of?
Post by: parrisw on January 16, 2007, 11:41:28 PM
It is made of steel, but unsure of how well, I can weld a key to it, its a tight fit over the crank, and if I weld on a key, the weld build up will interfere with the fit over the crank will it not???
Post by: Simonian on January 16, 2007, 11:47:37 PM
it may be best to silver braze something about the size of the keyway. then grind it to a good fit. This will be more accurate than a weld
Post by: parrisw on January 17, 2007, 12:02:52 AM
Yes, I suppose I could try that, I have regular bronze braze will that work??  or not strong enough.
Post by: parrisw on January 17, 2007, 12:05:44 AM
Im thinking this may be difficulet, I m looking at the piece here, the thing is so small, that once I weld or braze inside this thing, there is no way to grind it out, the only thing I could get in there is a points file or something.
Post by: Simonian on January 17, 2007, 12:08:55 AM
How good does it flow?
silver braze runs like water on a property fluked surface.
there are different flow temps. Easy flow should work about 900f is where it flows. Try a jewelry supply or a lapidary shop
Post by: parrisw on January 17, 2007, 12:32:42 AM
Bronze braze flow really well.  But the dam thing is so small, and the size of the key is tiny, much smaller than I am used to working on, this is like jewlery size stuff, I m used to automotive stuff, welding and fabrication.
Post by: Simonian on January 17, 2007, 12:38:27 AM
will think on it for a bit
You may have to take it to a jewelry repair shop  Give him the key that you find or make and have him braze them together. you still may have to file a bit to get them to fit
Post by: parrisw on January 17, 2007, 12:46:11 AM
Ok, thanks allot for your help thus far, I actually though when it first broke, to just weld the cam to the crank ::)  I know I know, but it would work, and when it dies again, to just scrap the saw.
Post by: Simonian on January 17, 2007, 12:49:40 AM
what would work too. If you can do it very fast.
Post by: parrisw on January 17, 2007, 01:00:05 AM
Yes I could do it, I would use braze since it flows at lower temps then welding, and if I ever had to take it off, I could just reheat and pull it off.
Post by: Corley5 on January 17, 2007, 01:20:58 AM
Watch E-bay for a parts saw.  They show up there on occasion  ;) ;D
Post by: parrisw on January 17, 2007, 01:40:13 AM
ya, I ve been looking there for   some parts.
Post by: Kevin on January 17, 2007, 07:26:39 AM
Is this it?
(https://forestryforum.com/gallery/albums/userpics/10030/L65.jpg)
Post by: parrisw on January 17, 2007, 10:31:16 AM
that looks like it, but the keyway that is shown there is for the flywheel, the small points cam goes on farther in that that keyway.
Post by: Simonian on January 17, 2007, 12:16:26 PM
a braze may take too long. too much heat transfer.
a wire feed welder would be quicker. just need to tack it in 2 spots.
Post by: parrisw on January 17, 2007, 08:55:08 PM
Ya I think your right, I was thinking of that, if it would damage something else, oh well, I got a wire feed welder too, thanks for the help.
Post by: parrisw on January 17, 2007, 09:04:17 PM
Anybody know which way around the cam goes, I can't remember, ther looks like there is an arrow on it, but one side of the lobe has a steeper ramp on it, I would think that would be the backside, so the points would open quicker.
Post by: Simonian on January 17, 2007, 09:28:39 PM
I take it the shaft is not tapered?
Cannot tell for the IPL
Post by: parrisw on January 17, 2007, 10:04:31 PM
No it is not tapered.  And whats IPL?
Post by: Simonian on January 17, 2007, 10:09:59 PM
Illustrated parts list
should have been FROM
Post by: parrisw on January 17, 2007, 11:49:59 PM
where would I find a IPL
Post by: Simonian on January 17, 2007, 11:59:09 PM
try husqvarna.com
Post by: snowshoveler on January 18, 2007, 04:58:20 PM
hello...
i work at a Husqvarna shop and so far i have found the part number is 501 25 24 01
i think thats the number....the parts list for those old saws are hard to read.
tomorrow i will check to see if there are any in the system in eastern canada
its possible that there is some "dead' stock that dosent show up in normal inventory.
Chris
Post by: Simonian on January 18, 2007, 06:23:04 PM
ya that is the number Good luck
Post by: parrisw on January 19, 2007, 12:06:40 AM
snowshoveler
Thanks allot for doing that, that would be very cool if you could do that.
Post by: snowshoveler on January 19, 2007, 11:03:27 AM
the last time it was available here...in stock that is.was 2005.
it listd at 86 and change cdn.
lot of money in my opinion.
it was on just about all the husky saws from that era with point iginition.
im still trying to get in contact with another source of parts but im not holding out much hope for it.
you might try asking on the chainsaw performance  forum.
lot of collector and old saw owners there.
Chris
Post by: parrisw on January 19, 2007, 09:57:13 PM
Ok, thanks for looking around for me, much appreciated.  I may just end up welding it up in the end If I cant get one.
