Other topics for members => General Woodworking => Topic started by: Norm on January 29, 2007, 06:00:11 PM
Title: Shopping for a New Plunge Router
Post by: Norm on January 29, 2007, 06:00:11 PM
I would like to get some advice on what folks use and the brands you like. Also any accessories you feel is important if at all for them.
As with all my tool choices bigger is better, but I've been told no more low-boy deliveries. ;D
Title: Re: Shopping for a New Plunge Router
Post by: metalspinner on January 29, 2007, 06:03:44 PM
How many other router's do you have?  Do you want one for a special purpose?  Do you already have a shaper and need the router for handheld use?
Post by: Larry on January 29, 2007, 06:54:41 PM
One can never have too many routers.  Even my old dogs get used.
For a plunge router I think power is maybe the least important issue.  Stability would be the first issue, than ease of plunging, and dust collection.
(https://forestryforum.com/gallery/albums/userpics/10125/P9280001%7E0.JPG)
This is my last plunge router purchase.  It gets an "F" for stability, "D" for ease of plunging, "F" for switch placement, "D" for dust collection, but on the good side, it gets straight "A+"s for the soft start, speed control, and power.
I've made modifications to improve it but it's like putting lipstick on a pig.  PC replaced it with a new model few years ago.
DeWalt and Bosch both make nice machines...but nothing to get overly excited about.
Seen some good comments about Festools but you never know if those guys are talking loaded up on testosterone.  In any case I'm not committing that kind of money until I can put my mitts around one.
Post by: Paschale on January 29, 2007, 07:04:41 PM
I have a Makita.  I wouldn't buy this particular model again, primarily because of the placement of the switch.  With a plunge router, you've got the router up above the workpiece, situated just where you want it with both hands hanging onto the handles.  Ideally, you'll have an on-off switch located on the handle. One mine, I've got to take one hand off the router, and turn on the router on top of the machine.  Thankfully, it has a soft-start (which I think is important), but it still is awkward and can get a little unwieldy in those first moments.
My two biggies:  get a switch on the handle and make sure it has a soft start to it.
Post by: SwampDonkey on January 29, 2007, 07:26:31 PM
My Makita router has a switch beside the handle. I think it was designed more as a shaper, but it is plunge. I always used it mounted on tables. I've got to get mine fixed yet, as it went before Christmas. But, I have a backup Makita router that has a trigger switch on the handle itself. I did all my dovetailing for my two furniture projects this winter with it. Both those routers are 15 years or more old. I can't think of a single large piece of furniture I built that I never used a router or mt shaper/router. You can get them now with very low noise. Get at least 2 HP one, although my little one has a 1-1/4 HP and has lots of power to burn up dull bits. :D :D
Post by: Don P on January 29, 2007, 08:35:28 PM
I've got the old big boy Porter Cable, it's got better handles and the trigger in the handle compared to Larry's but still is on the unwieldy side. It gets used mostly in a table but does get pressed into handheld work, usually in nested jigs or with a fence. The power is nice if you've got alot to do, I don't have to let it cool very often, where a smaller one on big jobs is hurting. The soft start fried awhile back and I took it out. Needless to say I had a firm hand on it the first time I tried it after that...twern't nothing if you're ready to be turning on a machine. I call it a handheld shaper, I'll replace it with another when the time comes.
Post by: brdmkr on January 29, 2007, 08:57:22 PM
I have the old Hitachi M12V or is it MV12???  Regardless, it is a heck of a router.  However, I only use it in a table.  I like the plunge feature in the table for ease of adjustment as I don't have above-the-table adjustment.  It also has the soft start and plenty of power.  I currently use a fixed-base craftsman for freehand stuff.  I don't like it much, and I am planning on replacing it with either the Hitachi or Bosch fixed/plunge kits (someday).
For what it is worth, I have heard that the new big Hitachi is actually an improvement over my current model, but in my humble opinion...... IT IS UGLY! :D
Post by: scsmith42 on January 29, 2007, 09:43:03 PM
Norm, I've got the bigger Dewalt plunge router.  Like the other brands, it's a bit unwieldy.  If I had it to do over again, I'd probably buy a smaller diameter non-plunging type, mainly because the lower mass should make it easier to handle.
I'll say this though - it does a nice job on aircraft aluminum instrument panels  ;D
Post by: pigman on January 29, 2007, 10:10:48 PM
I have three routers. A small fixed base  small Ryobi that I leave set up for dovetails, a 2.5 hp plunge Porter-Cable similar to Larry's that I use handheld and and a 3.5 hp  plunge Freud FT 2000 in a home built table. The Porter-Cable lacked power in the table. The Freud was cheap, has soft start and has variable speed which is necessary for turning big panel raising bits.  The Porter-Cable works fine for me the way I use it. I bought the Ryobi when I started wood working. It is not much of a router, but works fine for a dedicated dovetail router.
Bob
Post by: solodan on January 29, 2007, 11:29:50 PM
I have a Makita, and there is the switch on top like Paschale stated, but this particular model accepts a variety of bases. it is nice to be able to use the same motor and have different bases for different uses. The switch on the top works good on a router table if you don't have an auxillary switch, and they do sell bases that have a switch in the handle as well, so it could be looked at as a saftey device, cause the motor need to be in the on position in order for the trigger to work. I like it alot, because it is a good router with plenty of power, and it is very versatile as well. I believe porter cable also makes a pretty good one that accepts multiple bases.
Post by: Don P on January 30, 2007, 12:10:24 AM
SCSmith,
If you ever see a DeWalt 690 or an old B&D Industrial 1-1/2 horse, grab it. They are hands down the best balanced smaller routers ever made. They take quite a licking too.
Post by: Ianab on January 30, 2007, 01:23:52 AM
This is my baby  ;D
(https://forestryforum.com/gallery/albums/userpics/10460/ianab_slab_surfacer03.jpg)
Mostly used in the slab surfacer and home made router table. Soft start, variable speed, heaps of power (240v 10amps). I think the US version is tamed down a little (120v 15a?). It's a bit of a beast for handheld use, but perfectly usable. The power switch is on the main body beside the handle and you can flick it with your thumb while keeping both hands on the handles ;)
My other router is a little Bosch, similar to the Colt version you get there. It's really just a fancy plunge trimmer, but it's nice and light and works well for freehanding small roundovers and bevels on stuff. Anything heavy that needs doing I can allways haul out the Makita  ;)
Cheers
Post by: Larry on January 30, 2007, 07:13:01 AM
When earth shaking, stump-pulling, ground ripping, brute horsepower is required, the PC 7518 Speedmatic gets the call. :)  It's the standard by which all other high horsepower routers are compared.  I try to keep it in the router table but it escapes occasionally to take on big jobs. ;D
(https://forestryforum.com/gallery/albums/userpics/10125/P7230024.JPG)
Seen here wearing the router table plate, template bushing, and an extra long HSS end mill it is ready for a routing adventure in the extreme.  This machine will handle any bit available on planet Earth. :)
I would be more than happy to help you shop Norm and we could pick out a whole battery of routers to fit most any occasion. :D  As I wrote in my first post, you can never have too many routers. ;)
Just thought of another thing to look for when buying a router...the PC template bushings are the best made but they don't fit all routers.  It's not a big deal as you can buy or make bases for any router to fit the PC bushings.  I usually make a few extra out of lexan...just in case a router sale comes along. :D
Post by: Norm on January 30, 2007, 07:49:46 AM
Thanks for all the replies folks.  :)
I've got a small fixed base bosch I use for the easy tasks and a shaper for the heavy duty stuff. I wonder if I should also get a big beefy router to put in a table or am I just duplicating the shaper. To be honest the shaper just plain scares me. When you fire that beast up it makes the hair on the back of my neck stand up and certain parts to tighten appreciably.  :D
Larry I'm guessing we'd have a fine time hitting the woodsmith store on a shopping spree although I'd best alert the CC company first. Of course next I'd have to kidnap you to give me lessons on the shaper, too bad you moved even further away.
Thanks again for all the comments on your likes and dislikes, it really helps me out on looking at what's out there.
Post by: SwampDonkey on January 30, 2007, 08:30:57 AM
(https://forestryforum.com/gallery/albums/userpics/11009/SD_routers-001.jpg)
Here's mine too. ;D
Post by: Paschale on January 30, 2007, 08:35:28 AM
Quote from: Norm on January 30, 2007, 07:49:46 AM
:D :D :D :D :D
One way of looking at that...if it does that, then that's the sign of a good tool!   ;D
Post by: pigman on January 30, 2007, 09:45:19 AM
Quote from: Ianab on January 30, 2007, 01:23:52 AM
This is my baby  ;D
Ian, We put our routers in our tables differently on this side of the earth. We put our router under the table top, not on top of it. Thats right, things are upside down in the land of downunder. ;) I suppose the router in the picture could be in the slab surfacer. ;D
Bob
Post by: scsmith42 on January 30, 2007, 10:26:38 AM
Don P - thanks for the tip - I'll keep my eyes open for these.
Norm - if you get to go on that shopping spree with Larry, let me know - it might be worthwhile for me to fly in just for the education  :D  :D  :D  (not to mention being a 'fly on the wall' when Patty sees the CC bill!)
Scott
Post by: Larry on January 30, 2007, 01:26:07 PM
Norm, if you're not going to make raised panels on the router table than something around two hp would be plenty.  You wouldn't like a plunge router in a table...I've seen a few and the guys removed the spring to make them easier to adjust.
Some of the manufactures are making routers especially for tables now that crank up and down.  In addition, the aftermarket people are making some nice gadgets to raise and lower the router.  I don't have hands on experience with any of them so can't pass on a recommendation as to what is best.  They sure do look slick in the magazines though.
Post by: SwampDonkey on January 30, 2007, 01:43:21 PM
My Makita has a threaded shaft, and I was going to say it was used for up and down adjustment. Well not exactly, it's a depth stop adjustment and just below is a set of 3 depth stops which can be rotated and can also be adjusted with set screws. ;D
Post by: brdmkr on January 31, 2007, 10:37:28 AM
Quote from: Larry on January 30, 2007, 01:26:07 PM
That is sort of the idea.  Springs are easy to remove (and reinstall if you ever need them).  Without the springs they are easy to adjust.  I really think my Hitachi is easy to adjust even with the springs.  However, my previous router with a fixed base was a real dog, so that is all I have for comparison.  I really like my Hitachi setup.
Post by: Norm on January 31, 2007, 01:00:49 PM
Well I narrowed it down to this one Hitachi Router (http://www.amazon.com/Hitachi-M12V2-Horsepower-Variable-Collets/dp/B000GKC28W/sr=1-1/qid=1170265815/ref=sr_1_1/102-9485110-1553760?ie=UTF8&s=hi) or this one Makita Router (http://www.amazon.com/Makita-3612C-Variable-Plunge-Router/dp/B0000223JI/sr=1-21/qid=1170266356/ref=sr_1_21/102-9485110-1553760?ie=UTF8&s=hi)
Any opinions good or bad on either?
Post by: Larry on January 31, 2007, 05:06:15 PM
I bought a Hitachi M12 as a present for a family member several years ago.  He thinks it is a great router...and this was the older model before it got customized.  I did a little reading and looks like the spring is removable so you can put it in a table plus it has soft start...something I really like, especially on the these big honkers.  And even my little bitty Bosch Colt has soft start.
It doesn't look like the Makita has soft start...I would rule it out for that reason alone.
Post by: 4woody on January 31, 2007, 05:51:30 PM
Hi Norm thi is Woody i do sideing  an i have bouht two hitachi saws an woud not recomend any one to buy any thing made buy them my makitas woud last tell they got stold an have used them seens 84
Post by: Norm on January 31, 2007, 06:20:10 PM
Hitachi seems to run either hot or cold on some of their tools. I've heard bad reviews on their miters but good on their pneumatic nailer's.
Guess I'll be the test subject on the router...I already bought one. :D
Post by: 4woody on January 31, 2007, 06:45:56 PM
Good luck i hope you dont have any troubles out of it i tried to of the saw an no luck two saw four houses thats not good an they was new
Post by: Kevin on January 31, 2007, 08:16:21 PM
Way to go Norm!
Let me know what it's like, I'm in the mood to buy one myself, been looking at the Freud FT3000VCE 3-1/4 HP Variable Speed Plunge Router .
Post by: Don_Papenburg on January 31, 2007, 09:12:32 PM
Don't go buying them routers just yet Norm.  Take a look at the big yellow router from down under  .  I think it is called a Tridon  or something like that .  I have read several reveiws of it and all were positive .      I would consider the Bosch also I have a buddy that has some of them .  He makes his living with them  doing custom wood work.       I have the old PC 3hp plunge and three 690 fixed base routers plus a palm grip Milwalkee.  I like the palm grip for long routing jobs.   My opinion is that If I were to buy a new plunge router it would be  Bosch or  Tridon
Post by: woodbeard on February 02, 2007, 09:39:42 AM
I have the 3612 Makita, I like it a lot. It does start smooth, and the speed control works well, but the control knob doesnt always stay where I set it. I usually have to tape it in place so it doesn't slow down on me. Also,the plunge lock has slipped on me at times, but this may just be something I need to adjust, hopefully not with tape. ;D Other than that, it plunges well, the switch is easy to use and not positioned where it can be bumped on, and the collet works well.
That Hitachi looks like something out of a cheezy sci-fi show. Hopefully thats not the only upgrade they made to the old clunky models that it seems to have evolved from.
Post by: Tony on February 02, 2007, 07:55:32 PM
Quote from: Don_Papenburg on January 31, 2007, 09:12:32 PM
I think it's Triton??? ??? ::)    Fine Woodworking said it was the best :P
                                          Tony
Post by: Don_Papenburg on February 02, 2007, 10:33:02 PM
Yep thats it ,Triton
Post by: brdmkr on February 02, 2007, 11:01:28 PM
Norm,
I really like my older model Hitachi M12V.  I have not had a lick of trouble out of it.  The only thing I do not like about it is that it will not handle really large bits due to a smaller hole in the base.   For such a big router, I wish the opening were larger.   I think the new model will handle larger bits.  Supposedly this new router is a substantial IMPROVEMENT over mine.  If it is, you will be happy.
I don't know you, and I wouldn't dare want to offend, but the one thing that I think is wrong with the new Hitachi is.... IT IS UGLY  :D  But hey, looks don't route, and beauty is in the eyes of the beholder ;)!
I'm sure you'll be pleased.  Let us know what you think.
Post by: Norm on February 03, 2007, 08:31:21 AM
Thanks for that brdmkr, I did get the hitachi in yesterday. It was frozen hard as a rock so I'll not get to use it until today. The one thing that I didn't like was the looks of it. It kind of reminded me of something Tim Allen would use. :D
I did look at the triton but had never heard of it before so was kind of leary of it. It only had two reviews on amazon so I thought I'd stick with the hitachi which got good reviews also.
It sure is nice to have a woodworking section here now. I've always been intimidated by the other sites for woodworkers being a rookie at it and all. Thanks for all the help folks.
Post by: brdmkr on February 03, 2007, 02:37:35 PM
Quote from: Norm on February 03, 2007, 08:31:21 AM
You know, I drop in on a couple of the woodworking sites just to get ideas, but one of the sites some of the comments can be downright rude.  There is another site that requires that you post under your real name.  Folks there are pretty friendly to one another.  In a way, it reminds me of this site, only devoted entirely to woodworking.
Good luck with the Tim Allen special ;D
Post by: Kevin on February 03, 2007, 09:12:01 PM
Here's a review on the Triton...
http://benchmark.20m.com/reviews/TritonRouter/TritonRouterReview.html
Post by: DR Buck on February 06, 2007, 03:12:30 PM
Didn't see any own up to having the DeWalt.   ::)
  Well, I've got the 2 HP DeWalt 621 and it meets my needs OK.   I haven't used it with any large bits freehand, but it handles them OK mounted under the table.   I've done most of my freehand routing with my really old Craftsman 1hp unit.  It's getting near the end though.
Other than the torque kick at startup the DeWalt is fairly stable and not real hard to keep under control.
Here's the DW-621 link  DeWalt Plunge Router (http://www.dewalt.com/us/products/tool_detail.asp?productID=113)
Post by: metalspinner on February 06, 2007, 05:37:51 PM
Dr buck,
I'll own up to it.  I have the Dewalt, but it's the 625.  It works fine in it's current obligation.  It's  set up in a jointer /planer rig for my really big boards.  It's a little cumbersom trying to use it handheld, but I have the porter cable multi base for that sort of stuff.
(https://forestryforum.com/gallery/albums/userpics/12750/planingopt1.jpg)
Post by: brdmkr on February 06, 2007, 05:50:46 PM
Metalspinner,
What kind of bit do you use in your planing rig?  Is it just a standard straight bit or have you found something better?  I have always wondered if I could find a bit similar to what Lucas sells for their surfacer.
Post by: metalspinner on February 06, 2007, 07:13:07 PM
1 1/4 straight bit.  It's just the biggest I found locally.  I saw a 2 1/4" in a catalogue once, maybe Grizzley.  It was not a straight bit, but it only needs to be flat on the bottom.
Post by: Raphael on February 27, 2007, 10:06:06 AM
  I'm quite happy with the performance of my Fein RT1800, the switch is right there at your finger tips.  Plunge is a little stiff but can be adjusted.  I've heard good things about the Freud FT3000, almost went that way myself...
Post by: tcsmpsi on February 28, 2007, 09:44:57 AM
Plunge router?
Well, I always tried to keep mine from taking plunges, but from time to time, gotta start somewhere.   :D
Back over in another small shop I have an old Black and Decker industrial model mounted in a table.  Both these specimens work real well, though I didn't get a pic of the B&D setup.
I've looked a bit at some of these newer router set ups, and I can't hardly tell which end goes where.   :D
(https://forestryforum.com/gallery/albums/userpics/13641/router.jpg)
I've also got another base and a door hinge jig for this Porter Cable.  Don't know what I'd do if I had to actually replace either of my routers.  What I've seen available is not real inspiring.
Post by: Kevin on March 25, 2007, 03:18:58 PM
The Freud is a beauty!
Soft start whines up like a jet engine.
(https://forestryforum.com/gallery/albums/userpics/10030/Freud%20router.JPG)
Post by: tcsmpsi on April 23, 2007, 09:06:18 AM
Hey Norm
Have you had a chance to use your new Hitachi router?
Sorting through applications, shapers, etc., completely contrary to my post above (well, sort of), I went ahead a purchased a new router.  More hp, and ability to use bigger, more diverse bits.
When WDH was down the other day, we were over in that part of the shop and mentioned, looking over my old Porter Cable router that it was an old one.  He asked me how old, and thinking about it, I told him about 50 yrs old.   Got to looking at my owner's manual for it, and it is actually a bit over 50.
I haven't used it yet, but I did purchase a Makita 3612, that I intend to set up in a table.
Speaking of which, has anyone used one of the table saw extension router tables?  Space and maneuverability are of notable concern at the present time.
I did get a new Hitachi table saw to take the spot of my old Delta, which I believe will accomodate a good sized router table.
I got the designated circuit run for the Hitachi Sat., and though I've only ripped a couple boards through it, it is going to be a notable improvement over the old Delta.
Post by: Norm on April 24, 2007, 07:59:29 AM
I haven't had a chance to run it yet tcsmpsi. I opened the box and went hummm looks complicated...probably should put the owners manual under my pillow and sleep on it.  :D
The Makita was my first choice but it was on backorder through amazon (free 2 day shipping) so I went with the Hitachi. Be interested to how you like it after some use.
Post by: tcsmpsi on April 24, 2007, 10:52:41 AM
Likewise, Norm.
I've never had a plunge router.  There weren't no such critter last time I bought a router.   ;)
I ordered the 3612 from toolsforless.com.  No shipping, in stock and they sent along with it, a nice 3 pc. Makita raised panel door kit.  For 259., I could hardly say no.
I've looked the thing over, dissected it, believe I have a pretty good idea of its workings.
The male teenager left at the house, is showing some propensity of interest in the whole woodworking process, and he would need his own router to learn to live with.
I'm still eyeing the Hitachi.    ;D
