General Forestry => Forestry and Logging => Topic started by: Polly on October 29, 2007, 04:12:58 PM
Title: log length for furnature making
Post by: Polly on October 29, 2007, 04:12:58 PM
 8) :P i got some walnut logs that i want to saw to be used to make furnature what length should i cut them   :-\   thanks for the help
Title: Re: log length for furnature making
Post by: metalspinner on October 29, 2007, 04:38:39 PM
What kind of furniture do you want to make?
Except for one 8' dining table, all of the other furniture in the house is under 6' long/high.  And usually divisible by about three feet.  Table legs are 30" high as are many cabinet doors.
You may want to cut to the best lenghth the log will allow.  I like the crotch areas of walnut, so I try to keep the crotch in the log also. Short logs can be cut to thicker dimensions for table leg stock.  On the Woodmizer my sawyer uses, he has 32" between the middle two bunks, so I won't go shorter than 3' logs. And then only if it's a really nice piece of cherry or walnut to put up with the extra hassle of shorts.
Post by: Ianab on October 29, 2007, 05:22:27 PM
Having all the logs the same length can be an advantage when you are stacking them to dry, but dont cut off good stuff to achieve this ;) You can allways stack the long stuff on the bottom and shorter boards on top.
So let the tree decide how you buck it, try hard not to go shorter than 8ft, that is hard to cut on some mills. If you are using the wood yourself the exact lengths dont matter so much. Look for the big knots or curves on the log and decide with those in mind. Then just make the longest logs the tree allows and you can reasonably handle.
Cheers
Post by: Haytrader on October 29, 2007, 08:40:21 PM
We saw mostly ERC @ 6'.
Post by: WDH on October 30, 2007, 01:19:57 AM
8' up to 10' is what I shoot for.  Nothing longer than that has any furniture application unless you are selling into the wholesalw hardwood lumber market.  Your target market is the key.
Post by: Ron Wenrich on October 30, 2007, 05:37:26 AM
You'll find that the wholesale lumber market caters mainly to large scale users.  The longer lengths are only beneficial to handling the lumber.  Boards are kept long for the drying and surfacing, but when you hit the cut up shop, it all gets taken down to small pieces.  The only exception if for moldings, where long, clear pieces are needed.
For custom furniture making, take what the log gives you.  Make the log straight and as long as you can.  Crooked logs don't usually give very good lumber.
Post by: GHRoberts on October 30, 2007, 12:19:35 PM
I build a bit of furniture.
It is always beneficial to keep boards as large as possible as long as possible. It is even beneficial to keep boards from the same log together.
I just finished a pair of highboys. The grain on the drawers runs from one into the other. That required 8' long boards.
I have 13' boards in my shop. It is nice to make a piece of furniture from a single board. It also helps when there are defects in the board - lots of layout options.
