General Forestry => Forestry and Logging => Topic started by: J_T on May 10, 2003, 09:34:58 PM
Title: Tractor
Post by: J_T on May 10, 2003, 09:34:58 PM
Found 826 IH with a german deisel motor at a bargan I think. I know a skidder would be better as I use to have one. But times have are differnt. So now I need to pull logs lift slabs ect all with one machine. Does anyone know anything about tthis tractor do they hold up and can you get parts? Thanks JT  :)
Title: Re: Tractor
Post by: Tillaway on May 10, 2003, 09:41:19 PM
Is that a Duetz diesel motor?  They are suppose to be real good.  A friend has a Duetz tractor and loves it.
Title: Re: Tractor
Post by: chet on May 10, 2003, 09:50:46 PM
Ran a C5 treefarmer skidder for years with a Duetz. Yery tough and dependable engine.
Title: Re: Tractor
Post by: J_T on May 10, 2003, 09:56:21 PM
Don't know tractor is 225 miles away depends wat you folks say as to wether I drive that far to look at it. :)
Title: Re: Tractor
Post by: Bro. Noble on May 11, 2003, 08:35:57 AM
J_T,
The IH 826 was made around 1970.  Along about that time US tractor manufacturers where having some of their tractors/engines made in Germany.  Do you know if that is the case with this tractor or has someone changed the engine?
That tractor originally had a 358 cubic inch 6 cylinder engine rated at 92 hp.  It was made by IH but my info doesn't tell where.  They evidentally made it for only a short period of time.  They also made it with a hydrostatic transmission as an option.  I personally would avoid that like the plague.
I scanned through the FASTLINE publication thinking I could get the selling price for an 826 but didn't see a single one listed.
Unless you know and trust the owner or I wouldn't drive that far to look at it myself.  You could call the local dealer (which is now probably New Holland) and find out more about it and parts availibility.
Experience with machinery has convinced me to make sure that what I buy is what I want and need and not just cheap.
We use a 55 hp tractor with 4WD and a loader.  I like the manuverability of a smaller tractor and the 4 WD is a must logging in hilly ground  and lifting heavy stuff with a loader.
Noble
Title: Re: Tractor
Post by: redpowerd on May 11, 2003, 09:04:19 AM
where do you find yer info, noble?
i know i got 6 series i+t service manual around here somewhere......might take a bit, but ill post back.
Title: Re: Tractor
Post by: J_T on May 11, 2003, 03:20:01 PM
How about a 445 Long 4 wheel drive ? looks like a 5040 ac to me. Thanks  ???
Title: Re: Tractor
Post by: dail_h on May 11, 2003, 07:43:21 PM
   JT
   Your CASE IH dealer should have info & parts I don't know about the German motor though. The 445 Long and the 5040 Allis were made by Fiat I think
Title: Re: Tractor
Post by: DanG on May 11, 2003, 08:13:19 PM
JT, if you really want to find out about a tractor, have the dealer look it up by Serial #, not just model #.  I once rebuilt the engine in a Massey Ferg, and ordered the cylinder sleeves 3 times. They came in wrong each time. The dealer asked me for the serial number, and found that I had one of less than a hundred made with this version of the engine. They finally located the sleeves in a warehouse in England, and it took six weeks to get them.
Go look at the tractor.  It is impossible to drive 450 miles in this country, without seeing something that makes the trip worthwhile. If you buy the tractor, you get to do the trip over again, and see all the things you missed the first time. :)
Title: Re: Tractor
Post by: woodmills1 on May 12, 2003, 06:59:35 PM
I saw a long tractor last saturday.  not sure but over 50 horse it lookedlike one rugged 4x4.  the owner just lugged it around at low rpm dragging oak and lifting them up.  its front tires were like as big as my 30 horse back ones.
Title: Re: Tractor
Post by: Bro. Noble on May 12, 2003, 07:34:25 PM
I know a few people who have Long tractors and like them all right  but I don't know what model they have.
The U445 is a utility tractor which is much better for logging (in my opinion) that a rowcrop tractor like the IH 826.
According to the Nebraska Tractor Tests (1972)   the 445 was made in Romania and has a Uzina 3 cyl engine with 143 CID and rated at 42 hp.  During 46 hrs of testing,  broken rings were found on two of the cylinders.
Some of the Long tractors had Perkins engines whould would make them a lot more attractive to me.
Noble
Title: Re: Tractor
Post by: redpowerd on May 14, 2003, 07:19:04 PM
noble, info please, that stuff was right outta the box
Title: Re: Tractor
Post by: Bro. Noble on May 14, 2003, 09:33:50 PM
redpowered,
Oops,  I shouldn't have told,  now you will be as smart as me :D
Noble
Title: Re: Tractor
Post by: redpowerd on May 15, 2003, 06:59:54 AM
sheesh, that books expensive, and they make a new model every year. better find a used one
Title: Re: Tractor
Post by: J_T on May 15, 2003, 10:53:05 PM
 Found lot's info on that Long tractor today .has a Fiat 3cyl motor. Caller the foctory got dealer names also Long has a web site. Stock about 45 hp forgot to ask proper front tire size . This one has 750X20 on frount 13.6x28 rear Talked to four dealers only found one used two wheel drive. Said parts were no problem. They are same as 5040 ac and some others just diffrent color and name. Still thinking . :-/
