I worked on a little project with my Peterson a few weeks ago. It had the 13hp Honda, and I put on an older 23hp Kohler. What a difference. :)
(https://forestryforum.com/gallery/albums/userpics/16776/millnewmotor_010.jpg)
This kohler is solid cast iron, with twin horizontal cylinders and was tuned up and new rings when I got it. Paid $350 ;D
(https://forestryforum.com/gallery/albums/userpics/16776/millnewmotor_003.jpg)
The old honda motor mount and adjuster to Kohler adapter. I was able to use the old stainless hardware that came with the mill.
(https://forestryforum.com/gallery/albums/userpics/16776/millnewmotor_004.jpg)
I used a generator frame and fuel tank for my accessories. Cut it down to the right size and rewelded it. The tank holds 5.5 gallons. I don't need gravity feed, but the in-bed fuel tank was pretty expensive. This is bolted on and doesn't vibrate at all, so works good.
(https://forestryforum.com/gallery/albums/userpics/16776/millnewmotor_006.jpg)
I have been using a coleman water jug from the hardware store, I think they cost eight bucks. I made this valve, and if the jug needs replaced I can just keep using the old valve on the new jug. Way more durable than the plastic valve. The battery fits in a little compartment behind that. I also had to get a new pulley, and painted everything Farmer Green. Total cost about $500
Very Cool ;D ;D ;D
Gday
Top Job Erik ;) ;D ;D 8) and only $350 mate :o ;) ;D
I was yaking to the old man about upgading the lucas from the 20hp briggs pull start to a 30 hp kohler elec start when we picked the mill up but only having 75 hrs on the clock ;) and 140 now and 15000 bft later ;D 8) I dont mind only having the 20 briggs and pull starting it starts first pull every time and saws great ;D so i dont see things changing for a looong while yet mate ;) ;D But i still think it would make a great chopsaw motor so you never know ;) :D :D :D ;D
Keep up the good work Mate ;D ;D 8)
Chris
Looks like it's just supposed to be that way! ;D
Nice looking job! :)
A few more horse power makes quite a difference, and you almost doubled the hp so I'm sure you really noticed a difference. 8)
Hey Chris, I am as happy about the electric start as I am the added power. My Honda starts good, so I'll find another use for it or sell it. Maybe a big woodsplitter? Pull starting a 20 hp sounds like a chore to me. :o
There is twice the torque on this one, and almost twice the hp. I'm not sure which is helping more, but it has a lot more power for sure. Also the mill vibrates less when it's really working hard. I guess the twin cylinder runs smoother.
Gday
I find twins run a hell of alot smoother than a singles probly because the pistons arnt in a vertical plane ;) ;D
Chris
Here is a couple of the 1st days after the new motor.
(https://forestryforum.com/gallery/albums/userpics/16776/millnewmotor_014.jpg)
With dad's help, we cut about 3 hours 3 different days. Total of 2250 or so bdft. all of it was doug fir, my neighbors logs. He paid for the 16' 2x6 and the biggest beams, I kept the rest in trade for falling the trees. Only 2 trees to fall :) He is making a 24 x 12 horse shelter and has 50 more 2 x6 for whatever else. I am framing a chicken coop and covered run. I probably could have put this in the good neighbor thread on the general board instead!
(https://forestryforum.com/gallery/albums/userpics/16776/millnewmotor_001.jpg)
Now there is 6 or 7 inches of snow on everything, and falling fast.
Congrats on the upgrade Erik. I looks like you are ready for the snow to melt!
Captain
