General Forestry => Chainsaws => Topic started by: D._Frederick on September 10, 2009, 06:08:47 PM
The instruction manual with my 372 requires taking out screw to clean it.
If you are constantly taking screw in and out, how do you keep them tight? Do you Locktight them in?
Uh... which screw?
Gary
Quote from: GASoline71 on September 10, 2009, 07:51:23 PM
Uh... which screw?
Gary
Gary I think he means the screws in the cover for the pull start Mate ;)
Nah thats what the chainsaw spanners for ;) :D ;D just check them every morning when your using the saw ;) ;D 8) Also check your muffler with alanskey every so often it'll save it from rattling itself to bits too mate ;)
Regards Chris
You guys are talkin' in hieroglyphics mang... :D :D
Gary
I took out the seven screws that hold the starter assembly and the cylinder cover, was surpriced to fined that metal screw inserts were in the plastic. I was thinking that the screws screw directly into plastic and taking them in and out would result in problems.
