does anyone know anything about this saw 012? i have a 011, will parts interchange? is this a better pro saw than the 011? thanks nfp
I don't know, nfp. I have an 034 and an 038super, and used to have an 084. All great saws, in my opinion. I don't know about part interchanging, but any Stihl dealer should be able to tell you.
All I can add is the even numbered Stihls are suppose to be a better saw than the odd numbered saws.
Now that IS odd! :D :D :D- seriously, why would that be? Day of the week on which they were manufactured? Do they have an 013- is it specially bad? lw
The mid range pro and production Stihls are all even numbered.
The mid range home owner saws are all odd numbered.
What`s the difference you ask?
You`ll need to ask your dealer, I don`t know the answer.
I think they`re all good saws but the pro saws are heavy duty and may take a little more abuse.
Sawbuster[/i]
So I'm performing mental calculations (lightning like)- thinking 'even, odd, even, odd'- 51, my saw's a 51- now is that a GOOD saw or is that a BAD saw- and suddenly, the dim leetle lightbulb goes on- 'OH..YEAHH.. it's a HUSQVARNA 51- not a Stihl'...as Rosanna Rosannadanna used to say...'never mind'..thought I was on a roll for a minute there..
:D :D lw
I must be ok then because I have a Husky 61. It is 8 years old and still running like a bandit. ;D
Most of these good-old saws are taken off the market if they don't wear out. I noticed tonite that the 61 is no longer in the catalogue.
Hi Tom,
There is one exception to that rule that I know of! The Stihl 038 is a magnificent saw, and can take a huge amount of abuse (not that it should!), and still keep running. Its been made for over 20 years now, and varies little from the original.
Now thats a saw. The 090 is heading along the same lines with few changes since '59 (I think). Oh look, both even numbers!! I would agree that the even numbered saws tend to be stronger, but then they also cost more! People rave about the 028 (not made now I beleive) as the best saw Stihl ever made.
Cheers
Charlie.
I agree on the 028. I also have an 032 that's still going strong. I guess they don't make it anymore either. Parts are getting harder to get.
every time i see a used 028 cheap, i buy it and scavange parts to keep two running. :D :D i need another right now because only one currently runs. the other one actually rusted through the gas tank. :-X i sharpen the little chain on them with a big chain file. you should see them little saws cut. ;D ;D light also. i have an 038 that continues to hog out wood. now my 009 is just finiky and my 045 is way too heavy, i think i have had it since 1975, and i bought it used.
