General Forestry => Sawmills and Milling => Topic started by: Knute on July 14, 2010, 08:44:09 PM
Title: Bandmilling ?
Post by: Knute on July 14, 2010, 08:44:09 PM
I had some red oak sawn with a bandmill and the boards seemed to have horizontal tooth marks across the boards deeper than in the past. Also, a lot of sawdust was left on the surface of the boards. Not a big problem, but does cause a little extra planing to get rid of those tooth marks. Thought many of you would know the cause.
Title: Re: Bandmilling ?
Post by: Bill Gaiche on July 14, 2010, 09:03:13 PM
I had this happen to me the other day sawing some hickory. Problem was I had nicked my log stop and knocked one tooth out quite a bit and it sure was putting the marks across the boards. Changed blade and all was well.
Post by: Planman1954 on July 14, 2010, 09:04:11 PM
From my very limited experience, the brand of the blade can determine smoothness of cut. My buddy and I have done a little experiment....woodmizer won. It can also possibly be the quality of a resharpened blade. I'm sure others will have more to say than I.
God bless.
Post by: Magicman on July 14, 2010, 09:38:40 PM
Sadly, sometimes sawyers will use a blade that has one or more teeth out of whack.  This may not be an issue with framing lumber, but the blade should have been changed before sawing lumber that will be planed.
Post by: Knute on July 14, 2010, 09:46:32 PM
Thanks. I know resharpened blades were being used but not sure who sharpened them.
Post by: rbarshaw on July 14, 2010, 09:46:47 PM
For me it was always caused by one or more teeth being bent slightly out from all the others.
Post by: ladylake on July 15, 2010, 04:50:22 AM
 Yes a bent tooth or 2 and the extra sawdust comes from more set. Those boards would have to be pretty ugly not to plane out on the first pass. If planing from 1" to 13/16 there's no chance of the teeth marks still being there assuming they are cut straight which is far more important than a few teeth marks.   Steve
Post by: Chuck White on July 15, 2010, 06:55:04 AM
Sometimes, when I set the teeth in my blades, for some reason they will set too far.
That is if I'm setting at .025, when I move the setter handle forward again to check to see what the tooth actually set at, it'll be maybe .030.  At that point, I have to straighten that particular tooth and start over.
If you don't double check the set and a couple of teeth get out of set like that, you'll get some "snaggle-tooth" stuff.
I think the extra sawdust can be from lots of things, too much set, uneven set and too much water.
Post by: bandmiller2 on July 15, 2010, 07:15:51 AM
Knute,very common problem on a bandmill usally no problem unless a tooth is way out.The usual cause is hitting a small nail,unless of course the person setting the blade was asleep at the switch.Sometimes you can see the splayed out tooth/teeth I usally shut the mill down and take a piece of sticking lightly running it over the band when something feels differant thats the tooth.A small adjustable wrench will bend the tooth back in line.Frank C.
Post by: ely on July 15, 2010, 08:50:47 AM
i was sawing some of those shorts the other day, when i had a knot that was ahead on the log rub against my drive belt on the LM. well it pushed the drive belt smooth off the wheel as i was running wide open. so after i changed out the drive belt with a new one and put the blade back on i noticed these lines you are talking about on my boards as they came off the mill. it was not on the cant so i knew which side of the band to check. sure enough i found one tooth had hit something in the launch. when i grabbed it with pliers to bend it down it just broke right off, problem solved. smooth lumber again.
most of the time you will see the tell tale lines in all lumber, the better the band is at the weld joint the less noticable they are in the product. in my experience.
