General Forestry => Sawmills and Milling => Topic started by: mrcaptainbob on July 29, 2010, 11:53:58 PM
Title: Standing mill wood...
Post by: mrcaptainbob on July 29, 2010, 11:53:58 PM
The neighbor who's building his sawmill stopped by this eve with a question....how about cutting a standing tree similar to girdling it, but maybe deeper than just the bark. Say about two inches. Leave it stand for a year. It's off the ground, dries out from the sides with probably less cracking. When it's time, cut it down and run it through the saw mill. Good idea? Bad idea? Any  opinions?
Title: Re: Standing mill wood...
Post by: tyb525 on July 29, 2010, 11:57:42 PM
It's is best to cut a log as green as possible. Older logs can be harder to saw, plus they will never dry in the middle, and there will still be cracks. I don't think there is much to gain.
Post by: Jeff on July 30, 2010, 12:00:00 AM
Bad Idea.  Ty is right on the money.
Post by: tyb525 on July 30, 2010, 12:02:48 AM
I've heard many people (mostly old-timers) mention "seasoning" logs a year or two before cutting them when I am talking with them about sawing, and then I have to tell them the bad news. I wonder where this idea came from that is so wide spread?
Post by: Chris Burchfield on July 30, 2010, 08:13:57 AM
There may be motive in the madness for some applications.  I've not been around any of the operations but I've read where log home builders will dry their logs before milling for up to a couple of years.
Post by: bandmiller2 on July 30, 2010, 08:31:39 AM
To each his own.Soft woods are best cut freash,hardwoods I prefer to let them sit off the ground up to a year harder to cut yes but a better more stable product.Was common practice up here in the northeast to save really fine oak logs in the mill pond sometimes for many years.Of course I'am old and mayby not believable.Frank C.
Post by: tyb525 on July 30, 2010, 09:43:32 AM
Bandmiller I believe you I just wanna know why they did that :)
Post by: Jeff on July 30, 2010, 10:19:08 AM
Now how in tarnation is a log to season while in a pond? I have to think the only reason you would save logs for many years in a pond was to keep them from drying until you found a use or a market, certainly not to season them.
I don't believe for a second that drying hardwood logs before sawing reduces stress in the lumber, in fact after years and years of sawing it, I know that's not so.  I've sawn everything from trees that were standing only minutes before they were on the mill on a portable mill, to logs that had been stored in a barn for a dozen years "Curing" by an old farmer that believed such fallacy.  That log was the worst log I ever sawed. I'm talking hundreds of logs a day over 25 years, so I got to see a long term sampling of results. Lumber from older dried logs is no better then that from green, and probably worse because of the difficulty increased in sawing a quality product.
Log home logs is a different animal.
Post by: bandmiller2 on July 30, 2010, 10:55:10 AM
Oak logs are put in water to hold them in good condition,in Maine I've seen piles of logs kept wet with sprinklers,I would guess to keep insects out of them.I don't like milling hard dry oak but logs stored for several months off the ground don't move around as much when you mill them.As with everthing in this trade outhers mileage may vary.I have tried girdling oak with leaves,in theory it will reduce the moisture but I've found it not worth the effort.Not trying to dissagree with you Jeff just my experiance.Frank C.
Post by: Jeff on July 30, 2010, 11:04:12 AM
 Its a theory based on your past experience yes. I understand. My experience is far different and all we ever sawed at the mill was hardwoods. I suggest the logs you dried were not going to move around green either then. Red Oak is inherently stable to begin with compared to a lot of other species.  The question that this brings to bare, how do you know they did not move around as much? You can't unless you sawed them green, reassembled them, and then sawed them again.
I love a debate. :)
Post by: Ron Wenrich on July 30, 2010, 11:24:57 AM
Am I the only guy that's sawed standing dead wood?  Well, it wasn't standing when I sawed it.  But, I've gone through gobs of wood that has been dead, some for years.  Red oak, white oak, ash, hickory and tulip poplar.  A lot of this has had the bark fall off.
The sapwood is the first to go.  It either turns to punk or it gets brittle and is discolored.  The remaining wood, if the bugs don't get to it, is dry and dusty.  Sometimes you'll find pockets of dote.  But, the color doesn't seem to be as good as the fresh logs.
In theory, curing the log would mean that you could use the lumber right away.  The only problem is that you're also curing the sawdust, and it takes a whole lot longer to cure a log than it does to cure boards.
A board that comes from a log with twist, will yield twisted lumber.  It might not be evident right away, but as the moisture content changes, so will the board.  Stability is the reason they take big boards and rip into smaller strips, then glue them back together.  Do away with twisted logs, and you get straight lumber.
Ponds were used to keep logs fresh.  The water blocked the drying process, kept the bugs off and kept out the blue stain.  Sprinklers are used to keep logs fresh, but mainly to keep out the bugs.  I've seen them mainly on ash logs to keep out powder post beetle.
Post by: terrifictimbersllc on July 30, 2010, 11:42:18 AM
Here's the opposite of drying out.  These logs floated up onto the beach from Long Island Sound.  Owner went over with his backhoe, brought them home and called me.  Sawed out some pretty decent boards had some unusual green and blue streaks in them. We thought they were maple.  Terrificwoman said they looked shriveled.
(https://forestryforum.com/gallery/albums/userpics/21495/2822/shriveled.jpg)
Post by: Jeff on July 30, 2010, 12:03:20 PM
I've sawn more then a little standing dead wood. We were a ground zero area in this part of Michigan for Gypsy moths.
Post by: Magicman on July 30, 2010, 01:37:07 PM
Probably 75%+ of the logs that I saw are beetle killed SYP.  I find that they are much more stable than fresh cut.  Maybe the rosin has set or something?  The lumber from beetle killed SYP is much lighter and will dry quicker than fresh.
I just finished a job with over 100 SYP beetle killed logs.  Of that, I encountered only one "suck butt" cant that had to be flipped.  In March, I sawed a SYP job with all fresh cut trees.  I flipped several cants every day.
Looking at the OP,  I would never girdle a tree to speed up anything.  I would saw it green first.
Post by: paul case on July 30, 2010, 03:19:11 PM
saw it green gets my vote.
of the dead stuff i have sawn some is no good at all and all of it looses some wood. like everybody else says the sapwood is the first to go. take the sapwood off a 20'' post oak and you get almost as much slabs as good wood. drying a log by leaving it standing dead is no way to go. if you are concerned about some boards not drying well consider this the waste of the sapwood rotting off the log and having to be discarded is far more than a few boards that may twist or cup.  they probably will still be those few twists and cups even after the loss.pc
Post by: Ernie on July 30, 2010, 03:32:50 PM
Quote from: terrifictimbersllc on July 30, 2010, 11:42:18 AM
How did you get the sand out?  ??? Any driftwood I have milled sure dulled my carbide teeth real quick. :(
Post by: Jeff on July 30, 2010, 03:36:19 PM
mrcaptainbob  odds on, is referring to hardwoods considering what part of Michigan he is from.
Post by: terrifictimbersllc on July 30, 2010, 07:46:21 PM
Quote from: Ernie on July 30, 2010, 03:32:50 PM
I don't remember any issue.  I think he powerwashed them.  There were only a few and 7-8' I think.  It's possible the blade was dulled faster but nothing I remember.
Post by: bandmiller2 on July 30, 2010, 09:28:36 PM
Jeff,glad you consider it a debate and not a mutany.Of course its hard for me to prove,I'am not talking about letting the log dry out that takes forever and makes them difficult  to mill.My first circular mill had limited clamping ability,would take a slab cut flip it down and a 2" bow ,mostly white some red oak.Tried letting the logs sit  3 or4 months and had few problems.Probibly wouldn't have had trouble with hydraulic dogs.Frank C.
Post by: tyb525 on July 30, 2010, 10:30:18 PM
My biggest sawing job was all walnut that had been dead standing for many years. >1000 bf. The sapwood might as well been sponge. The heart wood was very tough to saw. My cuts were wavy much more than normal, and I had to slow feed way down for knots. Not to mention that unless I really poured the water on, the sawdust refused to stay on the ground, or even land there. Whenever there was the slightest breeze, it sent the dust flying, usually into my eyes (even with safety glasses on). I never have that problem with green logs.
I think the reason for log ponds, sprinklers, etc., is to keep the logs fresh and bugs off until they get the chance to mill them. I don't think they do it for any other reason.
Post by: mrcaptainbob on July 30, 2010, 11:58:50 PM
Good info and great dialogue. Sure appreciate the high plane you people are on. No snarky, no petty, just great discussion. Thanks.
Post by: bandmiller2 on July 31, 2010, 05:30:14 AM
Ty,get yourself a pair of goggles,the clear plastic ones for those dusty logs.If you have power at the mill site a big fan can help.Walnut sawdust can be toxic to some folks and even plants.My old buddy Spike grew up in Maine, in his youth worked in a mill,the sawyer showed him a huge white oak log in the bottom of the mill pond said his granddad put it there 100 yrs. ago,said he was saving it for a special job.Frank C.
Post by: ladylake on July 31, 2010, 07:01:02 AM
 I sawed some of those nice old white oak, red oak and elm logs the other morning. On quite a few the boards came off like banannas, white oak was worst then red oak. The elm came off straight, I think it was dry all the way through.  Steve
Post by: barbender on July 31, 2010, 07:40:06 AM
I am sawing some red oak that was dead standing for around 5 years, all the sapwood is punk and some of the heartwood too. On top of that, it is still WET. I'd much rather have some green logs right of the stump.
Post by: Magicman on July 31, 2010, 08:21:30 AM
Quote from: barbender on July 31, 2010, 07:40:06 AM
all the sapwood is punk ...... heartwood.....is still WET
As tyb said at the beginning.  You can rot it but you can't dry it standing.   ;)
Post by: Mark Webb on July 31, 2010, 07:51:23 PM
Wilson Cypress Company, One of the largest cypress mills in the country, was located here in Palatka, Florida.  They cut from the late 1800's till around the 1930's when all they large cypress was almost gone. They would send their men out a year in advance of cutting a stand and girdle all the trees they intended to harvest, to kill them in other words. This was done so they could make rafts and float to the mill in Palatka. If the tree wasn't completely girdled it would still have enough green wood in it so it would sink. That is where we are getting alot of the dead head cypress and pine (longleaf) that is valued so highly today. There is still one large cypress standing down by Sanford, Florida that is 17' 9" in diameter. But back in Wilson's days these and larger (25' )were not uncommon.
Post by: tyb525 on July 31, 2010, 08:08:17 PM
Mark, that is interesting info. I suppose that was a special case for cypress though.
But if it wasn't for those rafters and loggers, we wouldn't have this beautiful sinker cypress you see today :)
Post by: Mark Webb on August 01, 2010, 06:30:26 PM
(https://forestryforum.com/gallery/albums/userpics/21843/2898/Big_Cypress.jpg)
I was able to find this picture of the big cypress I was talking about. This was taken in 1952 and I am the little boy on the front row, left end.
Post by: tyb525 on August 01, 2010, 06:51:44 PM
Boy Mark, you haven't changed a bit in 58 years! ;) ;D
That's a big tree!
Post by: Magicman on August 01, 2010, 08:18:11 PM
'cept, he had shoes on then.    :D
Post by: Jeff on August 02, 2010, 08:56:56 AM
Here is an old clip of harvesting Cypress. Its pretty poor quality. I captured it from an old film we had here quite a few years ago.
http://www.youtube.com/watch?v=yLxNf3C-pro
Post by: Meadows Miller on August 02, 2010, 10:52:05 AM
Gday
Griding trees has its place like Jeff said  With Log building the main reasons for that are that there will be less settling to allow for and you can put the lagest raidial check into the cope and cut most of it out  ;) but one issue is if you want a clean look to your log wall system you need to do alot more draw knife work to get a nice finish  ;) We always used fresh select grade logs for our houses in D/fir and Radiata pine we also did one place with Redwood 50' footers with one flat side for the internal wall that was the softest stuff ive ever milled it was like a hot knife through butter  ;) :D ;D ;D 8) 8)
Asfar as Sawing goes Cut them as soon as they have been felled as Softwood degrades fast and you end up with more waste . And in Hardwoods down here the main issues to deal with are tension and degrade through checking & end splits and it just makes more work for the sawyer because you then have to saw the log to suit those things its just an added defect to deal with  ;) Case hardening is another issue with logs that have been stockpiled or standing dead for awhile  ;)
Ty down here in the hardwood industry we use sprinklers because we dont log hardwoods in the high country during 3 to 4 months of winter so the loggers go flat out during summer to get the mills quotas in to the mill yard wich is the worst time for degrade to happen  Mate ;)
Asfar as releving tension in logs i can tell you that it dont matter if the logs been down a day or 80 years if it still has that sapwood still on it its gonna move (pull) where ever it wants to to go if you dont allow for it  ;)
Mark and Jeff nice info and clip  ;) ;D 8) 8) I think we only had three species that where floated in any great volumes which was Red Cedar ,Huon Pine and Hoop pine most of are hardwoods are too dence to float and if you rolled a log in to a river it would disspear on you  :o :) ;)  :D :D Red gum was floated in a way up on the river but they used outrigger barges with the paddle steamers back in the day
Regards Chris
Post by: Magicman on August 02, 2010, 12:04:23 PM
Quote from: Jeff on August 02, 2010, 08:56:56 AM
I love watching those old logging clips, no matter what the quality.  That's some interesting old lost sawing techniques.
Post by: rpg52 on August 02, 2010, 05:13:13 PM
I've been told, ("short hand for not having any experience.") that Madrone, a hardwood found along the Pacific coast from N. Calif. to Canada, will cut without checking if buried in mud for a year or so.  Otherwise, it checks terribly like many other related species such as the Manzanitas (lots of these in California).  Don't have any personal experience with it so really don't have much factual to add to the discussion.
Ray
Post by: Magicman on August 02, 2010, 05:25:18 PM
Do Manzanitas get large enough to saw?  I saw lots of them with the redish bark peeling that were only clumps of bushes, similar to our Crepe Myrtles.  Maybe different varieties?
Post by: Dave Shepard on August 02, 2010, 07:40:58 PM
I run into this debate frequently. I DO NOT want to see any old logs come into the log yard. Old white pine, fine, but there will be an assortment of degrade, but it will still saw fine. Hardwoods present an altogether different scenario. I'm sawing cherry right now that is probably between 1 and 2 years old. I had to switch to a 4° band, saw slower, and flip more often. Fresh cherry I can saw with a 10° band, and go probably twice as fast. I may be wrong, but I think if you saw fresh logs, you can get the lumber stickered or in the kiln and have a much better chance at reducing loss to end checking. These cherry logs are full of end checks, which means I now have to consider that when I choose my opening face.
Had one guy tell me that seasoning hickory in the log was the only way to saw it. ??? I told him the best way to saw hickory was to drop the tree across the mill and have someone limbing just ahead of the sawhead, and they might get it before it split in two. I've also resawn a lot of old timbers. They move around when you cut into them as well.
