General Forestry => General Board => Topic started by: shinnlinger on September 06, 2010, 12:32:37 PM
Title: Used Kubota wheels????
Post by: shinnlinger on September 06, 2010, 12:32:37 PM
Hi,
The front wheels on my '85 Kubota L2850 are getting rusty and now chafe the tubes so they don't last very long.  Tried some wire brush action but might be time for some new wheels.
I am sure New Kubota wheels are way more than I want to pay.  Does anyone know if there is a generic steel replacement or a place to buy used wheels?
they are 7-16 ag tires with 6 on about 6 and 3-32nds bolt pattern.  Part number is L8801.
Thanks.
Dave
Title: Re: Used Kubota wheels????
Post by: RSteiner on September 07, 2010, 07:22:46 AM
I have a Kubota that is a little newer and the rims are made by Titan International.  They have a website with a dealer locater for your area, you might find their prices better or maybe they can cross reference them.
Randy
Post by: pineywoods on September 07, 2010, 11:19:04 AM
There is a place in chattanooga tn that will sell you new rims for most tractors with foam filled aircraft tires mounted. No flats, can't wear them out.
Post by: shinnlinger on September 07, 2010, 07:59:25 PM
Think they make an ag tread aircraft tire?????
Post by: pineywoods on September 07, 2010, 08:03:35 PM
Quote from: shinnlinger on September 07, 2010, 07:59:25 PM
front wheels only  :-[
Post by: Ironwood on September 07, 2010, 11:22:48 PM
I think Gempler's custom ordered rims for my Gator for me. I dont remember the contact w/ Gempler's but call them and you should be directed to the guy.
Ironwood
Post by: RSteiner on September 08, 2010, 06:32:24 AM
I have heard very good things about this dealer and their ability to help people get what they need.  Give them a call.
www.messicks.com/
I am sure they can get you replacement rims and may be able to tell you where to look for used rims.
Randy
Post by: Stan snider on September 08, 2010, 07:18:55 AM
If the rims are still solid they could be sandblasted then painted. You can make a leaker out of tubeless wheels with too big of grit and high pressure though. A siphon feed blaster wwill do the jab pretty quick for a DIY fix. Stan
Post by: Dana on September 08, 2010, 07:41:31 AM
I believe Titan has been purchased by Good Year. They still go under the Titan name.
As was mentioned the rims can be sandblasted, primed and painted.
My 70 Ford was chaffing a hole in the tube this summer. I suspected a rusty rim and cleaned it up several times with a wire brush. The tube would continue to get a new leak. What I found was that the side walls of the tire had slightly deteriorated and were wearing into the tube each time the wheel turned. A new tire took care of the problem.
