I am purchasing some land that was clear cut 4-5 years ago. There are a large amount of small pine trees around 4 to 6 feet tall that have come up that I would like to try and thin before it grows into a clumped mess. I have heard of a brown tree cutter that can be attached to a tractor but have also heard you have to add armor to the tractor to protect the undercarriage. I have also seen bush hog type attachments for skid steers. Does anyone have any suggestions on the best way to thin this out? I need something that is compact enough to maneuver around in and thin the trees with.
(https://forestryforum.com/gallery/albums/userpics/25085/3332/Pine_Trees.JPG)
(https://forestryforum.com/gallery/albums/userpics/25085/3332/trees_2.JPG)
This is the most economical, but physically challenging at times. ;D That far south, your going to want to do it in the winter months. Too hot in your summers.
(https://forestryforum.com/gallery/albums/userpics/11009/SD_SpacingSaw.jpg)
This is in New Brunswick. This is mixed growth, don't hit any softwood for a few yards back from the road. In New Brunswick 100's a professionals thin stands of young trees on public land and private woodlots.
(https://forestryforum.com/gallery/albums/userpics/11009/SD_brushcutting_FS550.jpg)
Here is a combination of machine and brush saw in Pine in Va. from another forum thread.
https://forestryforum.com/board/index.php/topic,42577.0.html
I'm sure WDH will chime in with some good advice, but I have seen areas like this thin itself some naturally and in a few yrs a thinning crew will finish it. We had a similar plot that naturally seeded and it has been thinned twice and has a good spacing for some good sawlog growth now.
Don
My first thought was along the lines of SD's , get in there with some power tools and thin / prune by hand.
But before that, what's your long term objective here?
Long term timber production?
Hunting area?
Something else?
Once we know what your are trying to achieve it's easier to advise.
I agree with last guy. Figure out objective. Get in there and see how many trees per acre you have. Consult literature on species management to see what your target trees per acre should be. Then treat it if you need to. It doesn't look over stocked in those pictures.
I also agree with you guys. But, as far as thick, don't overlook the hardwood not leafed out yet. That can be a lot thicker when hardwood is counted. I can also tell ya that the first 50 m is always lighter than behind because of the machine travel. I will also say that if you concentrate on the management of the trees, in this case the spacing,quality and species selection for diversity, the wildlife will look after themselves. ;) Let's not get into a whole lot of other wildlife things because we have an even aged stand here which is uniform in age, height and canopy layer. I've yet to see the moose, grouse, song birds and rabbits die off from pre-commercial thinnings. :D The structure is not likely inviting to a woodpecker nor an eagle for example. ;) If I were anyone doing thinning on my own ground, I would manage it for more than one species. And I have done that for my own land, even though most was planted. I still favored and decent looking cedar, hardwood, aspen, or fir. That way I can go in there several times to access the faster growing species and later the longer lived slower species. I can have the benefits of not waiting so long to harvest trees again.
First, Welcome gdk771, to the Forestry Forum.
As Don mentioned, 5 year old growth in Georgia will not be thinned by hand. My take is to just let it grow. A lot of natural thinning will take place. When it reaches first thinning size, the feller will make rows.
If there are undesirable tree species, you can walk through and do a hack-n-squirt to rid them.
I just followed the above procedure on a volunteer 15 acre stand of pine/hardwood. It was mechanically first thinned a couple of months ago.
WDH, where are you? ;)
Here I am, but y'all don't need me ;D. Don's advice is spot on from what we can see in the pictures!
I, too, would leave it to grow and deal with the density and spacing at the first thinning in about 5-6 years.
A brown tree cutter would indeed work well on that patch, but I agree with Don and Danny. Just eave it alone for 5 or 6 years and then thin. Mother nature will weed out the weaker trees and prune off the lower limbs. Watch the growth rate. When they stop growing, it's time to thin. We have several old pastures that "went native" with volunteer pine. Probably will need 3 thinnings before it gets to sawlog size.
Tell me what the target species is and I will look up the research and explain how to calculate your current stocking. You don't need to re-invent the wheel here, research can tell us optimum stocking for maximum growth and yield, we just need to punch in the numbers. Often times if you let the stand self thin until merchantable, you can skip a pre-commercial thin and go right to profit or at least break even.
4 to 6 feet is a little short. Appeared taller in the photos. Looked like 12 feet. ::) But looks like your going to have a thick crop of hardwood in that pine though. I can't imagine hack and squirting on 15 acres of thick woods. It would be endless. Maybe thick to me is a lot thicker than for others. ;)
Thanks for the replies. I primarily would like to thin it out so that someday perhaps I would have some harvestable timber but this is long term (15-20 years). For now, I'd just like to thin it out enough so you can walk through it and/or hunt deer. There are some large hardwoods which I plan to leave alone. They were not cut and are in draws with creeks in them. I'm going to try and go back there tomorrow and I'll take some more pictures. I guess I was off on the height of the pine trees. They may be more like 8-10 feet tall. I'll take some close ups of the base of the trees as well to show the relative size. Everything just came up volunteer on its own after the clear cutting.
On timber that size, it will be tough to see for hunting deer no matter what you do. At least it is fine habitat for deer because there is a lot of food and cover for them.
You wanna believe it. They can't even see you. :D How many times have I spooked a deer or a moose in a thicket, or a bear for that matter? ;D
Did you live, SD? :D
Welcome to the FF gdk771. I reclaimed fields on my property with a { heavy duty} Woods 1100 pound 5' bush hog on the back of a 45hp tractor. I would slowly back thru the trees with the bush hog down and mow them. The tractor does have a cab which made it quieter and safer. Holmes
Quote from: Tom on March 03, 2011, 08:56:23 PM
It will take a hike out of ya. Especially the oratory of an ugly moose, sounds just like a bear. :D That being said, most animals make a hasty retreat from Aliens. :D
SD linked to my thread from earlier, so that's a pretty good idea on what my advice would be. We've been having good success with cutting mechanical rows and then selecting manually with brushcutters. This year we've been able to treat around 35 acres, all natural regen and thick (some stands are pushing 40,000 TPA). The shredder is definitely the way to go in thick stuff, prior to it we used bushhogs and they did a pretty decent job, just left a lot of stubble to deal with for a few years afterwards. On trees of those size, a bushhog would be adequate, some of the stuff we've been working on is a little older and 25ft tall so bushhog wold be struggling :)
Here are a few from the areas that we've done this year...
(https://forestryforum.com/gallery/albums/userpics/14567/2049/IMG_1583.JPG)
(https://forestryforum.com/gallery/albums/userpics/14567/2049/IMG_1584.JPG)
Sure is nice not to have boulders, wet spots, gullies and steep ground. :D :D :D :D
VT_ what is your stems per acre down to now? 1500? That 40,000 per acre is pretty much the same as a good regen count on aspen suckers up in the north. I can see any kind of pine stagnating soon and needs to be pre-commercially thinned with those numbers.
I've never seen aspen that thick, unless it was the first 3 years. We don't thin pure aspen stands, but the thickest I've seen at 10 years was 25,000 /ha not per acre. Hardwood around 25-60,000 st/ha. Fir,red spruce 25-100,000 st/ha (no room for your feet).
If you want to smell something really, really good, Go stand in a freshly thinned plantation of young pines as VTForester has depicted. You won't want to go home. ;D
Should try yellow birch, a mint candy factory. ;D ;)
I haven't had a chance to count the pines per acre yet. I have about 30 acres I would like to clear. I took some more pictures today and have posted them. I'll try to get a count next week. It is pretty thick. Thanks for all the useful advice. I'm really glad I found this forum!
(https://forestryforum.com/gallery/albums/userpics/25085/3332/IMG_9530.JPG)
(https://forestryforum.com/gallery/albums/userpics/25085/3332/IMG_9544.JPG)
(https://forestryforum.com/gallery/albums/userpics/25085/3332/IMG_9542.JPG)
(https://forestryforum.com/gallery/albums/userpics/25085/3332/IMG_9553.JPG)
(https://forestryforum.com/gallery/albums/userpics/25085/3332/IMG_9536.JPG)
That looks about normal for a self seeded cutover to me. It wouldn't be so dadblame thick if it wasn't for the briars, sweetgums and other hardwoods that get a jump on the young pines. A lot of that stuff dies back if the pines ever shade the ground and blanket it with straw.
Even the cutovers that are planted here after a burn will look like that in 5 or 6 years because large companies typically don't go back and do any other controls. Their next control measure is a feller buncher at the first thinning. There is some much self seeding and even at the right time of harvest there are lots of pine seed on the ground ripe for a spring sprout.
Don
Very correct Don. The closed pine canopy is what self prunes the pines and kills the underbrush. If you manually thin too early, the pines will be limby instead of growing tall and producing quality trees, plus you give the the briers and underbrush sunlight which promotes further growth. Some things are better left to nature. It knows best.
I would think that waiting a couple more years and going in with a mulcher would be the most cost effective. After mulching then do the hand work. VT has the right idea with mechanical first.
There still is time for height growth for sure in that natural stand. But, a 12 foot red pine up here is almost 6" on the but. We thin and leave trees tighter up north that is why we go in little sooner. And the hardwood and shrubs that are worrisome are cut, so they are not left unless there is a hole in the canopy. So there is no out growing the leave trees. They will also be weeker in low light and eventually die after a few years. They will not grow from stump and outgrow the softwood as long as the softwood is 10 feet minimum and 6 foot spacing. I find that 6 foot is a little tight though, if looking back after 10 years post thinning. Even though some softwood species have not pruned much by then. Fir and spruce up here will hang onto the lower limbs a lot longer than hardwoods and pine. Limbs will be right to the ground even after 15 years in thicket. You can't even see the ground with a brush saw in hand, impossible. :D
I was reading a book on important wildlife food plants (I think this was for Southern forests), and one of the very best overall native plant for wildlife benefits is the genus Rubus, which is the blackberry family. So all those briar patches and tangles that are so hard to navigate through at this early age of an up-and-coming forest is really steak and potatoes for the birds, bees, and the critters. That makes them a very good thing.
That looks like loblolly and a pretty good stand of it - pre-commercial thinning won't pay for itself with these southern species. If you want to improve growth, find a woods bush hog and do it mechanically, but it won't cash flow for such an operation. Wait, watch, do a cool burn (and I do mean cool since it is loblolly) in the winter to raise the canopy base and thin out some of the excess. That'd do more than anything to start adding some resiliency to your stand
Raspberry and blackberry don't grow under canopy unless it pure aspen in the north. The yards and trails will grow'm though. Our wild raspberry flower most of the summer and will have fruit for a longer stretch than cultivated ones, but the fruit is small, extra sweet and sparse. Birds would be the primary users and bears to. The bears will flatten a raspberry patch. The wild canes can grow over 8 feet tall. They will usually only establish on the bare patches, if there is advanced regen they will not establish much unless it is sparse. I have some wild blackberry on a winter road, but they don't do anything, no berries and are kind of stunted. I guess because the surface was bladed when they scarified in order to get trees into the centre of the block. I had raspberry under my aspen trees after the cut, but they are dying out now because the softwoods, that were planted and regenerated, shade them now.
Rocky, the economics of it isn't all that great here either if you go from thinning to clearcut. The economics is better if a selection is used because you recover more wood over a comparable rotation destined to be clearcut. Different studies show you can get 30-60% more volume from multiple entries in that 80 years. Plus you still have your woods left and can continue making entries a lot sooner. Don't have the extra cost in establishment. Of course this works mainly for long lived shade tolerant species. They are commercial thinning 30-40 year old previously PCT'd softwoods on the better sites. But most of the sites we PCT will be clearcut. What bothers me is low crown royalty rates, then the government pays for the silviculture. I think if the license gets free silviculture of crown they should have to match silviculture on their freehold out of their pockets. The old argument that they could loose their license from reallocation and shuffles doesn't fly any longer. They control it long term now. The only shuffle is when a mill sinks and the land is reallocated to the ones still standing. The same would happen if it were their freehold, they would be taken as assets and sold. This also occurs on crown licenses, a couple licenses were sold during the down turn. They've lobbied the government so hard that you'd wonder how they could fail. :D
Quote from: banksiana on March 04, 2011, 02:36:56 PM
We are shooting for a target of 550 TPA, basically an 8x10 spacing. The shredder makes an average row width of 10ft, so we try and space 8ft down each side. In a perfect world, that's how it goes anyway :) Some of these areas are a little thicker than that, probably anywhere from 600-750 TPA....still a world of difference better than 25,000+.
Unfortunately, because our property is so close to homes/roads/airports, we can't really use fire as a tool to manage our loblolly. If we could, we'd really cut down a lot on our hand work. Shred and burn would be enough to free these trees up, but with burning off the table, I'm running a brushcutter from January to late March (we quit cutting before fusiform rust "blooms" to lessen our exposure to infection). I still might push for a limited small-scale burn to see how it works and just how smokey it gets. I have a feeling if I smoke out an international airport or the Yorktown Naval Weapons Station I might be in some trouble :)
Yes, you would have to run and hide if the smoke did not cover you up ;D.
Quote from: WDH on March 10, 2011, 07:33:53 PM
In school the professors called that a CLM - a Career Limiting Move :D
I have several of those pending currently (CLM's) :D
