General Forestry => Ask The Forester => Topic started by: Michigan on January 03, 2004, 09:04:57 AM
Title: Tree dbh
Post by: Michigan on January 03, 2004, 09:04:57 AM
 Would like to know your thoughts on how to mark a reference point for a tree's dbh. Would like something that would last as long as possible. Thought of paint, nail, and ribbon. Paint would last for? Ribbon would have to be replaced yearly? Nail if aluminum damage to value of tree? Any thoughts on how its done, thanks much
        Dan
Title: Re: Tree dbh
Post by: Texas Ranger on January 03, 2004, 11:04:32 AM
You got most of 'em.  You can scribe the bark, NOT into the cambium, but just in the corticle tissue and it will last for years.  Bark scribes available through the forestry supply houses.  But the height stays the same, just make sure you use a standard 4 and half foot height.
Title: Re: Tree dbh
Post by: Stephen_Wiley on January 03, 2004, 11:31:22 AM
Dan,
Welcome to the forum,  many of us lingered before posting.  Found this place to be like family, full of lots of information, humor and caring.
As Don has already mentioned dbh is measured consistently at four and half feet from ground level ( because fluctuation in ground level can be different always measure from highest exposed area).
Be careful in using the bark method of scribing if your trees have thin bark. Also try to avoid 'nailing' as it will create a wound to which pathogens can gain access.
Are you going to measure yearly? How many trees or acres of woods? What species? Are you concerned about asthetics of markings?
Title: Re: Tree dbh
Post by: rebocardo on January 03, 2004, 03:05:22 PM
I think bright spray paint on the west side of a tree would last a pretty long time. I painted some trees to mark a trail and it lasted a few years.
Title: Re: Tree dbh
Post by: Ron Scott on January 03, 2004, 03:08:38 PM
I'd recommend tree marking paint; use one of the tree marking paints such as Nelson's for longer lasting and visibility.
Title: Re: Tree dbh
Post by: Jeff on January 03, 2004, 04:55:04 PM
Maybe I don't understand, but my question would be, why mark the DBH on the tree? Mark it on you. That way it will be on every tree you walk up to.
Title: Re: Tree dbh
Post by: Texas Ranger on January 03, 2004, 09:15:14 PM
As my youngest says, "Well, duh!"  Diameter BREAST High. 8)
I had a lady tally man one time that made taking measurements,,,,,,,,,,,,, no, wait, for another time and another category. ;D
Title: Re: Tree dbh
Post by: Bro. Noble on January 04, 2004, 03:54:40 AM
I think that  painting a 'dbh' mark on ones self is a brillient idea Jeff 8)
That would make a good game for the pig roast-------paint the dbh on the 'Big Guy' :D :D
Title: Re: Tree dbh
Post by: Jeff on January 04, 2004, 07:49:44 AM
How about guess the DBH of the big guy. Course when this bunch gets together its gunna take some doing to figure out who that is.
Honestly though, why would you mark the DBH on the tree?
Title: Re: Tree dbh
Post by: Ron Scott on January 04, 2004, 08:09:45 AM
So that the diameter measurement is taken in the exact same place every year or whenever by whoever takes it for record keeping over time.
Always measure from the highest side of the tree.
Title: Re: Tree dbh
Post by: Stephen_Wiley on January 04, 2004, 09:26:53 AM
Post change,
If anyone read my post prior to today (1/4/04) I have made a very important change.
Note in my above post previously I had typed .........'lowest exposure'  Must of been brain fog as I meant the highest. It is now changed and I apologize if this has brought any confusion to anyone.  :-[
Title: Re: Tree dbh
Post by: Stephen_Wiley on January 04, 2004, 09:31:51 AM
Also if you are measuring a tree such as a Hemlock with unusual trunk flare, measurement should be taken from the line of demarcation above abnormality.
Title: Re: Tree dbh
Post by: Jeff on January 04, 2004, 10:11:29 AM
QuoteSo that the diameter measurement is taken in the exact same place every year or whenever by whoever takes it for record keeping over time.
So would it not be better to mark 4.5 feet on your person versus 10 gazillion trees?
Title: Re: Tree dbh
Post by: Bro. Noble on January 04, 2004, 12:17:10 PM
I think the object would be to identify the tree with a number so that the dbh could be compared in the future.
Besides a person's dbh can change both in the diameter and height deminsions :D
Title: Re: Tree dbh
Post by: Jeff on January 04, 2004, 12:30:59 PM
It wouldn't change anymore then a tree's. Besides I would think you could remeasure your dbh pretty easy. Now my diameter east and west varies quite a bit. ;D
Title: Re: Tree dbh
Post by: Tom on January 04, 2004, 05:44:39 PM
It's been recommended to tie a flag on the rental boat that took you to the fish so you can get it next time. :)   If it works for fishing, perhaps it would work for trees too.  My only concern would be the hill that forms under a tree as the roots grow.   If you mark yourself then you might be standing on higher ground next year.
I wonder if it would work it you drove a piece of PVC pipe into the ground next to the tree such that the pipe was 4.5 feet on the trunk? You could even stick a pice of paper inside with some information on it for next time  ....... like. ......."kilroy was here" :D
Title: Re: Tree dbh
Post by: Jeff on January 04, 2004, 05:47:28 PM
I guess what I am getting at is that I dont like to see paint marks on every tree in the woods. I certainly dont want to see nails and I'm not sure how I would take a peice of PVC next to them. :D
Title: Re: Tree dbh
Post by: Minnesota_boy on January 04, 2004, 05:55:17 PM
Just run that PVC pipe through the mill like you would any othe hollow log.   :D
Title: Re: Tree dbh
Post by: UNCLEBUCK on January 04, 2004, 09:43:29 PM
so what is the defenition of dbh ,  diameter ---------  height , I dont know what the initials mean but I like checkin out trees in the woods .  :P
Title: Re: Tree dbh
Post by: beenthere on January 04, 2004, 10:02:28 PM
Unclebuck         dbh ---  diameter breast height
Title: Re: Tree dbh
Post by: UNCLEBUCK on January 05, 2004, 10:52:21 AM
ok thanks beenthere !  I kind of thought that but just wanted to be sure . :P
Title: Re: Tree dbh
Post by: etat on January 05, 2004, 03:06:43 PM
Uncle Buck, thanks for askin the question, I been fryin my brain off and on all day trin to figger out what dbh meant.
Title: Re: Tree dbh
Post by: Stephen_Wiley on January 05, 2004, 07:20:31 PM
Uncle Buck and cktate,
d.b.h. = diameter at breast height or 4.5 feet from ground level at the highest exposed ground.
Exceptions:  trees with multi stem trunks, double leader below 4.5' feet, trees with excessive trunk flare are measured differently for log volume purposes.
Other abbreviations you will sometimes see are:
d.b.h./o.b.  =  diameter at breast height / outside bark
d.b.h./ i.b.  =  diameter at breast height / inside bark
depending upon purpose of tree survey or cruise it is important to note the difference.
Although not used much occaisonaly d.g.l. will be used in conjuction with d.b.h.    d.g.l. = diameter at ground level
Title: Re: Tree dbh
Post by: OneWithWood on January 06, 2004, 06:48:35 AM
I would think for the majority of trees there would not be a significant variance in dbh if it was taken at 4', 4.5', or 5'.  So marking the exact spot on a tree would be an unnecessary task.  It would be more important, IMO, to be sure and take the measurement from the same orientation each time to eliminate irregularities.  Of course that would not apply if you were to use a diameter tape instead of a stick.
Title: Re: Tree dbh
Post by: Ron Wenrich on January 06, 2004, 02:32:14 PM
Consistency is the secret to any cruising.  You must be consistent where you measure your dbh.  If you measure one tree at 4' and the next at 5', you can start knocking trees into different size classes.  Enough guys already seem to stretch a diameter tape too much.   :D
Getting a few trees into different size classes isn't too big a deal when using variable plots.  But, for that 100% sample, you can start to gain or lose footage.
I hate to see anyone use a stick for measuring trees that require any type of accuracy.  My first job as a forester was to go out and see why a consultant overscaled by 10%.  He used a stick and was off from 1 to 2 diameter classes on some of his calls.  Not acceptable.
He also had poor scaling and measuring techniques.  He measure mid-slope instead of high side.  It was one of his first jobs.  He cleaned up his scaling and is still in business 25 years later.
Title: Re: Tree dbh
Post by: OneWithWood on January 07, 2004, 07:50:06 AM
Guess I better work on that consistancy thang. ;)
Thanks for the advice Ron.  I stand a whopping 5'6", 5'7" on a tall day :D  So if I consistantly measure the tree on the high side where I touch it with my arm held at a 90degree angle I should get the consistancy should I not?
Sure am glad you more experienced guys are willing to share your knowledge with us more novice types. :)
Title: Re: Tree dbh
Post by: whitepe on January 07, 2004, 01:33:46 PM
What is the dbh of the pig that's going to be roasted
on Aug. 7th 2004?
Title: Re: Tree dbh
Post by: OneWithWood on January 08, 2004, 06:03:07 AM
Whitpe, I don't think that can be ascertained until August 5th. :D
Title: Re: Tree dbh
Post by: Joe_Beaulieu on January 08, 2004, 02:31:00 PM
I have worked with several woodlot owners that practiced fairly intensive management techniques.  Marking certain crop trees at dbh with a reference mark (painted line) and a number(more paint) allowed them to closely monitor growth rates.  See Independent Sawmill & Woodlot Management, Oct/Nov. 2000 issue, p.40 for article on crop tree management.
Title: Re: Tree dbh
Post by: Ron Wenrich on January 08, 2004, 04:54:46 PM
Most of the landowners around here have the crop trees marked and then cut.  That leaves all that inferior crap to take over the next stand.  Diameter limit cuts are also popular.
Title: Re: Tree dbh
Post by: Kirk_Allen on January 19, 2004, 07:31:13 PM
Jeff,
I agree with you.  I dint care to see paint on every tree in the woods either.
I can remember 10 years ago at my grandfathers farm on a sunny afternoon a stranger drives down the 1/4 mile lane to the farm house. (one way in- one way out)
We were on the front porch eating lunch and this guy gets out and proceeds to tell us that he just finished inspecting the timber on Grandpas west farm and had marked them so he could take a look and see which trees this guy wanted to buy.
Now you have to understand my grandfather.  He was a true Conservative in every aspect accept his trees.  Those were his trees and no one, and I mean no one was going to touch them let alone paint them.  That included family!
If you can imagine a 95 year old man grabbing a ball bat from the back porch and chasing this guy off the property you will only get half the picture.  This guy was lucky to get out of there with his life.
Grandpa did manage to take out two headlights as the guy was backing out.  If he would have had his shotgun loaded in the garage he would have shot the guy.
I must say I was shocked to walk through the woods that afternoon.  Every tree over 10" was marked with brilliant orange paint and on some of them its still visible.
I think the next morning at the coffee shop an APB was put out on this guy.  Every farmer in wanted a piece of this guy.  Not so much for painting the trees as for having the nerve to trespass and think nothing of it.
Oh well, I know its kind of off topic but it brought back some memories.
Title: Re: Tree dbh
Post by: L. Wakefield on January 20, 2004, 07:03:32 AM
   Oh, is that conservative? It is a perfect description of how I am and I've always been told I am paranoid and a total control freak  :D :D :D- I'l just tell them I'm a mite *conservative*.
   I know how the old gent felt, and I applaud his courage in letting his feelings be known.  lw
Title: Re: Tree dbh
Post by: Ron Scott on January 20, 2004, 09:55:32 AM
Many of my clients are upset timber landowner's whereby soliciting timber buyers have gone on the private property and marked trees without asking the landowner in advance  for permission to do so.
Some quality stands have been marked with so many different colors by soliciting timber buyers that it sometimes becomes hard to find a color left to use when the landowner does give permission to do so.
Such paint markings without the landowner's permission often encourages the landowner's to seek out a consulting forester for advice on what's going on with paint marked trees showing up on their timber land.
I never mark any trees without prior written permission of the landowner to do so. This includes the permission of all who own the property, including the wife. To do otherwise without the landowner's permission is trespassing.
Title: Re: Tree dbh
Post by: Ron Wenrich on January 20, 2004, 04:51:04 PM
I worked many years as a procurement forester.  Never, did I mark a tree without permission.  You don't need to mark trees to get an estimate of volume or value unless you don't know what you're doing.
With experience, you can get a feel, just by walking through the woods.  But, I liked to do a quick cruse before talking to the landowner.  I would even write a quick management plan, if I thought it was a selling point.  Most landowners didn't object to walking through the woodlot or even taking a cruise.  They would enjoy finding things out about their woodlot.  Sometimes you bought the timber, most times you didn't.
Only once was I threatened with the cops.  A really old lady who didn't take to kindly to someone looking at her trees.  I told her if she wanted to call the cops, I would wait 'til they came.
Title: Re: Tree dbh
Post by: Jeff on January 20, 2004, 05:01:43 PM
If I had a woodlot and caught someone painting my trees or even cruising them without my prior permission, he would be begging me to call the cops, that is if he could still talk. I should say she also. I hear tell there are more and more female timber buyers out there. The one I know from this county gets the bad word from me to who ever asks. I found her at a harwood timber workshop a couple years back put on here in Harrison by MSU extention. She was there simply to see who showed up and potentialy spew her line of bull.
Title: Re: Tree dbh
Post by: SwampDonkey on January 25, 2004, 07:30:26 PM
 ;D Here's my perspective  ;D
When working on the west coast of BC we did alot of timber cruising on Crown Lands for Lisence holders (those with cutting rights). BC has a timber cruising manual for crown lands which they are quite strict on and 3 major things that have to be followed per plot. They include cutting a plot centre stake tall enough to be at least dbh height when anchored in the ground, marking a reference tree below stump height (30 cm) which had bearing and distance to plot centre and plot number, and mark all dbh lines with paint after loose bark and moss has been removed on high side of the tree. DBH was always measured from point of germination. Also, trees where numbered clockwise from the direction you entered the plot along the measured stripline :) That was the easy part, now do all the pathology, quality and tree heights :) A plot typically took 45 minutes that had 6 or 8 trees to measure. Six plots a day was average and 8 was real good. More than 1 missed tree (in or out) found by the auditors from the MOF and it was a complete redo.
Anyhow, the painted dbh line was used for cruising audits by MOF staff and the reference tree was also for audits if there was ever any major dispute on the scale at the dry land sort. They could measure stump diameters and use treelength volume tables or the localized yield curves.
Never had to redo any of my work, but I did lots of other people's work over that got frustrated and quit  :) Well when you think of it, 1 missed Sitka spruce with 2.5 meter dbh and 70 m height represent alot of match sticks per ha :)
Here's the cruiser's manual:
http://www.for.gov.bc.ca/hva/manuals/cruising
They are currently working with the Assoc of BC Prof Foresters to get recognition for credited timber cruisers who have demonstrated their competance in cruising. There is an apprenticeship of sorts or depends on individual experience to become certified, and a peer review process. Member since 1996.
regards
Jeff, don't shoot me when I come a cruising your back woods ;)
Title: Re: Tree dbh
Post by: OneWithWood on January 26, 2004, 05:28:40 AM
Occasionally I will get a call from a logging outfit wanting to know if I would like to sell some of my trees.  They always seem to know what is in my woods.  I always decline.  I don't wish to do business with someone who cruises my property without first contacting me.  I believe it is only common courtesy to ask permision before stepping onto provate ground.  If anyone was ever so bold as to mark the trees before talking to me you can bet I will have them in court for malicious tresspass.
Title: Re: Tree dbh
Post by: SwampDonkey on January 26, 2004, 06:08:24 AM
hmmmm
I can' figure out why someone would be on your folk's property before asking you first. Who is paying them to go there and mark the trees? Are they cutting timber on your neighbors and taking time to scout properties bordering their operations? If so, they still should be asking first. Almost looks to me there are a few fly by night veneer buyers looking to get a sweet deal high grading your woodlots.
visit your woodlots often guys
Title: Re: Tree dbh
Post by: Frickman on January 26, 2004, 01:33:47 PM
Just to put in my 2 cents worth, I never go onto a property without the landowners permission, to do otherwise is trespassing, as mentioned above. On every piece of timber we cut we try to notify the neighbors of our planned activity, sometimes you even get some more timber by doing so. Even if I see the neighboring property owner outside I will walk around and up their driveway rather than down through their woods. The worst way to start out a potential business relationship is to go around trespassing and getting the landowners mad at you.
Title: Re: Tree dbh
Post by: SwampDonkey on February 11, 2004, 02:52:30 PM
Its important to note that dbh at 4.5 feet (1.3 meters) is the standard used to construct those standard yield curves (volume tables) used to determine stand basal area, density and volume. These standard yield curves are constructed by measuring a sample of trees for each species or species grouping which are representative of the forest land in your state, region or district. There are curves generated for any number of site indices (typically tree height @ age 50). Some jurisdictions use software programs to generate localized volume tables specific to the stand they cruise in, based on measured and estimated heights and diameters in the stand.
You can localize a standard volume table in the following way:
1)measure heights and dbh by species in the area for which the volumes will apply
2)prepare a curve of height over dbh by freehand method
3)read average heights from the curve for each dbh class (2-inch or cm)
4)interpolate from the standard volume table the volume of the tree of average height for each dbh class (or use the standard vol equation with the interpreted average tree height per dbh-class from above)
(https://forestryforum.com/images/04_01_03/localVol.jpg)
Steps 1-3 is represented by the first curve (freehand curve from sampled tree data in the woods), step 4 is the standard Vol equation with values interpreted from curve 1 to create curve 2. Big D is diameter and big H is height.
And you didn't think algebra was of any use way back in grade 8? ;)
Now all you need is tree diameters in that local area your working, to get volumes in future cruises.
I only do this for tresspass cuts, where I only have stumps on site, but I can measure neighboring stands to generate the localized volume tables. You can also use treelength tables. I have found that the relationship between stump height diameter and dbh is a straight line at 45 degrees with R^2 = ~ 0.95 for species in my area (Y=a+bX; a= y-intercept, b=slope). In regression statistics, the closer the line is to an R^2 =1, the better the fit ;)
Anyway that's enough statistics this round. ;)
