I have located a Mobile Dimensions mill for sale not far from here. I'm trying to arrange a meeting with the owner, and I need to know what I should be looking for.
Are there any weak points that would make it a bad deal? The mill is a 1986 model, but has had very light usage for the last 7 years. The head is under a shed, but most of the trailer, etc, is out in the weather, and has what appears to be surface rust.
The owner says the 67hp VW engine runs good, and all functions are working ok, as of last week.
Reason for sale is the demise of his construction business, so the mill is no longer needed. The price is reduced from $13,500 to $9000.
What do y'all think?
Dan. one on that level today would run you approx. $24,000, + or - a bit. Have him demonstrate it for you. I would also have the main blade checke for hairline cracks, not that, that is or has been a problem I have ever heard of, but it would be 7 or 8 hundred for a new one. :'( I would also check the dipstick. He probably has changed the oil to sell it but never the less. Check the shanks to see if there is much wear. You can do that by seeing if there is any shine to them. That could be difficult. Check the belts. If it has been setting for some time, they are probably low in quality. You will have to buy them from the Factory, as they are not available that I have vever found anywhere else. Each set needs to have come from the same cutt in the material and all stretched at the same time in production. The over all price sounds very good. If he has come down from $13,000, that is not to far off from what he most likely paid of it. My first one was 15gs and it is 11 years old.
I'd go along with what Frank said, also check the hoses for wear or rot. Check the corners of the teeth. If they are rounded, it may have been run that way for awhile which can overheat the blades. When he makes a cut, and the carriage returns, have him shut down the saw and feel the main blade. It should NOT be hot. If it is, the teeth need sharpening or replacing, and if it has been run that way for a long time, the main blade could have heat-warped. Look at the surface of the board for uniformity in the cut marks. If the leading or trailing edge has a big difference, it most likely is just an adjustment, see if he can make it. I wouldn't worry about the surface rust, mine has it, as the canopy is only over the head. If the carriage doesn't return (have him run it back and forth several times), you may need new springs on the track, no big deal. A little oil at the return stop area will work, too. If the board has taper, you should be able to adjust it quickly by pushing the round knob at the end of the tie-rod to disconnect from the tail end, then crank the head end over, and pull the knob back so the tie-rod re-connects.
Make sure he has a tooth-removal tool and shows you how to use it. (Be careful here-loosen the engine tightening bolt so turning the blade doesn't crank the motor, or it could start).
The price sounds pretty good to me, mine is about the same age, and was about 14K. It will seem complicated at first, but when you see it work for awhile, it's so simple!! Check the carriage bearings also (which ride the track). They should be well lubricated. Some track bounce is normal going through the log, but can be minimized by cranking down the small wheel which rides on top of the log, which is located near the blade guard, Make sure that the blade guard retracts when the carriage returns. Good Luck and Merry Christmas!!
Thanks, Timber Beast I had to get goining yesterday as a customer came for a lumber pick up. Anyway you continued well into the issues I had in mind that needed to be covered. I would encourage yoou to seriously consider buying this machine. Even though I have two I would buy tht unit myself if it were closer to me to examine. I have a son who is a Missionary in Haiti and would love to have this mill for his working with the Haitiains. He is teachin them how to fish rather than giving them the fish. His whole idea is to teach them how to replant by starting a nursery for the seedlings and onto the planting and maintainance of a newely planted forest. The sawmill is to teach them to process what trees are left and market the lumber as well as teaching them to use it in their homes he is teaching them to build for such things as doors, window frames, furniture, all the way to art work pieces from turnings to carvings. He has his work cut out for him, that is for sure. :D
Thanks, guys. I don't know when I'll be able to go look at the mill. The only time I seem to have is tomorrow, but I can't contact the man. :-(
If the blade has been overheated, would I be able to see the discoloration? Is any degree of discoloration normal on these?
I have a friend with one of these mills, and he says that the only maintenence problem has been the bearings, but that they weren't any big deal to replace. What's been your experience with this? He's had his since the late 70's, sawing part-time, so he has plenty of experience. I may try to get him to go with me, if I can pull him out of the woods during hunting season.
Frank, you can bet your son has his work cut out. I did a little one-week mission thing in Haiti, in the early eighties. We helped build a church/school building in Les Cayes. I saw a sawmill, there, that used a hand-operated Whipsaw. The log was on a raised platform, with one guy above it, and one below. The saw looked like an old, two man crosscut saw with ripper teeth. You gotta really want a board BAD to be sawing lumber that way!
Congratulations to your son for being there. It is a very worthwhile endeavor. I found the Haitian people to be warm and friendly, and very grateful for any help. There were some touching moments during our stay. One of them came as we were putting the finishing touches on some church furnishings that were intended for another church. We had the kneeling rails set aside while we finished up the pulpit. We heard some noise behind us when our generator ran out of gas. We turned to see a number of church members trying out "their" new prayer facilities. We didn't have the heart to take them to the other church, after that, so we took up a collection from the team, and went to town for more materials to do it all again. That was the best vacation I ever had.
Look like fun?
(https://forestryforum.com/images/YaBBImages/userpics/2man2.jpg)
Ahrgh, Jeff!! A pitsaw without a pit?
Dan, the only discoloration on my blades is from pitch from the last log I cut (wet Spruce), as I check and sharpen the teeth often. Haven't had any bearing problems, either, all the bearings have a zerk of some fashion, and I keep them lubed, but if you overlube them, they'll run hot for awhile. Haven't replaced any. Maybe someone else can tell you what to look for as far as blade discoloration, I keep my inserts sharp enough so the blades always run cool. :)
Let me ask a question to the experts. What advantage does a Mobile Dimensions mill have over a band mill? Or for that matter what disadvantages does it have as well?
Thanks in advance for any input
Gordon
Dan, you can sometimes tell by spots or blueing in a circular streak fahshion. I have had to have mine hammered twice in 10 years dus to haveing hit 3" porcelan insolators, bofore I got my metal detector from Rens in Creswell, Oregon. Yes, he does Dan. Thank you for sharing your experience with me. I will let him know. He is here fro the 10th of Dec. to about the 10th of Jan. He and his wife have made a 3 year commitment to the task. Challenge is an understatement for them both. He is having to learn to speak Creole. :P :-[
Gordon, I'm not an expert, but I play one on TV. ;-)
The pros of the MD, as far as I can tell, are, speed, the fact that you don't have to move the log, once you dog it, and the fact that you produce either one or two complete boards with every pass of the saw. The edgers are built into the saw head.
The cons, as I see it involve the lack of flexibility. You are limited to cutting a certain size beam, though it is still a pretty good sized board. I'm sure Frank & TB will correct me if I'm wrong, but I think 12-14 inches is about max. The large size edgers will handle about 6 inches. Flitches are out the window, unless the log is small.
I think the ideal, small operator should have 1 band mill, and one MD mill.
Howze dat for an "expert" answer? ;-)
Dan's pretty much right on. Dog it and cut it. No turning involved. On a bigger log, you can make the slab cut on the side, cut across the top, then lower the whole unit and make two complete boards with each pass, and it has enough power that you can make that pass on an 8-footer in about 10 seconds. If you have, say, about a 7" diameter "log", you can cut the edge slab, then move to the side and in the next pass, have a 4x4 with the heart boxed. Two passes. There is one vertical blade and two horizontals. My max is 12" wide by 4" thick. But I can handle a log up to 48", by raising the whole unit and moving it down as far as I want with each pass, could make all 2x4's or a mix of 1x12's, 2x4's, 2x6's or whatever. A 36" log will usually take about 15 minutes to finish, if I know what I wany beforehand. Another advantage, no broken blades, no water needed spraying on the blade. Disadvantage, no big timbers, as far as I know, 6" (with bigger edgers than I have) is max. thickness. Quarter-sawing is only what you get from the areas of the log that are lined up to come off as quarter sawn, main blade kerf is 5/16 and edgers are 1/4. Can't mill a 3-side cabin log (at least that I've figured out). Always a trade-off somewhere. Fast and reliable, though. I've gone down to 1/16 thickness without a hitch (just to experiment).
Also, on logs say 13" and up, after the first slab, the mill brings the board and slab back to the operator, pretty convenient if you work alone. 1750cc Volks engine will run all day without a burp, too.
Timber Beast, you can mill a board up to an 8 x 12 by adapting the bottom edger blade. You remove the 8" blade and replace it with the 16" blade. You then move the larger, main blade out four inches as well as the shroud. You then take the top off of a log, makeing a flat surface. Then drop down the distance you want to go for the width of your timber. Take the slab off, and move into the log for your thickness. I this way you can produce a timber up an 8 x 12. This is the fastest way I have found to be able to cut RR ties or other large timbers. I can also roll the log and taske one side at a time, producing a finished timber. with four passes or so.
I've never seen a Mobile Dimension saw run, but I have seen pictures. I don't really see much of a problem with the board width. In many cases with hardwoods, those wide boards are ripped down and glued into panels. I've been told its more stable.
The only question I have is how well it will do in hardwoods.
Grade hardwoods are sold by random width and by the linear foot from 4-16'. To get your best grade yield, you have to turn the log. Do you think that you sacrifice some grade by live sawing?
Ron, yeah, I think there is a sacrifice in the grade, if you don't turn. As Frank stated, you CAN turn it if you want to, but that negates the speed. Personally, I have found that hardwood is easier to saw than cedar or spruce, probably because it's less fibrous, as all I saw in hardwoods is maple, birch (white and yellow), and occasionally black ash or poplar (hardwood, yes, but hard?). Aside from the popple, the woods are quite stable and dry nicely in the air. Popple can be a pain. Most of the hardwood I saw I use myself or sell to niche markets, woodworkers who want birdseye or spalted stuff. Small quantities. Have sawed some Black Cherry, and it was a pure pleasure. Easy sawing, easy drying, easy selling, pretty stuff.
Frank, I am familiar, in the written word, about the method you described for bigger timbers, but I don't have a market for them. I built a deck on my logging shack just by slabbing one side and using the flat on top, left the rest round, for the joists, and yes, I peeled them. It will outlive my kids.
Found a guy who is interested in soft maple, with flame figure, 16-20" lengths, in the round, waxed on the ends, for building violins. Says he gives them a minimum of 15 years drying time, can't be sawn, has to be hewn after drying. I have some huge soft maples, but don't know if they have flame. Anyone know how to tell? Sounds like he'll pay a small fortune!
Timber Beast, the best way I have found is the remove the bark and see if there are ripples moving in a horixontal direction from the normal growing direction of the tree. this is the only method that i know of, other than cutting the log. You might also try splitting or cutting a chunk with the chainsaw that comes just before or after the piece you are trying to save. Fifteen years is a long time to wait to see the figure of a piece of wood. I do not know if I "wood" have the patience for that kind of wait. :D Perhaps there are some other ideas out there about this issue?
I've never heard of anyone using soft maple for instruments. Most of them use hard maple. The more flame the better. When they are dry, the maple will actually ring, so I'm told.
Ripples under the bark is a good method of determining curl. Of the little bit of curl I've run into, it usually had a rippled appearance. It wasn't as evident in the other species.
I recently saw a couple of dobros for sale. One was made of birch and another was made of curly oak. I'm not sold on the resonance value of the oak.
Other species used in acoustical instruments include spruce, rosewood and mahogany. Ash is used in electric guitars, as well as some off-the-wall woods in those cheaper products.
Ron, I am somewhat familiar with instrument making, as I have played guitar since I could hold one, but this guy says soft maple generally has a better flame these days, so maybe he's going for eye-candy. We used to call it "tiger-stripe". Ya fergot Mahogany! Most acoustic guitar sides are mahogany, sound boards usually spruce, most sought-after comes from Alaska. Necks on acoustics and electrics (top quality) are almost always mahogany or maple, with maple the choice for Fender in general, and mahogany for Gibson. The Gibson Les Paul Standard. Is a mahogany neck, ebony fingerboard, mahogany body, with a carved, laminated top of hard maple. The models from the late 1950's were of particularly nice figure, that coupled with the first PAF humbucking pickups make them fervently sought collector's pieces, some going into the 5-digit range!! Fender generally used ash for its bodies, but many examples of alder bodies exist. Once again, the models from the 50's shine, as they must have been made from one exceptional ash log. The ash is extremely heavy, adding to sustain and clarity. True of both Telecasters and Stratocasters. There are also some with solid maple bodies. The Gibson Les Paul TV models and Junior models were solid, uncarved mahogany bodies, but I did once see a Junior with a solid maple body, and I know that Keith Richards has a TV model with a solid maple body, which was the guitar used on the original recording of "Honky-Tonk Women". Collectors or sellers beware: with the price that some instruments are going for, if you find a 1959 Les Paul in good condition, it's about a 50% chance that it's a forgery, and no matter how well built, is useless as a collector's piece!
Hey TB,
I have a Gibson LP standard 1982. I paid $ 325 for it in 1985. It's 100 % original and weighs exactly a ton.
It just sits most of the time though because I much prefer the playability and sound of my American Standard Strat, 2000.
Stickbilt
I've been playing in bands for 35 years. Some good, some bad. I have a friend who made a lot of money buying those old guitars. He had one of those old Les Pauls, I believe it was a 1957. He told me the value was $32,000.
Paul Reed Smith is making electric guitars with outrageous flame. This same guy had the 2nd guitar Paul made. He traded that one for cash and a new PRS guitar.
If you want to see some really nice electric guitars, try this site: http://www.prsguitars.com/ Go back to their private stock sale. Really nice instruments. Some of these go for 5 digits, new.
I noticed that he used one piece red maple for some double necked guitars. He also has some models using swamp ash, basswood, and big leaf maple. Your violin making friend should find Smith's source. ;)
I've played guitar, a little banjo and mainly pedal steel, here of late. I'm thinking of going the dobro route, next. The pedal steels use a lot of birdseye maple.
Martin guitar is about 75 miles to the east of me. I had a chance to go through both their guitar plant, and their sawmill. It is supposed to be the most accurate mill in the States. Their Sitka spruce came from British Columbia, rosewood came from India, and I can't recall where the mahogany came from. I believe it was from Central America.
DanG's proposed mill
(https://forestryforum.com/images/YaBBImages/userpics/mobile%20dimension3jpg.jpg)
(https://forestryforum.com/images/YaBBImages/userpics/mobile%20dimension2jpg.jpg)
Dang!!!!!!!!!!!!!! I thought I was looking at my mill for a second!! Mine is set up the same way, 'cept it's surrounded with sawdust, and the one in the picture here looks older. My roof is even the same. 'cept I have an I-beam with a chainhoist to make engine/carriage removal easier.
Stickbuilt, that LP should easily fetch around 800 bucks.
I prefer them to Strats because of the neck angle, plus I'm pretty much just a "rythmn chunker".
Ron, PRS sure does make some pretty guitars, same scale length as the Les Paul, which is why so many players seem to switch to them from Pauls. Also, I think they must pay a pretty good promotional rate to "famous" folks who play them, I've seen a lot of guys switch to them shortly after having a top-twenty song. Nice stuff, indeed!
BTW, a few employees leased the Gibson plant in Kalamazoo after Gibson moved all production to Nashville. They make "Heritage" guitars, which are built with the same jigs and machines that the Les Pauls were made with. Doesn't have the prestige of saying "Gibson" on the headstock, but they the same thing, with a bit more hand-work. Interesting about the Martin place! (always wanted one!), I had a catalogue from them at one time, where you could order instrument wood from their mill. Wonder if they still do that?
I see that he has made some modifications to the mill. He enlarged the fuel container by at least 3 times. and added some sort of a shroud. My concern for this is the additional weight placed on the unit on that side and front of the power unit. I would think it would make a difference somehow. but I am not an engineer. But on thinking about this, I too have an additional weight out front on one of my units, the newest. It is the water cooler for the thinner curfed blade. It hold about 5 gallons, so that is approximately 35 more pounds out front, but factory installed and engineered, is the only difference. ::)
Frank, you use water to cool the thin blade on your mill?
Thought that was only needed on a band mill. Please tell me more about it.
What is the verdict on the mill for Dan? Looks like it's got some surface rust. But humid/wet is Flordia isn't it. It's hard to tell by the pics about the most important part the power head. Nice set up with the concrete pilliars. Don't have to worry about those nice Flordia bugs. >:(
Gordon
The mfg. has gone to a thinner curf balde for the main blade. The original was/is 5/16th whereas the nother is 1/4" curf. With the thinner blade there is the need to keep it cooler. I have one of each. When you puirchase the units you have a choice of water or no water. I just happened to acquire a prototype mill with all kinds of bells and whistles, even a trailer with "gobs of hydraulic toys attatched, of which they are not making such a mill. It is a real joy to work such a toy.
Well, the big day is coming! 8) I have an appointment on Jan 1 to look at the mill. If I don't find any obvious problems, I will probably buy it. I would think that checking the engine would be about like looking at a used car. I'll also check out whatever bearings for any slop, cables for fraying and obvious wear, and, most importantly, the frame for any damage or heavy rust.
Then will come the interesting part. ::) Neither I, nor the owner has ever operated a mill of this type. He had(that's PAST tense, folks) an employee that ran it for him. He knows how to "crank it up and run it back and forth", but has never actually sawn with it. :o I'll ask Miz DanG if she ever ran one :D :D Anyway, we've both "seen it done", and he's got a couple of small logs we can play with, so I should be able to tell if everything works ok. I have a buddy who can teach me the fine points, if I buy it.
If you don't ever hear from me again, it'll mean that things didn't go too well. :o :o
Make sure is is oil in it before you start. May even want to change it before you run it. Check for slop in bolted areas also. If we do not hear from thee we will know that the shrapnel got you from the teeth and the motor :D Serious though, Dan, STAND AT THE OPERATORS END ONLY. DO NOT ATTEMPT TO STAND ANYWHERE ELSE! Make sure you check the belts for frayed edges or weather checked before starting, also. You might want to wirebrush the track, both sides and bush a bit id diesel on both before running or in conjunction with wirebrushing. The best of luck to you both. What you might do is offter him 8gs after the running and see what happens. Just a thought. See, too, if batteries are included. You would have to add additional expense there of about $250.00 for good deep cycle batteries. ::)
Frank
I've been running 1/4" circle blades for 20 years and have never put any type of coolant on them.
One thing on the bigger blades is that we put a little lead into the saw. The cutting edge is about 1/16" ahead of the back edge. That way you aren't rubbing the eye with the log and you get no heat. Any way to put lead into your saw? Should be some type of adjustment.
Ron, I just called the factory in Troutdale, Oregon, to cover my bases on the sizes of the two blades they offer. The smaller of the two is 150/1000 for the 1/4 teeth and the larger is 165/1000 for the 5/16 teeth. So, with the 1/4 tooth unit, the idea is that there is less space between the corners of the teeth and the blade itself and generates more heat, erg to h2o is added. I hope this makes sense to you. If not try me again and I will see if I can reallign get things messed up. :D :D
Ron, you can see the edger blades directly below the (oversize) gas tank, looks like they are set at 5 or 6 inches. The main (vertical) blade is where you think it is, you can see the (discolored) main shaft protruding from the blade guard. The top horizontal moves up and down, the bottom is fixed, and is the lowest cut you can make. Should give you an idea of how it works. Not sure about lead, I've never had a heat problem. My horizontals have 1/4" teeth, my vertical 5/16. The manual that I have does not mention any kind of coolant, have never used it. The lower horizontal has an adjustment for angle, so that you can set the blade for tooth/blade clearance. The vertical can be adjusted for angle as well, but I haven't had to do it with mine. It ain't broke, so I ain't fixing it.
I can see one of the horizontal blades behind the cover. So, you are running basically a circle saw with a top saw, and a vertical edger.
I remember helping a guy with a double end trimmer. He couldn't get it to work without the saws heating. The trouble was it needed a little lead, ie blade clearance.
Does the whole frame move up and down to accomodate differing log heights? How do you dog your log down?
Ron, if you look at the close-up shot, you can see, on top of the first wooden bunk, the dogging system. It's a fixed dog to the inside, and on the same steel (orange) bunk attachment, you can see a dog with a lever (handle) on it. You just move your log to the fixed dog, then push the levered one in (there are holes in the steel top, then lever the holding dog in with the handle. Where the powerhead is, you can see the endstands on each side, looking like vertical posts, these are steel posts, and the whole unit, track included, can be moved all the way to the top of this via a gearmotor. The are stands at the unseen end as well. They operate with a rack and pinion gear system mounted to cables which lift or lower the unit on the endstands. You can see onje of the cables (kind of). I think you're looking in the wrong place for the horizontal blades. The unit is bottomed on the endstands, and the bottom edger is appproximately 2" above the bunks. The top, adjustable edger is 5 or six inches over than one. The edgers control the board width, the main verticle blade controls board thickness. This mill can handle at least a 42" log, probably more, length is only limited to track sections. I think you can go to 40 feet on length. The whole mill also can be moved horizontally to the limit of the end units that the endstands are mounted to, either way. Big log=move whole unit up on the endstands to the width (plus slab you want for your first pass), move horizontally for first slab of main blade, make a pass. Next pass make a board, move horizontally to thickness, make board, and so on until the top is flat. At this point, you can lower the whole unit down on the endstands, say 12 inches (plus kerf). You could simply make a pass and cut 12" boards up to 4" or 6" thick, depending on the size of edger blades, or you could move the top blade down 6" and get two 6" wide boards with each pass. Or you could lower the top blade down 4" and make a 4" and an 8" wide board with each pass, etc. Sounds more complicated than it is, if you watched it work for 5 or 10 minutes, you could run it easily.
You can dice up a 30" log in this fashion in maybe 20 minutes, including offbearing, by yourself. You'll have a lot of sawdust laying between the bunks and to the right of the contol area, all down the log length at this time. The final (bottom) slab will look like a side slab. Then you undog the slab and roll on a fresh log.
Guys, You only use water when you are using a 1/4 inch curf main blade. When the bottom slabe is thick thick enough I always turn it up on edge and cut an attitional board or three. ;)
I meant to ask you Dan, how did the viewing go as well as the sawing? Let us know if you can, please. I do hope that you are another proud owner of a Mobile Dimension Sawmill. 8) 8) 8) 8)
Thanks, frank and timberbeast for all of your info. Now after going to the website and re reading your posts on how they work I've got a good handle on them now. I also see that they are quite mobile if you want them to be.
A simple question, do you ever have problems at the end of your cuts with the blade hanging up when the cut piece starts to fall into the saw kerf? Guess after you saw a large timber you just manually roll it out of the way?
Thanks in advance
Gordon
Gordon, if anything the board falls away from the main blade toward the carrage track. As the caggage returns it brings the lumber back to you, no matter the dimension, from a 1 x 2 to a 4 x 12, 24' long on one of my mills. The rate of return is the same no matter to size of the cut board. There is zilch in hangups for me. the board always fall away and returned to me. I often get in a hurry and use my "pickaroon" to bring the board back and place it in the stack behind me. bye the time the lumber is placed in the stck and I have turned around the mill has returned and I am ready for the next cut. Both of my mill have 4 rates of return that I can set. If I have someone to offbear for me, I run at the highest rate, if they wish to work that fast. I always pay more than a can of Delmonte peas for my labor, however. :D :D
Gordon, on occasion, sawing small logs, I have had offcuts which have landed in a skewed manner on the uncut portion of the log. If you allow the mill to return, it will usually slash them in half, and occasionally sent a chunk flying (always away from you). But you can set the mill, in about one second, with a pin on the control handle, so that it stops at the end of the track. Then you can grab the offcut and throw it in the slab pile, pull the pin, and the carriage will return, pulling the board back with it. On large timbers, if you stick a prybar into the bottom kerf, about halfway through the cut, then lift a tad as the carriage returns, it is easier on the hydraulics. Not really necessary, just quicker.
Oh, my word! I was visualizing you cutting on that return, and was wondering what the H### you would do to the thickness of your cut by torquing on the log. I would guess, tho, that the 'carriage return part is where the log moves and no cutting is occurring. Yes, no? ( I could be part French, me.) lw
LW
The log is stationary and the carrage moves along a track system that is approximatley 12" square. Try the web site, www.Mobilemfg.com and perhaps that can help you visualize the process. The track and the carrage moves from the left to the right when cutting lumber. 8)
