General Forestry => General Board => Topic started by: gspren on November 12, 2012, 06:44:04 PM
Title: Need some weights for the front of my tractor
Post by: gspren on November 12, 2012, 06:44:04 PM
  I have several "baskets" of seasoned wood setting along a fence row since last winter. I took 16' fence panels and made some baskets that are about 4 1/2' dia. X 4 1/2' tall and put them on skids so instead of stacking wood I just lay a few on the skid first then after setting the basket in place I can just toss the wood in. This afternoon I made my first attempt at picking up a full basket with forks on the back of a 1956 JD620, the tractor had no problem with picking it up and while going downhill everything was fine but when I hit a slight upgrade to get to the woodshed the frontend went airborn  :o and even when I stopped the front stayed up until I lowered the forks. I unloaded about a dozen chunks off the back of the load and then made it OK. I wonder how much weight I need to hang up front? This was seasoned cherry and locust so moving a basket of green oak would be much worse.
Title: Re: Need some weights for the front of my tractor
Post by: breederman on November 12, 2012, 06:51:54 PM
I would ask my wife to sit on the hood. But then again I ain't to bright!
Post by: tyb525 on November 12, 2012, 06:56:02 PM
2-300 lbs maybe?
Post by: beenthere on November 12, 2012, 07:17:54 PM
gspren
Back up the hill. You will be fine.
How much weight?  Just enough to counter balance whatever the load is (which will vary from one load to another if you have just tossed in the wood). Remember the rules of the school-yard teeter-totter, or physics.  ;)
Sure need some pics of that rigging.  :) :)
Post by: sawguy21 on November 12, 2012, 07:22:34 PM
Got an old cylinder head lying around doing nothing useful? Hang it from the axle.
Post by: martyinmi on November 12, 2012, 07:27:47 PM
Quote from: breederman on November 12, 2012, 06:51:54 PM
breederman,
You and I might be related. :D :D :D
gspren,
If you can wait until the next pig roast I'll deliver you enough 70# IHC(they are off from a 1086 if I remember right) halves to keep it down. I think I have 12 that I used to use for tractor pulling back in the 80's when we weren't allowed to use hanging weights. And the price to you(FREE!) can't be beat. ;)
And speaking of beat, have you given any thought to beet juice? We use it on our 300+ hp tractors instead of hanging weights when we are packing the silage piles. I think it's 25 - 30% heavier than water and non-corrosive.
Your local tire dealership should be able to tell you how much weight it will add when you tell them your tire size.
Post by: beenthere on November 12, 2012, 07:39:06 PM
Quote from: sawguy21 on November 12, 2012, 07:22:34 PM
What??  How??
Post by: sawguy21 on November 12, 2012, 07:41:05 PM
I have seen it done with strap iron u-hangers
Post by: gspren on November 12, 2012, 09:54:30 PM
It's a tricycle tractor so nothing on the axle. The front tires are 6.50 x16 so would hold about 7 gal each so thats a thought.
Post by: chevytaHOE5674 on November 12, 2012, 10:12:02 PM
The rear end of my hay mower needed some weight for ballast, so I dug up a 4cyl engine block and filled it with concrete and hung it from the rear frame with a chain. Was super cheap and does the job.
Post by: Okrafarmer on November 13, 2012, 12:16:34 AM
Marty, did you have to put antifreeze in the beet juice? In Michigan you don't want those tires freezing up. Straight water will freeze of course. Is the beet juice also anti-freezical?  ???
On the JD 620, yes, most of the JD horizontal 2-cylinder tractors are naturally light on the front, compared to a Farmall, for instance. There are usually 2 or 4 big bolts on the front of the bar going down the middle of the grill. Make a bracket to bolt on those bolts, and you can hang some weight up there.
Also, JD did originally make some ballast weights specifically for those tractors. However if you don't already have 'em, they're rather spendy collector's items now.  ::)
Also, beenthere is right. You can back up the hill if you have a heavy load on the rear. Just like we teach in Bobcat school (school of hard knocks rocks): "Always keep your heavy end up-hill."
Post by: chevytaHOE5674 on November 13, 2012, 08:02:14 AM
I think beet juice is good down to -35*. I've got some in one tractor of mine and have never worried about freezing.
Post by: gspren on November 13, 2012, 08:14:47 AM
gspren,
[/quote]
Marty, If those IH weights are what I think I would take 4 for the rear of my Farmall H, as to the beet juice I have it in the rear of a JD 318 garden tractor and the dealer said they don't like putting it in small tires because of the smaller valve stem but it does work great. I will probably weld up a bracket to hang some suitcase weights on the front, maybe I can borrow a few until I know what I need.
Post by: Okrafarmer on November 13, 2012, 08:20:22 AM
Just don't weld it TO your tractor. That would mar a beautiful antique. You have plenty of bolt holes already provided for you, for the express purpose of mounting weights or implements to the tractor.  :)
Post by: gspren on November 13, 2012, 08:26:43 AM
Quote from: Okrafarmer on November 13, 2012, 08:20:22 AM
Absolutly, I just didn't word that right it is a nice looking and running old tractor and moving wood would be good for it over the winter. I have a bigger 2355 JD that handles it fine but I don't like taking the scraper box off and on to put on the forks for a 10 minute job.
Post by: beenthere on November 13, 2012, 09:15:25 AM
Quotetaking the scraper box off and on to put on the forks for a 10 minute job.
Get a quick hitch (iMatch is the Deere equivalent) and then dropping ballast and exchanging for the forks is a 15 second task. ;)
But neat to keep the old two-cyl Deere active too.
Post by: Al_Smith on November 13, 2012, 07:20:03 PM
As a rule those old JD three point hitchs are pretty controllable .In other words they stay where you put them .Just carry the load low .The tractor will only rise up until the load hits the ground .
Oh I've scared my wife nearly to death pulling shrubery with a Ferguson ,chain hooked  to the back of a grader blade .I would get the front end up three feet in the air but it never raised any higher once the blade hit the ground .You have to steer it with the  brakes though .
For those who don't know on those old Fergys and Fords it's next to impossible to control the three point hitch .That pot licker is either up or down .
That old 620 JD is one fine old hunk of USA made cast iron .Back when they made things to last forever . ;D
Post by: Okrafarmer on November 13, 2012, 07:34:37 PM
I would love to have a 620 one day. My dad used to drive one when he was a teenager, when it was still relatively new. For Captain Crunch and other Oregon people's benefits, that was when my grandfather worked for Thistledown Farm, before it became famous.
Post by: chevytaHOE5674 on November 13, 2012, 08:09:06 PM
Quote from: Al_Smith on November 13, 2012, 07:20:03 PM
That's because they don't have position control on the hydraulics only draft control. So the 3pt is always trying to raise or lower to keep the pull on the draft spring constant (perfect for a mounted plow or cultivator). Not until the 8n ford and ferguson TO-35 did you get position control to hold an implement at a constant height.
Post by: Al_Smith on November 15, 2012, 04:47:26 PM
Yes and no .It couldn't have been the 8n because it ran basically the same H.O. Ferguson lift as the TO-20-30 Fergy .Unless I'm wrong the 8n popped up about the same time Harry O and Henry dissolved their verbal agreement on the 9n .Harry built the Te's in England and Henry the 8n's in Detroit .Then a few years later old Harry to rub salt in the wound built the works in Dearborn or he found some cheap realestate  ,one .
Oh you can fiddle with the quadrant adjustment but you're kind of spinning your wheels to get it very close to hold anything in place .
Fact I don't think any of them could hold much until they came out with live power which would be the To-35 Fergy and I think the Ford Jubalee .I've been wrong before though  ;)
Post by: beenthere on November 15, 2012, 05:02:24 PM
Sorry Al
The Ford 8N had position control. At least the one I had did, but my TO-30 did not.
The 8N did not have live power. The pump for the lift ran only when the PTO was engaged and running.
Also as a side note, the 8N had left/right dual brakes on the right hand side, opposite the clutch. The TO-30 did not, and to brake the left wheel it had to be done with the left foot while operating the clutch (if that was necessary at the same time).
Post by: Al_Smith on November 15, 2012, 05:26:50 PM
Well I stand corrected then and thank you .
What however was different from the 8N and the TO-30? I once got an 8n as part of a trade which had the differential  torn out .I robbed the PTO shaft from it and put it in a To-20  which had a bent shaft .Had to use the Fergy bearing housing but the shaft was the same .I think I unloaded that Ford for 900 bucks .
I do know this, Ford or Fergy the brakes never amounted to a hill of beans .Turn the drums ,new shoes two years later you couldn't stop a pizz ants motor scooter with them .I even went so far as to install new bearings and  seals on the axles of one of my TO-20's  and two years later same deal and that tractor was and still is parked inside in the dry .
Post by: chevytaHOE5674 on November 15, 2012, 06:41:12 PM
The difference is in the hydraulic top cover (among other things), giving it position control of the hydraulics. On the 8n there is a lever that you flip to choose between draft and position. When it position it will hold the 3pt hitch wherever it is set with the quadrant lever. When in draft mode its either up or down, the middle part of the quadrant is to set how much draft is required before the 3pt will raise.
Post by: Al_Smith on November 15, 2012, 07:20:10 PM
Okay I think I remember but correct me if I'm wrong again .Is that the one that had a handle inside the quadrant handle? It's kind of fuzzy because it's been decades since I've been on an 8n.
Oh you can carry stuff on the hitch of TO 20 .You just lift it where you want it and kick the PTO out of gear .Problem being if it's heavy enough it will leak down .I suppose though you figure they are 60 years old that's not so bad ,heavens I leak down myself at times .
Post by: Okrafarmer on November 15, 2012, 10:34:46 PM
Our MHF model 50 is a 1956 model, and it has many features that are far more modern than you fellows are describing. They seem to have standardized a lot of the normal "tractor stuff" by that time, like two brakes on the right foot side, hand throttle to the right of the steering wheel, live (but not independent) hydraulics and PTO, hydraulics work without the PTO engaged (but still must have clutch engaged), power steering (which doesn't work on ours), and a six speed transmission with two reverse gears. Must have been a pretty nice machine to use when it was a baby, but now it is getting kind of sloppy.  :-\
Post by: Al_Smith on November 16, 2012, 06:05:16 AM
I suppose it's like most of them with a double clutch deal,the main and the hydraulics / pto .Two clutch plates in the same housing connected to two shafts,one inside the other .Double position pedal and a true pain in the behind to align the discs if they need replaced which thank heavens is only rarely.
I've got a 1954 JD 70 gasser which uses an over center clutch deal on the pto .It carries hydraulics but I've never used them .The old gal ,424 cubic inches really likes gasoline,lots of it .They say 35 drawbar HP but the old popper will walk circles around a Massey 65 .
The only three point hitchs I've ever paid attention to on the tricycle type JD's I think were add ons .They had external cylinders with a standard hydraulic valve so they would stay where you put them .Some of them had so much power you could raise the front of the tractor if the the load were heavy enough .
Rambling on one of my A JD's has a contraption they call a "powertrol " which I think works like draft control .I've never used it and really have no idea how it works ,fact I think the 70 might have something like that too .Lawdy it's been 20 plus years since I've had the green tractors even started .
Post by: chevytaHOE5674 on November 16, 2012, 07:12:29 AM
On an 8n the position/draft lever is under the seat behind the quadrant right up right to the hydraulic top cover.
As for the double clutch setup to get a "live" pto or hydraulics, just hope you don't have to replace one. Last one I did was the terrible trying to get everything all lined up and back together. Split a much larger tractor with a cab for a clutch job in less time than that little to-35.
As for JD and powr-trol I'm not sure what it actually is. Never been a JD guy as they are relatively more expensive compared to other brands with no real gains.
Post by: Al_Smith on November 16, 2012, 07:52:14 AM
I bought those old JD's before the country went nuts restoring old tractors .I think I got 125 in the A and 450 in the 70 .70-75 bucks in another A I robbed parts from that some  dummy pulled down the road to un stick and bent a rod .
I've only done two that I can remember double clutch deals .The first was Massey 35 I swore I'd never do again .The second was a Ford Dextra diesel that I just let a local clutch rebuilder reline and align before it ever got put back in the tractor .It was certainly worth the extra 50-60 bucks over doing it myself for half a day .
Post by: Al_Smith on November 16, 2012, 08:05:09 AM
More ramblings !This gentlemans 620 will probabley last forever unless it sits in a fence row and rusts up .I mean they were made to last forever .
Old tractors though get like old chainsaws ,the price goes up and down .If there's a bunch of money floating around they go up .Then when things get tight the bottom falls out .
I look at some of the prices people pay for old saws and just shake my head .You'd about think they were buying Rolex watches .
Post by: Okrafarmer on November 16, 2012, 09:45:17 AM
Al, the first hydraulic lifts on JD tractors came with the very first model A's built in 1933. They remained essentially the same until 1947. Those ones have a rockshaft at the back of the tractor, and you can build a 3ph for them, but they ONLY go up and down, you can't stop them in the middle anywhere, for love or for money. In 1947, JD revised the models A, B, and G, and one of the several improvements they made was the introduction of Powr-Trol. This optional feature made it so you could indeed stop the rockshaft at any position in between up and down. My dad's 1948 B had this. He designed a 3-point to add on to the B (also works for the A, 50, and 60). The PTO has to be running for the hydraulics to work, and of course neither the PTO nor the hydraulics is live on an A, B, or G. The other feature with the Powr-Trol is that it (usually at least) includes, for the first time on John Deere, a remote hydraulic outlet.
JD's original intent was that the rockshaft be used primarily with cultivators, but as the Ford-Ferguson 3ph gained popularity, the positioning of the JD rockshaft was perfect for use with a 3ph.  Eventually, over the course of the A-B-G, 50-60-70, and then the 520-620-720, JD went from no thought about a 3ph, to making an add-on unit (model 801 hitch, I think it was called), to eventually integrating it into the tractor design by the time the X20 models were offered. Each new model introduction, as well as the 1947 upgrade, brought improvements in the design, and a tendency toward mainstreaming of what had been optional features before. By the time the X20's were introduced, Independent PTO was standard, hydraulics were fully independent (also on X0 tractors), and 3ph was expected (although it could be deleted if the customer didn't want it). Basically, in 10 years, from 1946 to 1956, hydraulics were introduced to the farm and mainstreamed. Yes, they were around before that, especially on the power lifts and 3ph of John Deere, Ford, and others, but they really took off and matured after WWII.
Are you keeping those old tractors just because, or are you planning to tinker with them? I'm sure you could sell them if you wanted.  ;D
Post by: Al_Smith on November 16, 2012, 10:17:25 AM
The old tractors .Well it's basically the residue of a nasty divorce .Plus   couble of dozers and 50 tons of junk .I'll keep them because they will always be worth at least as  much as I paid for them and I certainly don't need the money .
I've seen the rock shaft deal on the old pre war years unstyled JD's just never paid much attention to them .They didn't all come so equipted .
I have the bones of a 1940 numbered A that didn't have the rock shafts .On the 1946 style but 1947 serial number A it has the rock shaft powertrol .There was about part of a year in '47 where they sold both welded steel frame A's plus newer stamped steel types .It was the remains of left over stock from WW2 they never sold .
If I recall correctly the true 1947 style had a low hole granny gear where the prior did not at least that was so on the B's .Fact the "war years "weren't that great of pullers like the unstyled or for that matter stamped frame models .
Post by: Al_Smith on November 16, 2012, 10:28:29 AM
While rambling on .In that pile of junk I have a couple D4 Cats .The 2T series is 1943 ,war years .It has a steel core radiator and steel bushings on the cylinders .The 1946 5T model has went back to copper cored rad.,brass bushings .During the big one all that brass was needed for shell casings .--Trivia --
Almost forgot ,also have a 1940 model 7 J series I think .Ag tractor ,pulled a 4 bottom plow in Indiana,low hours,cracked head which I have a replacement .It also because of prior to WW2 has a lot of copper and brass .
Post by: beenthere on November 16, 2012, 11:28:56 AM
Al
Seems like a few pictures of your collection would make some very interesting walks down memory lane.  8)
Would you do that for us?
Post by: Al_Smith on November 16, 2012, 11:40:51 AM
I've got few of pulling the antiques a long time ago .The rest are someplace on film not down loaded .Give me a tad to find them .
Post by: Al_Smith on November 16, 2012, 11:59:12 AM
Here a few of what I got .
 (https://forestryforum.com/gallery/albums/userpics/12054/John_Deere_002.jpg)
This is purely an exibition pull with a 1954 Oliver Oc-6 crawler .It's kinda unfair advantage pulling a crawler against a wheel tractor .The sled operator tried to stall me out but he didn't have enough weight to do it .He did stall a couple JD 820's though .
Post by: Al_Smith on November 16, 2012, 12:07:20 PM
One more .This is a dead weight pull .On dead weight the way we do it is like a horse pull,ten feet .There's about 5,000 pounds on that sled with wheel weights and a 1934-1935 JD B ,brass tag by the way .
I might have gotten 5 feet .
This was sometime in 1991
 (https://forestryforum.com/gallery/albums/userpics/12054/John_Deere.jpg)  I think and the last I ever pulled antiques . Sure was fun though . ;D
Post by: beenthere on November 16, 2012, 03:13:54 PM
I was thinking pics of the stash as it sits now, not yesteryear pics. ;)
You made it sound pretty interesting.
Post by: gspren on November 16, 2012, 03:56:32 PM
  Enjoying all this old tractor talk, I really need to learn how to get the pictures off my camera and on here. My 620 has live PTO and live hydraulics and that means you don't need to engage the main drive clutch, also power steering which I didn't need with that load on the rear! The 620 also has factory 3 point hitch and is quite powerfull. My Farmall H and 140 don't have live PTO so when the Tractors stop so do their mowers. One of the reasons I got the 620 was it acts and works mostly modern except for the hand clutch but it looks and sounds like an antique. The whole idea of moving wood with the 620 instead of the bigger 2355 was just to use it more, and it will move some wood!
Post by: Al_Smith on November 16, 2012, 07:59:50 PM
Oh I'm just full of storys .My favorite 620 story involves pulling a 24 by 24 foot machinery shed on dollies down an 18 feet wide country road with no permits .
We had road guards on all the intersections and only had to remove two mail boxes in three milles .Following behind on every little rise in the road  Mr Deere's  boy John would kick in the governor and the putt putt was transfered clear through that shed and rattled boards on the back everytime it fired .I laughed so hard I nearly wrecked my truck .
Post by: Lud on November 17, 2012, 07:34:13 AM
I was prepared when I ordered some concrete as you always get a bit extra.  5 gallon bucketswere filled and I pushed inch and a half plastic pipe taped closed in the middle.  After it set up and popped out of the bucket, it was easy to wire two of them on the front of my 57' Ford 841 PowerMaster tractor.
They've been a good counterweight for my lifts off the back end.
Post by: Al_Smith on November 17, 2012, 08:33:12 PM
I have an entire 55 gallon drum full of concrete on the tail end of one of my Fergesons .It has a Davis industrial loader which really is too much for that size of a tractor and will dead lift 2500 pounds .Without that counter weight ,what ever it might weight it would stand the tractor right up on its nose because I've done it .Not good at all .
Fact I did once of what the original poster did only in reverse .Uphill run ,load on front ,bounced the front end rear end up ,down the hill on the front wheels ,bailed off .The tractor turned upside down .My ex wife came down the road ,saw the tractor all 4 wheels in the air and thought I was under it .Not good .
Post by: Okrafarmer on November 17, 2012, 08:38:18 PM
I guess in the heat of the moment you didn't think of putting the loader down.  :-\ Or maybe it wouldn't have helped much by that point.
Post by: Al_Smith on November 17, 2012, 09:45:36 PM
That's what started the bounce.I let off the load and up came the rear end and down the hill we went .Myself for short time and the poor old Fergy for a long time .I was the proverbial rat leaving the proverbial sinking ship ,which did in effect sink ,in a manner of speaking .Stuff happens real fast at times .  ;)
That ain't nothing .I rolled a big old oak up over the top of a D4 cat and the only thing that saved me was it crushed the intake pipe and stalled the dozer engine .I'm blessed ,seems I have a guardian angel .
Post by: Okrafarmer on November 17, 2012, 10:21:44 PM
Yeah, I nearly flipped my Allis Chalmers CA over backwards once. In my subconscious desperation my right hand went back to an ancient instinct and tried to reach for the hand clutch of the John Deere B I used to drive. Of course the CA didn't have a hand clutch, but my hand found the throttle instead (my conscious brain not knowing what I was grabbing), and pulled the throttle back, stalling the engine. The front wheels were way up in the air, another foot or two and I probably would have gone right over.
God is good. I should have been killed 50 or 60 times by now!
