General Forestry => Sawmills and Milling => Topic started by: DR Buck on January 29, 2013, 03:09:16 PM
Title: Question about Using the Wood-Mizer Resaw Attachment
Post by: DR Buck on January 29, 2013, 03:09:16 PM
  This past weekend I was started making molding blanks for for baseboard molding from lumber I've stockpiled.   It was all sawn at 4/4 and 5/4 then kiln dried.   Before I could run it through the molding cutter I've had to rip it to width on the table saw and then plane it down to 3/4" and 5/8"  thickness.   Planing takes a long time and multiple passes, even on my Woodmaster 5hp planer.  I ended up emptying my 55 gallon dust collector drum 6 or 7 times just to get a few hunderd linear feet of molding blanks.
I'm looking for a more efficient and faster way to make stock thinner and was wondering if anybody used the latest model (RS2) Wood-Mizer resaw attachment to resaw kiln dried 4/4 and 5/4 boards into thinner stock?    The price is a little high, but maybe I can talk myself into buying one if it will work with 10ft to 12ft  4/4 boards.
Title: Re: Question about Using the Wood-Mizer Resaw Attachment
Post by: WH_Conley on January 29, 2013, 03:55:46 PM
Is there a pallet shop around close that could run them through the resaw for you. Maybe after hours or something. If the boss is willing there are usually some bucks that will stay a little later to make a little extra beer money.
Post by: Cedarman on January 29, 2013, 04:42:59 PM
I think WH has a great idea if you have someone in the area.
My guys will just about always stay for that kind of work.  I usually let them have all the money.
Post by: wwsjr on January 29, 2013, 05:16:23 PM
I have the older model WM resaw. I have it set up to saw bevel siding. I use 1 1/8" and saw it to 5/8" to 3/8" X 6" or 8". Works good for me. I have cut a 1000 BF in about an hour. Never have used it to resaw thinner boards, but I think it would work OK.  I think the later model has a much better feed system.
Post by: Jim H on January 30, 2013, 10:16:06 AM
I have the older model. I've done bevel siding, and also boards like you are describing with good success. I like the looks of the new style resaw plus it can be set up to do shingles.  Jim
Post by: Klicker on January 30, 2013, 10:48:38 AM
I have a 2007 model and have used it to resaw 1 inch boards and found it did it well. Rod
Post by: JustinW_NZ on January 30, 2013, 03:47:51 PM
Quote from: wwsjr on January 29, 2013, 05:16:23 PM
Excuse the thread hijack, but wwsjr I have one of the older resaws as well (it came with the mill) ive never used it but I assume looking at it you can mount it and tilt it offcenter for doing the bevel siding?
I assume its that simple?
Cheers
Justin
Post by: wwsjr on January 30, 2013, 04:55:40 PM
The tilt is achieved by adjusting the 3/4" bolts that are on the bed rails. Initially it takes some adjusting and testing to get the proper tilt from end to end. Once adjusted, I leave the same setting on the bolts as I take off mill. I leave mine with the bevel setting only. A quick test when I place back on mill is all that is needed. A slight adjustment may be needed if you are cutting different widths of boards. I am not at the mill today to look at manual, but it shows the steps to set up.
