General Forestry => Firewood and Wood Heating => Topic started by: r.man on October 09, 2013, 10:14:58 PM
This video shows a firewood processing station, or set up. I wouldn't call it a processor exactly but it shows ingenuity and the ability to make do while keeping things simple. Has some interesting points but the main thing I want to point out is at about the four minute mark that shows the wood going from the splitter to a trailer. KISS principle to the max. I tip my imaginary hat to the designer for getting the job done in a simple manner.http://www.youtube.com/watch?v=Clja6n0n4BM
r.man, the video didn't attach to you post.
That's because I am an idiot and after rereading and editing my post as I always do I forgot to actually attach the video I was talking about. Luckily I have learned to modify my posts so now I don't know what you are talking about. Did I say that out loud? Thanks for the heads up.
Using gravity instead of fighting it not as common as it use to be! Location location location.
Looks like he is using a electric winch to advance the log, to take it one step farther and have the log pusher run in a track and use the electric winch to shuttle back and forth there would be no need to drag the winch line out an hook it on the log.
If you look at the 7 minute mark, there is a french fry cutter design issue as will. Logs were getting jammed between the splitter wedge and the side. I would have liked to see the table were the rounds fall directly connected to the splitter. Even less lifting.
I expect that he could trim down a fair bit of work with a few minor refinements but he is probably so happy with the work he is saving that he hasn't bothered. Without changing his winch setup he could save a trip around by putting his canthook at the other end of the deck and a simple ramp at the splitter would allow him to slide blocks across instead of lifting them. Still, what he has is a tremendous improvement over a totally manual system. Warms the cockles of the heart, whatever those are.
