This is the second of a set of two tables I made for a friend (his walnut tree), it is just under 4 ft across the long corners. The two tables will be a book-matched pair. The voids were filled with epoxy (tinted with graphite). The base is basically a staved cylinder that has been turned (also walnut).
This was a big part of the motivation toward building a mill as these were cut with a chain-saw which left a lot of work and wasted a lot of wood mostly due to the saw being too small and my skills with a chain-saw are not great.
(https://forestryforum.com/gallery/albums/userpics/33766/coffee_table.jpg)
Nice. :)
That is a nice piece of walnut. Love walnut.
Very cool. 8) 8) 8)
Looking forward to seeing the pair finished. ;D
Sweet :)
Jim
The butterflys are a nice touch.
keep up the good work 8) 8) 8)
Its even better lookin in person. Nice job Dennis.
we ran several feet of trim thru the shaper last night out of walnut and it does look some beautiful, cant wait to get it stuck on the wall and finished.
Looks great. I do like the butterflies.
How did you take the rough chainsaw-sawn lumber to a useful state? I have a planning jig setup with my router, but it's labor/time intensive. Wondering if you have any other suggestions.
Hope we'll be seeing more pics :)
Chain sawn lumber to a useful state quickly? Use a big straight edge and mark the super high points and Use a hand held electric planer like I got cheaply at HF a number of years ago. Reduce the bite and keep measuring and marking and taking off the highs. A hand held grinder with a 35 disc can be a timesaver, then a sanding progression.
Not going to be mirror smooth but looks good to the average viewer.
After the 35 I'd bet your router would get it in one pass! 8)
Thanks for the advice Lud. Sounds like a good idea. I"ve been taking MANY passes with my router jig to flatten my chainsaw cut lumber. It's slow and its not doing my planing bit any favors. Maybe next time I get a 20% coupon i'll try picking up one of those HF hand held planers.
Great advice, Lud. ;)
Quote from: mesquite buckeye on January 28, 2014, 04:54:36 PM
Very cool. 8) 8) 8)
Delivered today and he put it next to the first one and took this pic.
(https://forestryforum.com/gallery/albums/userpics/33766/Tables.JPG)
Quote from: lowpolyjoe on January 29, 2014, 11:19:21 AM
I used a router setup also; it is quite slow but does a good job. I will get a handheld planer for the next one. Eventually I will have some slabs from the bandmill dry; they will take a lot less cleanup.
Den-Den I will pm you with my address so you can send me one for Christmas I will be looking for it a few days before the 25 and thanks for the gift :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) just joking my wife likes it told me she wants one I said as soon as YOU buy me a mill ill make you one :D ;D :) 8) 8) 8) 8) 8) got the most meanest looking face I ever saw so I don't think she is getting it for me :'( :'(
Nothing wrong with those. Walnut is nice wood. I used to be able to get walnut here, but my source has gone out of business. I have a couple on the lawn, but I have a long time to wait. :D ;)
You fellas to the south have lots of stuff we don't. :)
They look very happy together. smiley_thumbsup smiley_thumbsup
I have a big 2" dia flat bit that I use for planing with the router. This gets bolted to to a wooden jig on the mill, and i then just run the carriage up and down the rails. Side and height adjust are done on the mill.
With a 2400w router and that big bit you can chew away a fair bit of material if needed.
(https://forestryforum.com/gallery/albums/userpics/10460/ianab_slab_surfacer05.jpg)
Is that 50 htz power? We're on 60 htz over here. ;D
Great looking tables. Walnut is my favorite wood but I usually just saw the straight logs and cut the crotches up for firewood as they don't fit on my little saw. After seeing your tables that is going to change. Due to your post I see a chainsaw with about a 3 ft ripping bar in my future.
They look beautiful and the butterflies look great too. How did you attach the top to the base?
