General Forestry => Sawmills and Milling => Topic started by: woodweasel on February 16, 2014, 09:01:58 AM
Title: Adding Hydraulics To lt35 Manual
Post by: woodweasel on February 16, 2014, 09:01:58 AM
 Anybody ever added hydraulics to lt35? Kinda toying with the ideal :P :P
Went to my woodmizer account online but could not find the hydraulics
in the assessories. Lt 35 is one year old this month,bought it for my hobbies.Put a free ad in the Thirfty Nickle (want ads) last month picked
up 4 jobs. Two of the jobs are 50 plus logs ( will do these at the end of the month). Most i've cut at one time was 6 logs.Thinking 50 is gonna
be tuff manually? ??? ??? ;D :P Daniel
Title: Re: Adding Hydraulics To lt35 Manual
Post by: Chuck White on February 16, 2014, 11:10:25 AM
Hydraulics will certainly help your back, and we aren't getting any younger!
Maybe give Wood-Mizer a call and ask about trading up.
Your mill is still practically new and you might very well get all or most of your initial cost applied to a hydraulic mill!  ;)
Post by: Ga Mtn Man on February 16, 2014, 11:24:59 AM
I second Chuck's suggestion.  Adding hydraulics to your mill will likely effect your warranty.
Post by: WoodenHead on February 16, 2014, 02:28:02 PM
The LT35 likely has no hydraulic upgrade options available.  Having said that, knowing the right part numbers to order, you most likely could add the WM hydraulic loading arms, backstops and bolt-on log turner with hydraulic pump and two valves (LT40 manual option HLTK - $4,000US) without violating warranty.  I have never tried to add this to an LT35, but I can't see why it wouldn't work (2010 mill and newer).
However... I would actually agree with the others and consider trading up, particularly if you want more hydraulic functions (having some functions, but not all might be just as aggravating as having none).
Post by: Magicman on February 16, 2014, 02:39:13 PM
Personally, I would seriously consider upgrading to a LT40.  At least run the numbers.
Post by: Ga Mtn Man on February 16, 2014, 04:28:01 PM
Quote from: Ga Mtn Man on February 16, 2014, 11:24:59 AM
I second Chuck's suggestion.  Adding homemade hydraulics to your mill will likely effect your warranty.
Post by: hunz on February 16, 2014, 05:10:58 PM
I personally would trade it in... like magicman said, go for the lt40hyd! I myself already love my 35 hyd, but again its all I know. If I was to make any upgrades I would go bigger. Just my $0.02
Post by: MartyParsons on February 16, 2014, 07:40:05 PM
Hello,
There is a hydraulic kit for adding ( some of) the hydraulic features.  Loading arms, turner and back supports. Wood Mizer installed brakes on all mills that could possibly add hydraulics. The LT35 manual has electric brakes.
My opinion like the others if you are going to keep selling the sawing service your body will thank you if you purchase a full hydraulic mill. I would also think your production rate would increase.
The LT35 with Hydraulics or the LT40 HD would be great.
Marty
Post by: pineywoods on February 16, 2014, 08:59:20 PM
Woodweasel, I have added home-built hydraulics to 3 manual lt40's. Here's my 2 cents on the subject. I looked at buying the parts from woodmizer and adding them to my mill. Decided it really wasn't practical for several reasons, one being cost. Some of the options require some extensive cutting and welding, with a chance of warping the frame. WM hydraulics use a hefty 12 volt motor to drive the pump. You would have to upgrade the electrical system. All things considered, if you want the full package, trading up is the best way to go. If you have someone with a hydraulic mill within visiting range, I definitely recommend spend some time just watching. The wm turner/2 plane clamp operated by a competent sawyer is a beautiful thing to watch..
I went with a bolt on home-made turner/clamp, power backstops and toe roller, but I am a fixed operation, which makes it a lots easier.
Post by: woodweasel on February 17, 2014, 09:01:25 AM
Thanks fellows im gonna do the math, probally call WM. :P
