General Forestry => Sawmills and Milling => Topic started by: golddredger on March 08, 2014, 12:40:10 AM
Title: WM LT40 uses a 13'2" blade?
Post by: golddredger on March 08, 2014, 12:40:10 AM
Just want to make sure what size blade it runs. Got ideas kicking around and pricing things out. I would like to make sure it cuts 36" log and uses the 13'2" blades. There web site does not say they only give thickness and width for the LT40. Thanks! 8)
Title: Re: WM LT40 uses a 13'2" blade?
Post by: VictorH on March 08, 2014, 12:45:25 AM
It will cut a 36" log but there is only 24" between blade guides.  You won't be making 36" slabs with the Lt40.
Post by: Chuck White on March 08, 2014, 07:31:03 AM
The LT40's do use 13'2" (158") bands unless there has been a mod to the mill such as widening the sawhead!
Post by: Dave Shepard on March 08, 2014, 09:25:53 AM
An LT40 has 24" from the backstop to the outer guide roller, and 28" between the guide rollers.
Post by: golddredger on March 08, 2014, 04:23:45 PM
Thanks guys that is what I wanted to know! Have a great weekend!
Post by: Brucer on March 08, 2014, 07:27:53 PM
More specifically, the standard WM blades have 180 teeth that are 7/8" apart  ;D.
