General Forestry => Forestry and Logging => Topic started by: shawn55 on March 31, 2014, 11:25:32 PM
Just wondering where the serial numbers are on a 3-53 so I can identify the year.
The serial number and model number is stamped on the upper rear corner of the engine block. The numbers should start with 5033-xxxx and the serial number will be 3D-xxxx. A quick way to tell the year is check the governor housing tag as the year is usually stamped on it, unless someone changed it.
most 353 are the same the only diff is the rotation i believe
Got it. It's a 1975
