Other topics for members => General Woodworking => Topic started by: ozarkgem on August 24, 2014, 09:33:18 PM
I went to Colo and cut a load of furniture poles. . Do I need to peel l them now and let them dry or let them dry under cover and peel them later. I have not worked with these kind of poles. Not sure what species they are. Maybe someone can identify them.
(https://forestryforum.com/gallery/albums/userpics/36105/SANY0029%7E0.JPG)
Very likely lodgepole pine if from Colorado (CO).
Peeling can be learned as soon as you get a chance to test out your stash. I'd give a few a try and see how it goes, as they won't get any fresher. Depends a bit when they died, but suspect you will learn pretty quick what works the best.
I can't speak for Colorado, but I know down here in Virginia it's so humid that I have to peel pine right away or it will get moldy and funky in a hurry. Hardwood species seem to be a little more tolerant to drying with the bark on. Peel a few and leave some be to test it out - see which method gives you the best end result for what you're making with them.
