Other topics for members => FOOD! FOOD! FOOD! => Topic started by: coxy on December 16, 2014, 05:25:10 PM
how many times can you freeze and unthaw fresh meat the reason I ask is I have a lot of roast that I want to grind up in burger and make stew meat but I have to unthaw to grind and cut then freeze again its beef that I raised not the store any help would be great coxy
i won't refreeze meat. :)
I have thawed and refrozen meat but only high speed beef (read venison) many times but just once per package as this degrades the quality, with no adverse health/spoilage effect.
I just loses some moisture but not much if unwrapped.
It is a myth that this spoils it.
Beef that you buy in the larger markets has been shipped frozen for years then thawed and cut and packaged
Beef isn't shipped frozen. That would take all the shelf life out of it when it would thaw. If you thaw your Meat under refrigeration, process it right away and you shouldn't have any problem re-freezing. Especially for what you are doing taking whole muscle meat for grinding. It'll be okay. I wouldn't make a habit of it though. I would be more worried about the proper packaging to avoid freezer burn.
Keep it 40° or below and you should have no problems.
Agreed, just keep it cold!
Pork or poultry would be a different issue!
