General Forestry => Drying and Processing => Topic started by: buzywoodliff on January 23, 2015, 01:59:26 PM
Title: Moisture meter
Post by: buzywoodliff on January 23, 2015, 01:59:26 PM
Anyone find a good, dependable, inexpensive moisture meter for the hobby woodworker??
Title: Re: Moisture meter
Post by: beenthere on January 23, 2015, 02:04:03 PM
Quotegood, dependable, inexpensive
Do they go together?  Doubt it.  ;)
Post by: pine on January 23, 2015, 02:16:06 PM
What is your definition of inexpensive?  You want pins or pinless?
You can find some that are quite good (no fancy bells and whistles) Delmhorst J4 new for low $200's on Amazon.  Used on ebay,  there are a couple now, slightly used (what ever that means) for prices ranging from under $70, $129 and $150.  Of course the Delmhorst RDM3 is a good bit more with fancy bells and stuff.
Post by: square1 on January 23, 2015, 02:45:49 PM
Quote from: beenthere on January 23, 2015, 02:04:03 PM
You know the old saying: Accurate, Long Lasting, Cheap - Pick any two.
Post by: WDH on January 23, 2015, 09:19:19 PM
I think that you get what you pay for when it comes to moisture meters.
Post by: buzywoodliff on January 23, 2015, 10:31:34 PM
You get what you pay for pretty much applies to everything..... And I purposely didn't use the term "cheap". Lol
What little bit I know about them, the pin type are less expensive, and I think they would be fine for me anyway.
I was hoping to get something decent for 50-100 dollars.... Am I way off?
Post by: GeneWengert-WoodDoc on January 23, 2015, 11:02:57 PM
How important is it to know the moisture content accurately?  If the meter is off a little bit, will it ruin a project and mean a loss of hours of work as well?  Probably "Yes" and so you do need to spend money (no less than $200) for a meter.  I prefer one made in the USA as the calibration will be appropriate for our species, pus parts and repair will be very easy.
Post by: buzywoodliff on January 24, 2015, 06:03:41 AM
Thanks for the input, hope the new year is treating you all well.
Peace
Post by: WDH on January 24, 2015, 07:30:12 AM
I have a Wagoner pinless MMC210, and it is fast and easy to use.  You have to correct for wood specific gravity, but Wagoner supplies you with a chart.  This one costs just South of $400.
I also have a Delmhorst J2000X with a slide hammer and 1" pins for use in the kiln. This one will run just South of $500.
The Delmhorst J-4 without the slide hammer is about $260.
Post by: jdtuttle on January 24, 2015, 08:04:55 AM
I've had good luck with Lignomat. Not too expensive and works well.
Post by: xlogger on January 24, 2015, 08:49:34 AM
After looking at prices this morning you are right WDH, you will spend at least $400 for a good pinless. I want one myself but not in a hurry to get one, so I wait awhile maybe I'll find one on ebay or craigslist. I've need to start on building my kiln first for now. After a pm with doc, I thinking more about building a kiln and connect it to my OWB as a heat source. Anyone here done that? So any suggestions on the structure will be appreciated.
Post by: dean herring on February 08, 2015, 09:58:04 PM
I am getting really confused, the more I read about weighing lumber using electricity, the more I am confused. Is there a simple but accurate way to check?
