General Forestry => Forestry and Logging => Topic started by: coxy on April 29, 2015, 07:17:44 PM
Title: loader
Post by: coxy on April 29, 2015, 07:17:44 PM
has any one done or see anyone use a (hibeb loader I know its not spelled right)  with a grapple on it my neighbor has a wood processer and we were thinking about trying to rig something up to load the deck and separate the big and crooked logs that wont go through the processer if anyone has pics that would be great  :)
Title: Re: loader
Post by: landscraper on April 29, 2015, 07:44:35 PM
Hiab?
I had a palfinger that I was going to mount a grapple on, never found a grapple, I ended up selling the crane to a tree guy who uses it with slings and a hook to load logs.
The only problem I saw with mounting the grapple was where to stow it when the knuckleboom was all folded up for transport.  Mine folded in on itself behind the cab of my truck and the headache rack of the bed and I didn't see a good way to stow the grapple along with the boom.
Title: Re: loader
Post by: lopet on April 29, 2015, 10:40:34 PM
If speed isn't a issue, they're slooooow.
Or you can change the valve bank, but can't see why it's a problem to put a grapple on it.
Title: Re: loader
Post by: magicmikey on April 30, 2015, 03:16:44 AM
  I had 2 truck cranes, one which was modified for a short log hauler. The pair of hydraulic hoses on the boom run a homemade grapple with a single cylinder. The control valve was relocated and had pedal swing.
  The fotos are 35 years old. :laugh: :)
mike
 (https://forestryforum.com/gallery/albums/userpics/21613/56_GMC___Foco.jpg)
 (https://forestryforum.com/gallery/albums/userpics/21613/f-350.jpg)
Title: Re: loader
Post by: coxy on April 30, 2015, 06:45:55 AM
thanks for the info    I like the pics of the old trucks  :)
Title: Re: loader
Post by: gjersy on May 07, 2015, 09:32:41 PM
https://forestryforum.com/gallery/albums/userpics/15324/thumb_loadertj.jpg
https://forestryforum.com/gallery/albums/userpics/15324/thumb_bypassclam.jpg
Title: Re: loader
Post by: gjersy on May 07, 2015, 09:38:31 PM
Messed up posting those pics, but thats a Hiab on my 1970 TJ with a 1/2 cord bypass clam, it has tandem 34 gpm gear pumps and is pretty fast for its day.
Title: Re: loader
Post by: beenthere on May 07, 2015, 10:38:40 PM
gjersy
Your pics are in your gallery, so to put them in your post just modify the post, click on the line below "Click here to add Photos to post" and when the window opens, click on the "My Gallery" tab.  Your gallery will open and you then click on the pic you want to post. It will enlarge.
At that point, scroll down a page or so to see "Insert Image in Post". Click that, say OK and your pic will show in your post. Verify by clicking the Preview button.
Just one small step away.  8)
Title: Re: loader
Post by: CHill8903 on May 15, 2015, 11:30:30 PM
I have a Hiab 650 crane with 2 extra valves. I've also considered adding a grapple(log tongs can be scary). What's the best way to run the hoses with the extensions?  I know they make hose reels that would allow the hose to stretch/retract with the extensions, but they seem to only be 2 hose reels. Is there a way to run a grapple and rotator with one valve?  I'm thinking skidsteer quick connects would make it easy to take the grapple on/off.
Title: Re: loader
Post by: mad murdock on May 16, 2015, 01:46:36 AM
We have a Hiab log crane on a truck at work we use for lifting the helicopters and other things as needed. It works well. I think max lift is something like 6,000 or 6,500 lbs close in.
Title: Re: loader
Post by: lopet on May 16, 2015, 09:31:50 PM
Quote from: CHill8903 on May 15, 2015, 11:30:30 PM
I normally just run loops on top of the boom and tie to hoses together. That might be a little catchy if you're working underneath of trees. Just a idea.
