General Forestry => Forestry and Logging => Topic started by: Ken on June 09, 2015, 07:09:44 PM
Title: Access road gates
Post by: Ken on June 09, 2015, 07:09:44 PM
I need to put have some gates manufactured for some properties that I look after.  In the past I've had them built out of tubing, piping as well as posts with chains or cables strung between them.  I would like to hear suggestions as to what has worked well for others.
Title: Re: Access road gates
Post by: celliott on June 09, 2015, 07:27:17 PM
I've seen a few home built gates that had grease zerk fittings, a nice feature. Also some type of feature to cover the lock.
I think cementing the posts in well is a good idea, but it all depends on where the gate is I guess. If it's  gate beyond a main road that is also gated, do you need the whole nine yards, or will a cable\chain work?
Post by: Texas Ranger on June 09, 2015, 07:57:02 PM
If you use cable slide a 4 inch pvc pipe over the cable as a visual to knot heads that will ride into it and sue when they get hurt trying to trespass
Post by: Holmes on June 09, 2015, 08:07:13 PM
 I bought a couple from TS .I did not think I could build a metal gate for less than $150
Post by: thenorthman on June 09, 2015, 09:33:21 PM
the DNR gates out here are pretty slick, mostly made of 4-5" tube, sometimes with a counter weight on one end, usually with a box contraption on the lock end with various lockable levers so that each one can have a separate lock, if any one lock is removed the gate is open, locks are hid up inside a box so they are kinda hard to get too...
The gate at my folk's place... that is hardly ever used, is simply a pair of posts, one taller then the other, with 2 D rings welded to it, the lower D ring having the gate itself attached and the upper D ring having a cable that runs out to the far side of the gate to keep it level, the "hinge" is just some old heavy U bolts welded to the frame of the gate, I think that another hinge on the bottom of the gate is used too... its been a few years since I've really looked at it.  The gate is made out of 1.5" angle iron like 3/16-1/4" wall the posts are scrap rail road rails just set really really deep... I hear old gas pipe is cheap and plentiful in other area's
Post by: Ron Scott on June 12, 2015, 01:15:38 PM
The use of a single strand cable or chain has been banned for closing roads on National Forest system lands for some time due to the liability issues as mentioned above by Texas Ranger. We have had some significant lawsuits in the past due to personal injuries when a trespassing ORV, snowmobile, or motorcycle rider has been seriously injured or decapitated by colliding with a cable road closure in the past.
The State of Michigan also discourages their use and is in the process of initiating a law to ban their use for road closures on State lands and private lands as well.
The metal slate type farm gates available from Tractor Supply etc. are now often used or where more undestructible gates are needed in high trespass areas, they are build from 4 inch well casing pipe with the posts cement filled as also previously mentioned. The locks are also set up inside the pipe for armor against bolt cutters and bullets.
Post by: Wudman on June 12, 2015, 02:38:27 PM
I have used various types of gates in the past.  With the cost of steel these days, some would be rather expensive.  For the most part, a lock is for an honest man.  It will let folks know that you don't want them in there, and most will respect it.  I have had a couple of problem tracts, and nothing I did kept people out.  I had one tract that I gated with 4" boiler pipe set 5 feet in the ground in concrete.  It had six such post and a 16 foot gate out of the same material.  When I installed it......I thought to myself.....let me see you get through that.  I went back there a couple of months later and the whole thing was laying in the edge of the woods.  I have no idea what they pulled it up with.
The majority of our gates are 12 inch boiler pipe posts with a single 2" pipe crossbar that slides through the post.  The lock is protected inside the upright so that bolt cutters can't get to it, but a 3/8 shackle hardened Master lock can't be cut with a set of standard bolt cutters anyway.  It can present a challenge when somebody crazy glues your lock.
Now a days, I carry a 4 inch cordless angle grinder with me.  It will get you in anywhere.  A thief could do the same.  With that in mind, I have gone to hanging mostly 6 bar agricultural gates.  They are relatively cheap and keep out the folks that would stay out anyway.  Video surveillance is pretty cheap for the problem areas.
Wudman
Post by: tantoy on June 13, 2015, 10:07:53 AM
Building out of square or rectangle is much easier than round. Here are a few pictures of gate i have built.
 (https://forestryforum.com/gallery/albums/userpics/21468/P3130004.JPG)
 (https://forestryforum.com/gallery/albums/userpics/21468/PA210036.JPG)
 (https://forestryforum.com/gallery/albums/userpics/21468/Forest_service_gate_b.JPG)
Post by: GRANITEstateMP on June 13, 2015, 12:24:02 PM
Nice looking gate Tantoy!
Post by: Ron Scott on June 13, 2015, 05:33:53 PM
Well done!
Post by: Ford_man on June 13, 2015, 06:34:57 PM
Put up a sign with big lettering reading; ENTERING THIS PROPERTY WITHOUT PROPER PROTECTIVE CLOTHING CAN CAUSE SERIOUS HEALTH PROBLEMS OR EVEN DEATH.  then when the police come to see what you are hiding there you tell them if they go in there with no clothes on they can get baddly sunburned, cause skin cancer and die. :rifle: :rifle: :rifle:
Post by: beenthere on June 13, 2015, 08:26:37 PM
They prolly won't go in with no clothes on.  ;D
Post by: Ken on June 16, 2015, 07:51:51 PM
I picked up some material last Friday and my welder was working on the gates today.  Going to use 6" tubing for posts set in the ground below frost level and about 5' above ground level.  The posts will be put in buckets filled with concrete.  The frame of the gate will be 2" x 2" tubing fastened to and hinging off the posts.  The gates will open in the middle and be 24' in total length.   Will post some pics when they get installed.  Thanks for your input
Post by: Larry on June 16, 2015, 08:27:02 PM
Ever hear of Dogpatch USA?  At one time it was an amusement park featuring Lil Abner and a bunch of other characters.  It was a going concern but fell on tough times and closed.
While closed an ATV rider hit a throat high cable strung between two trees to keep people out.  He won  the ensuing lawsuit with a judgment of $650,000.  In lieu of cash he was awarded Dogpatch USA.
Lawsuit settlement puts Dogpatch USA in new hands (http://www.arkansasonline.com/news/2011/may/04/lawsuit-settlement-puts-dogpatch-usa-new-hands/)
I want to build a gate across our drive.  A big fancy iron gate.  Been gathering junk for the last 5 years in preparation.  Every time I see a gate while out driving I take pictures.  One time I was accosted by the property owner who wanted to know who gave me permission to take pictures of his gate.  After a lot of flattery we parted on peaceful terms. :embarassed:
Post by: Onthesauk on June 16, 2015, 08:40:20 PM
At least 10 years ago I read an article in a NW logging magazine about logging road gates.  Interviews with DNR, logging companies and a lot of the folks who "use" those roads.  At that time it was virtually impossible to keep a gate secure.  Design was pretty much just for the casual folks from wandering through.
Post by: Ken on June 28, 2015, 06:58:44 AM
Got 3 gates installed this week.  Should work pretty well.   Just have to weld some caps on the pipes to keep water out. I will also get some sort of a locking mechanism fabricated but will just use a chain and padlock for now.   I should have gotten these in earlier as some local yahoos were tearing around in their mud jeeps on a new road I have been working on.  One guy called me early last Sunday morning wanting to use my bulldozer that was on site to pull out his truck.   >:(
 (https://forestryforum.com/gallery/albums/userpics/13639/IMG_0196.JPG)
 (https://forestryforum.com/gallery/albums/userpics/13639/IMG_0195.JPG)
Post by: Jamie_C on June 28, 2015, 08:46:00 AM
At least you should be able to track him down and give him the bill for damages to the road. It's the only way some of them seem to learn.
Post by: submarinesailor on June 28, 2015, 10:51:42 AM
I would paint them a bright color to help control your liability.  If someone runs into them in the dark, no telling what the #$%^& courts will do.  Mine were painted a dark green and I found chrome on one the week end after we put them up. :o :o :o ::) ::) ::) :D :D
Post by: lopet on June 28, 2015, 11:35:12 AM
Looks built solid.     X2 on the high visible paint or some reflectors.
Happy B day    Ken  btw
Post by: John Mc on June 28, 2015, 12:57:00 PM
Quote from: Ken on June 28, 2015, 06:58:44 AM
... some local yahoos were tearing around in their mud jeeps on a new road I have been working on.  One guy called me early last Sunday morning wanting to use my bulldozer that was on site to pull out his truck.
It would be a shame if your bulldozer accidentally totaled the truck that got stuck tearing up your new road...
Post by: Ken on June 28, 2015, 04:07:25 PM
I do intend on putting some reflective tape on the gates to help with their visibility.   I should have mentioned that the guy on the jeep got stuck on a part of the road that I did not have finished yet so I was not too mad but he did get the message that I did not appreciate his trespassing.
Post by: Ed_K on June 28, 2015, 09:03:08 PM
 Ken, hope you had a good day  8) .
Post by: barbender on June 30, 2015, 09:22:10 AM
Nice gates, guys. X2 on the cable closure method, that is just a bad idea.
