I have looked at the double cut band saw blades and was wondering if any one has experience with them?
Is it only the crown that keep them on in both directions?
Could they be sharpened and set on standard machines?
Any info/input will be appreciated.
been wondering the same thing.
I was wondering the same thing myself!
I think you're talking a whole different animal, and a whole different kind of machine. Only thing they have in common is both using a band.
I think they are talking something like this.
https://www.youtube.com/watch?v=qHQJrdNbgUQ
I have no experience with them but I got a feeling that until you have optimized almost all other variables there are better ways to spend money.
Guessing they need a very solid rigid mill to work at all.
I must say that vidio is of an impressive machine.
gww
I'am not the sharpest tool in the shed but I'am sure our sharpeners and setters could be easily modified to handle double teeth. Now this is something for a sawmill shootoff best single cut vs. same size double cut, advantage may not be all that great if you consider extra costs and problems. I believe saw guides basically give up and down stability, front to back only if you hit something or push a dull band. Frank C.
Those are not inch and a half bands, those are at least four and more likely 6 inches wide.
Here is some interesting reading.
https://archive.org/details/bandsawguidebook00simo
Bit dated, copyright 1921, talks of doublecut blades being made as narrow as 8 inches.
Details on that particular mill is that it's a 6" blade and runs a 115 hp John Deere diesel. I'm not real impressed by the sawing techniques used in the videos, especially for hardwoods.
Twin Cut makes a circle mill that cuts in both directions.
i looked into a double cut and after alot of head scratching i decided it wasn't worth the money. ie: the blades are close to $300/ blade,the sharping/setting eq. was close to $35000,if your grade sawing you have to stop after every cut to clear the cant to see the grade. aside from all that i thought if double cuts were the way to go why dosent wood mizer have one? there are alot of smaller things that can increase production all the while using a single cut blade for alot smaller dollar amount :)
i agree with red oak on that one we gave some serious thought to one of the selects but you can buy a cooper scragg cheaper :D and cut a lot more lumber :)
When you get into those bands you need a saw room with someone that knows how to service them. I am constantly amazed at what and how much the bands we use cut, and the long service from them. Frank C.
I was in a hardwood mill in Canada that used 2 headrigs that had double cut bands. Sounded like mosquitoes. They live sawed and only turned the log one time. Everything went through an edger. They were doing about 100 Mbf per day.
(Mr. 18 million bf)
Pls contact me.
I now have 15hp electric motor for 40 ft band mill.
Cnytreeguy, welcome to the forum.
It appears that he has not been on here for several years.
If you have questions there are very knowledgeable people on here daily. I'm not claiming to be one of them though.
