General Forestry => Chainsaws => Topic started by: herbeapuce on July 31, 2015, 03:52:21 PM
Title: Is this a Carbide chain ?
Post by: herbeapuce on July 31, 2015, 03:52:21 PM
Hi. Seems this chain is rock hard and the file just slide on it.... is it possible it's made of Carbide  or I'm just stupid...   ;D
please see picture.
thank you
stef
 (https://forestryforum.com/gallery/albums/userpics/40351/Stihl_Chainsaw_Chain_marked__with_a_C.jpg)
Title: Re: Is this a Carbide chain ?
Post by: beenthere on July 31, 2015, 04:48:23 PM
Doesn't look like a carbide tooth. It does look a bit burned from aggressive grinding which may make it hard to get a hand file to push through it easily (slightly different curvature) and hardened so file doesn't bite in like normal.
Others may know more about it. Just my thoughts.
Post by: Seaman on July 31, 2015, 05:02:40 PM
Looks like it has been case hardened by a grinder, which will make it very hard to file.
FRank
Post by: old guy on July 31, 2015, 05:15:53 PM
Yup, what they said, somebody hardened it with a grinder and you will just dull files on it.
  I have gotten thru the hardening with a file but it ain't no fun.
   John
Post by: herbeapuce on July 31, 2015, 05:37:57 PM
Quote from: Seaman on July 31, 2015, 05:02:40 PM
FRank
In this case I will get a new one.  the teeth are uneven in length so there's no way I can do a good job  by hand with this chain...
I put a lot of weight on the file and it doesn't grab .... brand new file that is
thanks everyone
stef
Post by: Oliver1655 on July 31, 2015, 08:41:01 PM
Someone with a light touch using a grinder can probably salvage the chain.  Light brushing strokes work much better than trying to take off a lot at a time.  When the teeth are uneven in length, it is not uncommon for me to have to reset the stop 3-4 times to get them close to the same length.  In the process of doing this, most of the hardened/blue edges should disappear.
Most of the carbide chain I have seen has carbide tips brazed to the cutter links just like circular saw blades.
Post by: sawguy21 on July 31, 2015, 11:51:00 PM
Carbide coated chain is or at least was available but this isn't it. The coating looked like Spackle.
