General Forestry => Forestry and Logging => Topic started by: BargeMonkey on September 04, 2015, 01:49:07 PM
Title: Timbco Sawhead Trouble ???
Post by: BargeMonkey on September 04, 2015, 01:49:07 PM
  So I'm stumped, literally. I can rotate the head on my machine, but any pressure and it flops side to side. No leaks, no busted cylinder rods, no clue. I did try and twist a very large tree over last time I was home, I've heard you can bust the tilt cylinders. Anyone else had this problem ? Head moves, but just won't stay, haven't had this problem before.
Title: Re: Timbco Sawhead Trouble ???
Post by: Gearbox on September 04, 2015, 07:54:55 PM
Pulled the rod off the piston ? gearbox
Post by: BargeMonkey on September 05, 2015, 01:02:05 AM
 I called K+D in OH today and Kris didn't quite know, I guess those cylinders are known for this. I've got 2 other guys local with the same machines and heads and will know more tomorrow, not even going to attempt cutting with it especially with a road on 1 side and a major powerline on the other.  :D. Figured maybe someone on here had been down this road with a barsaw head, she just flops over, head still moves, no rods broken.
Post by: ScottAR on September 05, 2015, 01:23:17 AM
Wonder if the piston seal is torn/blown....  That would let it bypass internally?   Hydraulic rams/cylinders are amazingly strong when everything is right but pushovers (pun intended) if something is amiss.
Post by: loggah on September 05, 2015, 07:39:19 AM
The nut that holds the piston tight against the rod may have backed off.that will allow the the cylinder to function but the oil can bypass on the threads under pressure.
Post by: Brleclaire on September 06, 2015, 10:40:38 AM
You could take the lines off and cap them off and try to see if if still flops around just to make sure it's the cylinders and not something in the valve. If it still does it pull the cylinders and break them down and see what's broke
Post by: Gearbox on September 06, 2015, 06:45:12 PM
As Loggah says or if the piston comes off the  rod all kinds of weird things happen . You can still force the rod out of the cylinder but no piston to pull it back . sorry I wasn't more clear on the first post . Gearbox
Post by: BargeMonkey on September 09, 2015, 07:42:38 AM
 Pulled both cylinders yesterday, the nut was busted off the left tilt cylinder. Another guy I know who has one of these heads has done his 3 times, guess it's pretty common when stumping big stuff. Called all over looking for a spare cylinder, they aren't cheap.  :o
Post by: loggah on September 09, 2015, 07:05:09 PM
Its not a excavator !!!!!!!! ;D ;D ;D
Post by: BargeMonkey on September 10, 2015, 09:01:19 AM
Quote from: loggah on September 09, 2015, 07:05:09 PM
I got yelled at a few yrs ago after I got it stuck, "it's not a (admin edit) mountain goat" where my father's words. Hopefully have the cylinder for when I get home, getting way behind again.
