General Forestry => Chainsaws => Topic started by: Dan-O-Matic on November 15, 2015, 11:51:40 PM
Title: Husky 445 or Stihl 250
Post by: Dan-O-Matic on November 15, 2015, 11:51:40 PM
Trying to decide between a Husky and a Stihl for a Home Use saw.  :P Will probably never cut anything bigger than 24 inches. 1 or 2 cords a year for an occasional use fireplace. Currently I have 5 large white pines I need to get down and cut up. All are about 20 inches at the base. After those come down and get cut up it'll be occasional use for trees that have fallen across a path I walk with the grand-kids.
Stihl is the only game in town the sells and services. But my concern with them is that the warranty is only a year. Unless I'm missing something on the website.
The closest Husky dealer is about 30 miles away. But the Stihl dealer works on anything. So....Husky 445 or Stihl 250?? Or something else. We have a TSC that sells Jonesred as well. No experience with those.
Thanks for the help.
Title: Re: Husky 445 or Stihl 250
Post by: SawTroll on November 15, 2015, 11:55:54 PM
The 445 surely is a much better saw, but you have to weight it against the difference in service availability.
Post by: sawguy21 on November 16, 2015, 12:33:56 PM
Stihl will double the warranty if you purchase a six pack of their oil with the saw and use it. I sold and serviced both brands, either saw will serve you well if used and maintained properly. In your situation I would go with Stihl simply for the service. Jonsered is a red Husqvarna and good but does TSC service what they sell?
IMHO, warranty is often overblown. If a defect in workmanship or materials doesn't show up in the first few months of use there should not be any problem. Echo touts a 5 year warranty but it is strictly a marketing tool to sell to the uninformed, any successful claims after the first year are very doubtful.
Post by: Dan-O-Matic on November 16, 2015, 08:30:15 PM
Thanks Sawguy. I figured with how little I'll use a saw either way would work. Stihl is where I was leaning. I took my dead Poulan pro that hasn't run right in the 5 years I've owned it to the same Stihl dealer. The guy at the counter who took my saw made it sound like it could be a week or so. I had NO problem with that. I got a call less than 24 hours later from their service guy.  He said the saw had been re-purposed as a paper weight. Scored cylinder and piston. Not worth fixing. I figure that if they will take care of someone who DIDN'T buy their saw there I'm confident they will service the guy that DID buy his saw from them at least as well.
Post by: kenskip1 on November 16, 2015, 09:01:50 PM
I have both of these saws. However I will give the Stihl the edge. Seems to have a bit more power or maybe the balance seems better with a 16BC. Both are great saws but like I mentioned I will have to give the Stihl the edge.
Post by: ScottInCabot on November 16, 2015, 09:42:58 PM
I own a MS250, and knowing what I know now.....I'd have purchased the J'red CS2252
Those stupid flippy caps just stink.  The saw has been leaking bar oil since I've owned it!  Stihl dealer here looks at me like 'so what'.
Support for a J'red locally is probably only the one dealer, but he at least treats me like a person...not a 'target for another purchase'.
Scott in Cabot
Post by: kenskip1 on November 16, 2015, 10:22:03 PM
SIC,If you had a problem with the saw why not take it back to the dealer and tell him you want it fixed the right way.Are you now shooting down all Stihl saws because of your own negligence? Granted the caps can be a bit of a hassle but once you figure them out you will never have a problem.If your dealer had taken the time and effort to ex-plane there function to you you may not have been shooting them down. How well did it run? Did it always start? How was the vibration while cutting?You did not mention these topics. Well congratulations on your Husky 353. This is also a great saw. I simply like to here both sides of a topic prior to having someone shooting them down.I hope you do not take offence as I am merely  stating my point of view, Ken
Post by: deerslayer on November 18, 2015, 04:29:48 AM
Regarding saws leaking bar oil, that's just a fact of life. It's not brand specific but some models seem to do it more than others.
Post by: Dan-O-Matic on November 18, 2015, 07:53:29 AM
OK....so if I were to go with a Husky, knowing that my use will be light on average (except for 4, 40' white pines I have to get down this year) can I assume that a 445 will be enough saw? The only Husky dealer within 30 miles is closing and offered me a 455 for $300. Which is just under what I can get a 445 for.    Thoughts???
Post by: rburg on November 18, 2015, 09:20:39 AM
The 455 would have more power than the 445 or 250 but it is also noticeably heavier. From what you have mentioned you will be cutting, the 455 should handle it.
Post by: starmac on November 18, 2015, 11:03:03 AM
As far as I'm concerned, the 455 is a good size for a home use saw, a new one for the same price or less than a 445 or 250 would be a no brainer at my place.
Post by: beenthere on November 18, 2015, 11:55:59 AM
Good deal, if indeed it is a new 455 saw for $300.  Otherwise, the dealer leaving would be an issue to consider.
My second saw is a 250, and has served me well. 18" bar and is capable of 36" tree diam, but likely would use the 20" MS362 for that size.
And no leaking bar oil either.  ;D
