General Forestry => Chainsaws => Topic started by: madmodifier on January 31, 2016, 12:33:15 PM
Title: Fuel tank vent replacement
Post by: madmodifier on January 31, 2016, 12:33:15 PM
Hi All,
I am wondering what could be used to replace a missing fuel tank vent? I have a Jonsered 910 and the vent is gone. I did not figure this out until I filled it with fuel and it was spiting out when revving the saw. I am guessing a section of fuel line but what to put on the end? I do not have any sintered brass fuel filters but I thought that might work.
Thanks,
Ben
Title: Re: Fuel tank vent replacement
Post by: dougand3 on January 31, 2016, 02:01:05 PM
A duckbill valve may work. Poulan uses them in fuel caps. Homelite uses them in fuel tanks. Depends on if the diameter is correct. IIRC, I used one in a 1/8" ID fuel line section for a fuel tank vent on a Husky.
Post by: madmodifier on January 31, 2016, 03:49:11 PM
Interesting! Thanks for the idea. Do you know if the idea is to vent pressure from building in the tank or to allow air in when needed?
Post by: dougand3 on January 31, 2016, 06:15:22 PM
It's to allow air in to replace the fuel going to the carb.
Post by: sharkey on February 02, 2016, 11:11:34 AM
Allows air in to displace the liquid.  If you can get a piece of fuel line to seal, you can use a screw with the head cut off like an old Stihl or maybe an Echo style tank vent;
http://www.ebay.com/itm/Echo-Fuel-Line-In-Tank-Vent-Line-Trimmers-Weed-Wackers-Straight-Curved-Shaft-/271905007083?hash=item3f4ecd25eb:g:88kAAOSw3ydVgdxQ
Post by: madmodifier on February 02, 2016, 11:15:32 AM
I did end up stuffing a piece of fuel line on the nipple and put a sheet metal screw on the end. I ran a tank of fuel through with little issue. I will try and pretty this up but it seems to work. Thanks all for the ideas!
