Been lurking for awhile and want to thank all for the great info in the forum. I purchased a Thomas 6013 back in June. Went with a Thomas as they are about 45 minutes from the house. First project was a saw shed, next will be a solar kiln.
I am sawing just for hobby/fun and learning every time I saw. Any day in the woods is a good day!
I think I have the picture thing figured out.
Thanks, Doug
Shed
(https://forestryforum.com/gallery/albums/userpics/43199/DSCN2100.JPG?easyrotate_cache=1479175347)
Wheels off, log deck up
(https://forestryforum.com/gallery/albums/userpics/43199/DSCN2120.JPG?easyrotate_cache=1479175493)
poplar, hemlock slabs, oak and beech
(https://forestryforum.com/gallery/albums/userpics/43199/DSCN2619.JPG?easyrotate_cache=1479176056)
You have a very nice operation there Doug, and Welcome to the Forestry Forum.
Also, congrats and thanks for the picture. 8)
Nice looking shed!
Also, interesting how you have stacked your lumber using minimal blocks. I'll have to rethink how I was going to do mine. I was planning on two cement blocks every two feet. But doing it your way, I'd probably do two (one front, one back) every four feet or so, place a big beam and then short 4x4s across every two feet.
I've got to mill some 8x8 and 8x10 posts, 8x12 and 8x15 beams. Then a slew of 5x9 rafters and a lot of 1x. Hopefully, tomorrow, I'll knock out these 4 logs.
(https://forestryforum.com/gallery/albums/userpics/30640/20161109_Cabin_3.JPG?easyrotate_cache=1478741815)
Awesome setup!
Welcome!!
gummer23,welcome to he forum. Like that building. Looks like you have the 60?? model? I have the 6020. Paint inch marks on those logs stops. Comes in handy when you are sawing flitches. I have 4-6-8-10 inch marks. 4 inch is really 3½ and 6 is really 5½. Just easy to set it up and I know I have a ½ inch to spare. Did a good job on the the log brough.It keeps the tractor away from the sawmill. Got a Logrite peavey? Sponsor on the left. Tell them thecfarm sent ya. :D
What's all the lumber being used for?
I see a tractor,using that to get the logs out with?
Welcome and I like your operation.
Very nice operation and welcome aboard.
Thank you all for the kind welcome.
ljohnsaw..So far the lumber stacks have held up well with the minimum of blocks. They have not gone swayback yet (3 months).
thecfarm...I have the 6013. Log stops are marked already, have not hit one yet knock on wood. I have the biggest cant hook that Peavy Manufacturing makes- they are right around the corner. Been using the tractor for some hauling but use the ATV with a Logrite arch for most log hauling. As far a lumber use, I build and repair cabinets and furniture. Just need to get the wood dry first. I recently tried Kasco 4 degree blades and have been using them for everything. Great cut quality and life with my little 13 hp honda.
Doug
Welcome Douglas nice looking sawmill she'd and operation
Welcome to the Forum, Doug. Nice mill shed and setup.
Very sweet set up ! Glad to see you around here . I hope to get up to the county soon .
Quote from: ljohnsaw on November 14, 2016, 10:15:48 PM
Nice looking shed!
The book I read on stacking lumber said that the bottom course of lumber should be 18" off the ground in areas of the country that has snow cover in the winter. You need to have it up so that the air can flow through every layer of lumber.
One way to do it is like he has shown, put down some "ground blocks" then some timbers then your cross blocking:
(https://forestryforum.com/gallery/albums/userpics/10095/Lumberdryingframe-s.jpg?easyrotate_cache=1196530543)
All my lumber in my yard is up on timbers above the ground blocks.
Jim Rogers
Quote from: Jim_Rogers on November 15, 2016, 09:33:20 AM
Nice looking shed!
Jim Rogers
Thanks for the info, Jim. But, does 18" still apply when you have 10
feet of snow :o :D
Nice shed
Dimensions?
Welcome Gummer, I can see your a meticulous workman good job on your shed. I've got to say it, add on, the snow will blow in and cover everything. If you really want to be spoiled put a good roof over your log deck and some sides on your shed then you can work through the winter, or at least part of it. Frank C.
Quote from: bandmiller2 on November 15, 2016, 05:34:26 PM
You are so right. My plan is to drain the fuel and pull the battery when the snow piles up and go skiing.
Doug
Quote from: gummer23 on November 15, 2016, 06:03:14 PM
Doug
Welcome aboard, I like the way you think!!
Best
D
Doug
Last five letters was wrong... Should have been outh.
Welcome aboard Gummer, I live on the coast of Virginia now. I was born in Houlton up there in Aroostik County. I have a lot of family up around Danforth, Pittsfield, Waterville and Portland. Nice operation you've set up there Brother.
May your cuts be straight, your boards never cup, check, twist, bow or crook and may you never hit a nail , glass insulator, brick or any other blade killing object , and my your blades sharpen themselves.
Glad you're here !!!
Quote from: Solomon on November 16, 2016, 08:35:22 AM
Quote from: scully on November 15, 2016, 08:35:54 AM
I'm headed up to the county next week to do some hunting with a good friend in Fort Fairfield. Beautiful country. Thanks for the welcomes.
Doug
Yessah... Good to see some Mainah's on here if you get to Liberty Look me up !! Good Luck hunting.. !!!
