I always run water on my blades while sawing is that the norm? When I get pitch build up I touch the blade carefully with a brush full of diesel and it cleans it right up. I always have been afraid to dry cut, after all thats why WM put a water tank on the saw right?
I can't say how much better it is using lube, but I so far have
never used any. Only dry cut. Once or twice I put a brush full
of diesel on my blade and I did not see a difference, so I quit.
ARick,
I think the idea of the lube tank is to have the "option" to use it as needed. I do not normally use mine when cutting poplar but use it extensively when cutting pine and ash. I have not tried the diesel trick yet but may as I recently bought a used JD tractor and first piece of diesel equipment on my place so now diesel is readily available.
Water will help keep the blade cool. Other additives will help cut sap. Try both and adjust as needed based on what you are cutting and your experience dictates.
For a couple of years I operated a WM-70 with absolutely no lube of any kind and had no problems or buildup on the band. Frank C.
Only water for one cut to clean the blade. I cut dry 99% of the time. In the winter I use straight windshield washer fluid. ;D
Wow I had no idea that you can cut dry and I've been cutting for 10 years I appreciate your responses, I will try cutting some of my soft woods dry, I really don't see how one could cut hard woods dry Opinions?
You have a lt15 I know, But, don't cut too slow. That will gum up the blade in pine.
I have typically always run water with detergents like Zep degreaser concentrate, Pine-Sol and even some generic liquid dishwasher detergent I brought home one time that my wife wouldn't use in our dishwasher ;D. At any rate they all seem to provide some level of cooling and lubrication. It also reduces blade and guide roller noise on my machine.
In pine or other logs with a lot of pitch I have to run some type of lube / degreaser to keep buildup off of my blades and the band wheel belts too. After reading several posts about the pros and cons of water / diesel lube on this site and because of the cold January temps the last couple of days I spent cutting, I finally broke down and tried some diesel. I can say I was impressed with how it kept my blade quite and clean. I was also happy that it didn't cause the dust discharge chute to clog up due to the damp sawdust :).The biggest bonus was the very limited amount of product I actually used. Only a single drip on the blade about every 3 to 5 seconds was all that was needed even in pine logs heavy with pitch 8) 8) 8).
Now I'm not saying that I'm going to make the switch to always using diesel because I don't like being responsible for dripping diesel everywhere I set up my machine. I'm also waiting to see if using diesel significantly shortens my bandwheel belt life. But I sure did like the way it worked for me when I used it.
I can't saw without water, my cedar is old and dry. My blades get way too hot without fluid. I can go through 10 jugs in one day.
Like DPatton I added diesel to my lube choices to get through some very sappy pine. Immediately, I could tell there was less strain on the engine, a clean blade and no wavy cuts. Used a manual oil pump can connected with a neoprene tube tee ed into the regular lube line.
I always run water/Cascade. Probably 90%+ of what I saw is SYP. If I start to get any indication of blade buildup, I switch the LubeMizer on constant and engage the clutch until the buildup is gone, then back to pulse.
Quote from: Peter Drouin on January 29, 2017, 08:38:54 PM
I have a problem with white oak or hickory gumming up the blade. I know you cut white oak, Peter. I'd like to see a video of how fast you feed through, say 15 or more inches of white oak. I may not have enough belt tension or something but I just can't seem to feed fast enough to not need blade lube on sticky wood like white oak. I run my drive belt and blade tensions over factory suggestion. Blade tension around 33-3500psi (gauge bottomed out) and drive belt around 19lbs
I had always cut dry until recently and i started with a mix of water, diesel, pinesol throwed together in a homemade lube tank. There is enough agitation to keep everything stirred up to some degree and I can tell a difference in cutting and how long blades last. My mill is a small, low powered, manual mill and it is easy for me to recognize small differences.
Quote from: RPowers on January 29, 2017, 10:27:02 PM
I cut as fast as the motor will let me cut. I have never done a video ;D
When I stop the blade in the cut from the feed and the belt smoking, I went too fast. :D
With some logs you have to use lube for a cut or two. I don't like lube all over the lumber.
Do not over tighten the belt, I put mine where WM wants me to. But the blade is tight.
(https://forestryforum.com/gallery/albums/userpics/22511/DSCF0386.JPG?easyrotate_cache=1396654059)
I will see about the video.
I used to cut dry but eventually I would cut a species that would give buildup. I modified Cooks diesel wipe to clean top and bottom of blade and since I can generally cut w/o worrying about buildup. My blade never gets warm, even when I used no lube, I think because 1) sawing rate and 2) crowned steel wheels that give good thermal contact with the band.
Bob
I have always used water (full tank) and a cup of liquid dish soap, usually Dawn with good results.
IMHO too little lube can be as bad as too much lube!
I cut mostly White Pine and Hemlock, with a little hardwood thrown in here and there!
EDIT: I forgot to add, I also put in a cup of PineSol.
I cut mostly hardwoods and I almost never use lube anymore.
When I cut pine I use water with dawn.
No problems but I'm not high production either.
Jon
With the logs I cut(mostly pine) I don't think I would be able to make more than a few cuts if I didn't use a lube of some kind. I originally started out with water with lots of soap I would go though maybe 10 gallons for a day of cutting. Then I went to straight pine-sol the bottle lasted a couple days. After that I switched to heating oil. In a full day of cutting I may go through 1/2 gallon but usually less than a quart. I have since switched to diesel. It works the same as heating oil but easier to get in small amounts. I have it set up so it wipes on to the inside/top of the blade. It used to also wipe on the bottom/outside but I don't think that made much difference. With diesel I use a couple drops per cut.
Quote from: kelLOGg on January 30, 2017, 06:56:45 AM
Bob
How about a picture of that modified Cooks diesel wipe.
I think I use too much water, I was cutting dry, but then I put on the HP guides, and the movable side would get packed with sawdust so to clean it what I would do is put the lube on full blast at the end of the cut and move it in and out and you could see all the wet sawdust falling out and I did that every cut and then I'd be out of water in a hurry and have a big mess. But now I took that thing off and I'm only lubemizing when the blade gets talkative
Redprospector, There was an existing thread on this topic so I dug it up.
Bob
https://forestryforum.com/board/index.php/topic,58022.msg843717.html#msg843717
I brush mine off at the beginning of each log.
When I had a drip system, more fluid lube would bounce off the band than would actually be used for cleaning and lubrication. When I added the lubmizer, I was able to use much less fluid. When I installed the high performance blade guides, I noticed immedialty that the tight clearances of the blocks would scrub the band clean, so again, I was able to reduce the amount of lube. However, I didn't like the way the HP guides would block sawdust from my dust collector, so I opened up the gap in the top side, lost the scrubbing action, and the top of the band gets build up again, so I use lube.
My point is that I have tried many different combinations, and hardware setup will definately affect pitch buildup. On the other hand what's it really matter? if a specific mill configuration requires it, use it, if it doesn't, don't....water with a little bit soap or whatever added to it is the cheapest part of sawing.
What you use to keep your blade clean also depends on how far north you are. Here diesel works most of the time but if you get a cold snap or if you buy some in early winter and don't use it until late winter it can gel on you.
Quote from: Joe Hillmann on January 30, 2017, 10:55:38 PM
What you use to keep your blade clean also depends on how far north you are. . . .
And a little further North, we use windshield washer fluid.
Buy it by the barrel to save: $0.68 per litre.
Not as strong as I use to be, made friends with a grapple.
(https://forestryforum.com/gallery/albums/userpics/19307/20170127_161106.jpg?easyrotate_cache=1485837264)
A bonus to using the ww fluid is that boards won't freeze together after cutting.
(https://forestryforum.com/gallery/albums/userpics/19307/20170127_161117.jpg?easyrotate_cache=1485837711)
Yup, saw that the other day, front tire is low.
Topped it up to 32 psi today. ;)
Quote from: kelLOGg on January 30, 2017, 09:16:48 PM
Bob
Thank you.
I must be doing something wrong, A full lube tank will last me a month or better.
I buy washer fluid by the barrel too and the last one lasted me a month
My mill doesn't have the Lube mizer, just the drip tube. So it uses more ww fluid.
Our work regularly calls for the widest cuts possible and the lube cools the blade.
In a 26" wide cut that is 40 feet long, if the lube is turned off, the blade tension drops because of heat.
Fluid and gas need to get topped up at the same time.
Where do you guys get windshield washer fluid by the barrel?
I haven't seen it at the local AutoZone....
I get it at my local carquest. We might have different kinds of stores though, all the ones around here are franchises (?) And they know you by name and sell alot of heavy truck parts and make hydraulic hoses and whatever. I don't think advanced auto or autozone does that kinda stuff
One of the jobs I worked at in the shop the boss bought methanol by the barrel and we ran that in the trucks for washer fluid, I think its the same thing
Quote from: YellowHammer on January 31, 2017, 10:12:18 PM
I bought 4 drums a few years ago at Orilley's Auto Parts. They had to order it, but didn't take long to get it.
I buy at a local lubricant and chemical company called Nemco. (nemco.ca).
Thinking that might be too much of a road trip for you Robert. :o
There's got to be some wholesalers around your part of the country I'd think?
Quote from: 4x4American on January 31, 2017, 10:34:11 PM
Don't have proof, but there's more to it than just methyl alcohol and water, there's some detergent type of agent in the mix.
It helps the wipers get rid of windshield bug smear in the summer.
Yes I meant to include minus the soap, could be other stuff. i'm honestly surprised that guy tried to save the company any money
