I'm getting some very nice large Walnut logs in, I'm thinking about doing it all in 8/4. Do you guys think I should air dry or dead green in the ol L200? I know what a pain it is getting final moisture out but I'm concerned about honeycomb and just hurting the load in general. I have a guy that would buy it tomorrow if I had it so as usual I need tonget going on this. I've done lots of 4/4 which is probably a cake walk compared to 8/4.
Any advice would be greatly appreciated.
I would say that figure has a lot to do with how you dry it. If it is straight, plain grain it is fairly easy. If it has beautiful figure wood at crotches, you have to be really careful.
I dont think it will have much figure Den, it's all woods grown tall and straight.
I have been kiln drying 8/4 with good success. It has a high moisture removal rate. However, I have been air drying to about 35% or less and taking it slow in the kiln.
Air drying under an open shed is #1. Then air followed by kiln. Then kiln drying green. The issue with going green is the long time involved. Because you have L200, you can safely (quality perspective) kiln dry a full load from green.
The most important procedure is to end coat with a double coating and also use the end coating on all large knots. Use Anchorseal or equivalent. This will prevent almost all honeycomb. The biggest issue with walnut is end checks that turn into honeycomb and travel down the lumber, often 12".
What part of Maryland are you from?
Here is one of the walnut slabs I currently have in a kiln. The slabs are 12/4 up to 14/4 and the ends were heavily waxed. We mark the checks before loading to make sure there is no dispute about where they came from.
(https://forestryforum.com/gallery/albums/userpics/10317/end_check_2.jpg?easyrotate_cache=1486311702)
Quote from: YellowHammer on February 04, 2017, 10:29:24 PM
How long are you air drying to get that and are you air drying in an open shed?
Quote from: GeneWengert-WoodDoc on February 04, 2017, 10:37:51 PM
thanks Gene, I'm going to air dry fro two months and see where it's at.
Quote from: robmelby on February 05, 2017, 08:19:14 AM
I'm in Westminster, not too far from you.
Quote from: Cazzhrdwd on February 05, 2017, 05:30:52 PM
Several months in the summer, longer in the winter. I have an open roof on a concrete slab.
I dry slab vacuum humidity 6 %. Doing heat treatment of 175 gr S. Humidity will be 10 - 12% heat treatment no. Air natural convection. Cold at bottom, warm at top. I have not used the atomizer with water, I did not use a fan. The steam from the wood , very much in the chamber is a drying agent and moisture. The result of drying and thermal treatment on photo slab.
Sergey.
(https://forestryforum.com/gallery/albums/userpics/11531/image_28129.jpeg?easyrotate_cache=1486356431)
(https://forestryforum.com/gallery/albums/userpics/11531/IMG_5144.JPG?easyrotate_cache=1486356470)
(https://forestryforum.com/gallery/albums/userpics/11531/IMG_5139.JPG?easyrotate_cache=1486356453)
(https://forestryforum.com/gallery/albums/userpics/11531/20161012_204034~0.jpg?easyrotate_cache=1486356704)
(https://forestryforum.com/gallery/albums/userpics/11531/image_28229.jpeg?easyrotate_cache=1486356732)
If you start with end checks, hopefully this is what you will have at the end of the drying schedule.
(https://forestryforum.com/gallery/albums/userpics/10317/closed_end_check_1.jpg?easyrotate_cache=1486480373)
(https://forestryforum.com/gallery/albums/userpics/10317/closed_end_check_2.jpg?easyrotate_cache=1486480405)
Nothing but a crayon line.
Quote from: serg on February 06, 2017, 12:08:23 AM
Sergey.
Sergey, I see you make gunstock blanks. It looks like you have hundreds of rifle blanks. Tell me about your gunstock operation. I also turn walnut into stock blanks and fit and finish stocks. Gary
I, also, have been trying to write a perfect schedule for walnut gunstocks. I think they have been coming out pretty good but the company that sends them wants them perfect. Not even hairline cracks are permitted. They sell some rough and any cracks would depreciate value. If it was up to me, I'd run them through a belt sander and then sell them. Here's a couple pictures. In the first one, I had cut up a a couple blanks to verify that there was no degrade inside and that the core was dry. The second picture is just 4 rejects.
(https://forestryforum.com/gallery/albums/userpics/10317/dry_gunstock~0.gif?easyrotate_cache=1487615626)
(https://forestryforum.com/gallery/albums/userpics/10317/Walnut_gunstock.gif?easyrotate_cache=1487615674)
ToddsPoint, Hello!
I do not speak English. I brought the nuts for drying vacuum chamber. The customer himself takes the gun factories where they make the butts for a hunting rifle.
Den. You said, well, do everything right.
Sergey.
Quote from: Den Socling on February 20, 2017, 01:35:22 PM
Crotch wood in a kiln would be tricky indeed. I air dry my wood, simply because I don't have a kiln yet. I cut stock blanks out of the slab immediately. I hang it and put a clear plastic bag over it. When the bag shows moisture, take it off and turn it inside out and put it back on. This slows the rate of drying and it will keep it from checking. Once there is no more moisture showing in the bag it is safe and the feather won't check. Gary
Quote from: serg on February 20, 2017, 11:12:26 PM
ToddsPoint, Hello!
Sergey.
Thanks Sergey. Gary
So as usual, trying to get the water to move in this 8/4 walnut. I'm at about 30% in the core, 17% on the outside. Shut the compressor off and raised the temp to 120. It's been there for 24 hours, no movement yet!
Finally have movement. Core is about 28% so I'm continuing with compressor off and 120 degrees. Outside has moved up to about 18%
Are you using a pin meter? They do not measure above 30% MC with any accuracy, so they will seem to stay at the same value even though there is moisture loss.
I have an L53 so the dynamics are similar to your L200. I turn off my compressor and raise the temperature to 145-150 degrees. Then I turn on the automatic fans until the temperature drops to around 120 degrees. The fan should exhaust a fair amount of moist air. Then I repeat the procedure. Make sure you turn off the compressor so you don't trip the over heat switch.
Gene yes I am.
Glen I'm trying to get the inside and outside cores to equalise a bit. It's been air drying for 2 months. I'm a bit nervous to go that high yet. I will when I get it closer to done.
Still slowly coming down. I'm getting a small amount of end checking,
Some are about 1 inch long and a 16th wide, it would be normal checking on anything else, sure hope it's not an indication of honeycomb.
Face or end checkIng?
Quote from: GeneWengert-WoodDoc on May 12, 2017, 05:03:39 PM
Its end checking, face looks very nice. It is end coated.
End checking should be controlled well by a thick coating of Anchorseal or similar product. The coating needs to be applied prior to the start of any end checking. Walnut is quite prone to end checking which indeed develops into end honeycomb. Hard to tell now how far the checks go.
Quote from: GeneWengert-WoodDoc on May 13, 2017, 07:01:03 AM
Have another load going in about a month, that will be also encoated with anchor seal. What about also covering the end of the pile with plastic?
Also any ideas on doing a better job with 8/4 walnut. I'd like to read up on it a bit?
Use two heavy coats
Quote from: GeneWengert-WoodDoc on May 13, 2017, 06:01:18 PM
Use two heavy coats
What would sealing the end with plastic do?
Seems like plastic would be a pain. What would you have in mind d?
Just covering the ends securely. Now I'm at about 25% core and my end checks are getting a bit larger. Not too many running down the face, just on the end.
(https://forestryforum.com/gallery/albums/userpics/39135/IMG_0284.JPG?easyrotate_cache=1494858303)
Its a bit blurry, not that way on my iPad. Not sure why it is here.
Getting more green 8/4 today. Going to put it on sticks and put it in the barn. Its going to be 95° Tomorrow (Wednesday) should I cover it also to keep it from drying too fast?
Here's how I would do it, not sure of your configuration. I would sticker it, with the stickers as close to the end of the boards as reasonably possible to arrest any end checks. Then I would spray or slather Anchorseal on it, two coats, or as much as it will soak up. I like spraying because it will cover the entire exposed end, and the exposed face, of the boards up to the first stickers. Then put it under a shed, put another stack of stickered wood on top of it for weight, and surround it with other drying stacks to cut the wind down.
Quote from: YellowHammer on May 17, 2017, 06:39:23 AM
Agreed, what do you think of the end checks in the pic?
Gene I'd like your opinion on it as well.
Except for the large one, they appear as normal end checks that could be prevented with two coats of Anchorseal. Two coats are essential when spraying.
The large check is a stress check from stress in the tree.
Quote from: GeneWengert-WoodDoc on May 17, 2017, 07:57:43 PM
Okay thanks. I coated it once during air drying, I'll do it on this next load.
This next load is very nice. Here are some very nice 15'
(https://forestryforum.com/gallery/albums/userpics/39135/IMG_0285.JPG?easyrotate_cache=1495066400)
