General Forestry => Sawmills and Milling => Topic started by: GareyD on December 09, 2004, 02:20:36 PM
Title: Help, I want to Auto Raise my MightyMite
Post by: GareyD on December 09, 2004, 02:20:36 PM
After using the mill for a couple days, I can see where auto raising the end stands would really be a time and GareyD saver...as it is now ya hafta go to both ends and raise 'em with the cranks shown in the foto below....
(https://forestryforum.com/images/03_21_04/End_Cranks_xat.jpg)
I called MightyMite and inquired 'bout their end raisin' setup...put me on the floor with a price of $3400  :o :o :o
They did however give me the part number on the Hyd. Motor that they use...
 http://www.surpluscenter.com/item.asp?UID=2004120915220918&catname=&qty=1&item=981-1027
On most mills that I have looked at...the Hyd. pump looks kinda like a big starter motor...is this the kind that I need...or a different kind...and how big does it need to be...
For power options, I have AC, DC, or  a 1700 Ford tractor that has a broken steering box/column, no remote hyd's, but the motor & PTO still runs fine...
I'm pretty handy at puttin' stuff together...just ain't real good at figurin' out what I need...need sumbody to draw me a picture  ;D ;D
GareyD
Title: Re: Help, I want to Auto Raise my MightyMite
Post by: D._Frederick on December 09, 2004, 04:39:41 PM
GD.,
The problem you have is that you have to raise both ends the same amount. The two choices you have are a mechanical linkage or with hydraulics. If you can find a gear boxes to couple to were the crank is and run a shaft between them powered by a dc motor gear drive would be the cheapest. Check with the Surplus Center and see what they have.
Post by: DanG on December 09, 2004, 05:07:51 PM
Garey. What D said.  My MD is very similar to your MM. It uses a 24v electric motor and a reduction gearbox. The two ends are connected by a length of square steel tubing with a gear at each end.  I'll try to get some pics tomorrow if that would help you.
Post by: GareyD on December 09, 2004, 05:14:06 PM
Dang
Pix would be great...I have a couple of ideas on what I need to do...just don't wan't to reinvent the wheel ;D
Also if ya get a chance see if ya can read any of the spec plates on the gearbox and motorsssss
GareyD
Post by: Frank_Pender on December 09, 2004, 06:36:30 PM
On the only two hydraulic mills MD manufacured (I have both of them) they used a small hyraulic motor to their already rack and pinion system connected at both ends.
Post by: DanG on December 11, 2004, 08:45:41 PM
Here's a few shots of the lift mechanism on my mill. I don't believe it is standard MD issue, though.
Motor & gearbox
(https://forestryforum.com/images/03_21_04/danglift04.jpg)
Sprockets and gears at the operator's end
(https://forestryforum.com/images/03_21_04/danglift01.jpg)
Gears at far end
(https://forestryforum.com/images/03_21_04/danglift02.jpg)
This is where the cables attach, that actually do the lifting. There is one of these at each of the four corners. The cable goes over a pulley atop the endstand, and is anchored to the crossbeam.
(https://forestryforum.com/images/03_21_04/danglift03.jpg)
As you can see, my ol' mill has been rode hard and put up wet, but she still cuts like a new one. I get sort of used to looking at it, but these close-ups are reminding me that I need to get handy with the wire brush and paint gun. :-/
Post by: Frank_Pender on December 12, 2004, 07:21:36 AM
DanG, it is a standard issue from the factory.  I have one on each of the hydraulic mills and on my first non hydraulic mill I ran it with both a 24 volt system and later powered it with an electric motor.  Then there was no more fussing with batteries.   The batteries were/are great if you plan on being mobile, which I am not. 8)
Post by: Swede on December 12, 2004, 09:29:25 AM
DanG;
If You use Hammerite (I´m shure you have that painting in US too) , a small roller and a paintbrush You don´t have to use the steelbrush very much! Later  it´s easy to take a paintbrush and do a "makeup" now and then. Red and Dark Blue looks great on old sawmills!  ;D
Hammerite likes some rust more than most new metal surfaces.
Swede.
