General Forestry => Sawmills and Milling => Topic started by: Jmiller160 on April 26, 2017, 11:25:46 AM
Title: blade sharpener
Post by: Jmiller160 on April 26, 2017, 11:25:46 AM
Are there any affordable hand sharpeners or possibly homemade options?
Title: Re: blade sharpener
Post by: paul case on April 26, 2017, 11:40:12 AM
I had an EZ boardwalk sharpener and I liked it fine and it worked well for the money.
They are a sponsor here. Icon in the column to the left of the page.
 (https://forestryforum.com/gallery/albums/userpics/20540/2953/SANY0008.JPG?easyrotate_cache=1288318938)
PC
Post by: fishfighter on April 26, 2017, 12:26:20 PM
Built mine for $25. Well, bought a old craftmen radial saw.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1182.JPG?easyrotate_cache=1484734446)
It takes me about 15 minutes to sharpen a blade. But I have more time then money. :D
The blade run thru a piece of 2x4 that I had sawed a slot 1" deep. It is tight and the blade holds good.
 (https://forestryforum.com/gallery/albums/userpics/38788/IMG_1180.JPG?easyrotate_cache=1484734555)
Post by: Kbeitz on April 26, 2017, 05:24:15 PM
And I used a Sears chop saw....
 (https://forestryforum.com/gallery/albums/userpics/39553/DSC05503.JPG?easyrotate_cache=1493241845)
 (https://forestryforum.com/gallery/albums/userpics/39553/DSC05080~0.JPG?easyrotate_cache=1493241966)
Post by: bags on April 26, 2017, 09:18:06 PM
I use a Tek Motion chainsaw sharpener. You can pretty much use it right out of the box without build'in a base bracket. Undo the chain stop and turn it around and block the chain adjustment bar and its good to go. I grind the micro cracks out of the gullet with a dremmel.
I'd post a picture but me and FF picture post'in don't get along.lol.
You can probably find a pic in my gallery.
Post by: fishfighter on April 27, 2017, 05:00:22 AM
Quote from: bags on April 26, 2017, 09:18:06 PM
With the radial saw, I'm using a 1" wide stone that I dressed it out to do the gullet too. I keep a new 7 degree blade on hand to dress the stone on. So far I been very happy with the way the blades are sawing. ;D
I had a bunch of 10 degree blades that are now 7 degree which I found that my little mill likes best. ;D
Post by: bags on April 27, 2017, 07:34:54 AM
In that closeup pic of your blade stop--- it looks like your 1" stone does a nice job.
Post by: DDW_OR on April 27, 2017, 09:35:16 AM
 (https://forestryforum.com/gallery/albums/userpics/22142/IMG_0344.JPG?easyrotate_cache=1493254727)
I like the idea of one sharpener for two things.
"I grind the micro cracks out of the gullet with a dremmel"
maybe have a wider grinding wheel that is shaped for the band blade?
Post by: DDW_OR on April 27, 2017, 09:43:14 AM
my sharpener came with the Timberking when we got it new.
 (https://forestryforum.com/gallery/albums/userpics/27421/GEDC1765.JPG?easyrotate_cache=1493300372)
 (https://forestryforum.com/gallery/albums/userpics/27421/GEDC1770.JPG?easyrotate_cache=1493300436)
 (https://forestryforum.com/gallery/albums/userpics/27421/GEDC1775.JPG?easyrotate_cache=1493300454)
Post by: Darrel on April 27, 2017, 05:45:01 PM
My old woodmizer sharpener
https://youtu.be/MDXdkY1dj6Q
And the duel tooth setter I made
https://youtu.be/rfhaoXh0xTE
Post by: fishfighter on April 27, 2017, 06:01:14 PM
Quote from: Darrel on April 27, 2017, 05:45:01 PM
If only I had the money to spend, but I only saw for myself. ;D Got a pineywoods setter that I made. ;D
Post by: Darrel on April 27, 2017, 09:09:39 PM
Hey Fishfighter, if you look closely, you'll see that my setter is basically a Pineywoods setter that I mounted on a frame and put a couple of handles on.
Post by: bags on April 28, 2017, 09:01:31 PM
Thanks for pull'in up the picture DDW_OR.
I'm gonna check around and see if I can match a wider wheel up to the grinder so I can get farther into the gullet. It takes a 7/8's arbor and the wheel is 5 3/4" so I'm think'in I might have quit the time find'in what I want for the job.
Post by: fishfighter on April 29, 2017, 07:31:12 AM
Check ebay. A bunch come with inserts.
Post by: bandmiller2 on April 29, 2017, 08:35:02 PM
Bags, 7/8" is kinda a standard size for wheels. They are held on with a collar and a hex head screw, you will need to find a longer screw, probably metric. Just for chuckles try sharpening only the face with the setup you have, you may find you get many sharpening's. Frank C.
