General Forestry => Timber Framing/Log construction => Topic started by: John P. on June 24, 2017, 10:03:39 AM
Title: Board and Batten + Wrap and Strap
Post by: John P. on June 24, 2017, 10:03:39 AM
I decided to go with the wrap and strap method for insulating my barn workshop, and am trying to figure out how to fasten my siding. I have horizontal girts/purlins every 24" for the siding to screw into. Wood is white pine, cut locally.
I'm processing my siding as follows:
Plane all to an even thickness - approx 7/8" (one side only, rough/bark side facing out)
Apply a wood preservative (all 6 sides)
Apply a latex primer (all 6 sides)
Paint (sides facing out only)
I was reading online about installation, and came across this article:
http://www.hobbyfarms.com/how-to-install-board-and-batten-siding-3/
The author recommends waiting 6 months to put the battens on - but does that make sense, since I'll be painting/etc...? The wood has dried for well over a year, though I know it will continue to dry once up.
Thanks!
Title: Re: Board and Batten + Wrap and Strap
Post by: Jim_Rogers on June 24, 2017, 11:20:51 AM
If the siding and battens are that dry, I'd put them up.
Jim Rogers
Post by: John P. on June 24, 2017, 11:51:09 AM
One other thing - that website (and I've seen it elsewhere) fasten the boards 1" from the edge - why not the middle of the board? That way, I would suspect at least, that the board would shrink evenly on both sides of the screw/nail.
Post by: John P. on June 24, 2017, 11:55:56 AM
Oh, not to answer my own question... but is the idea to hide the fasteners since the batten will overlap? You'll still see a fastener head on the batten.
Post by: Dave Shepard on June 24, 2017, 05:55:41 PM
Board and batten is only supposed to be fastened in the middle. The batten is to hold the edges and allow seasonal movement.
Post by: Don P on June 24, 2017, 06:59:19 PM
Notice he is only fastening one edge of the boards and is also putting bark side in, that cups it to the framing and allows the board to move seasonally, it is also putting more heartwood out, might help in the long term. Don't fasten the batten to the boards, only to the framing behind them so the boards can move. You can put the battens on immediately.
Post by: John P. on June 24, 2017, 07:03:46 PM
Wait - bark side in? I was under the impression I needed to put the bark side out from other things I've read.
Post by: Don P on June 24, 2017, 10:09:06 PM
Wood cups to the bark side was his rationale for doing bark-in. I've never really paid much attention, just put best face out. What was your reasoning?
Post by: Magicman on June 24, 2017, 10:22:59 PM
Boards cup toward the bark side and away from the pith side.
I always put the pith side out and the bark side in.  This makes the board edges tighten toward the building instead of flaring out.  I nail the boards and battens down the center.
