Hi there!
I'm looking for advice on outside wood boilers...
I'm building a new house which has 2300sqFt (basement) + 2300sqFt (mainfloor) + 1400sqft (attached garage)
We are pretty sure we want to put hydronic heating everywhere.. in concrete for basement + garage, and nail-up between joists for the mainfloor.
After searching through this website for reputable boilers, I think I've narrowed it down to either HeatMaster (dealer near by here) and Portage and Main (dealing directly with manufacturer).
After discussing with both companies here is what they suggested:
HeatMaster, G200 @ $12,000(CDN)
Portage and Main, BL2840 @ $8,900(CDN)
It seems like there's quite the price difference here... Is there a reason for this??
I was also wondering if anyone ever had any experience with either of these models and if you'd recommend them?
Any preferences?
Any advice would be appreciated,
thanks
OWBnoob
Please add your location to your profile.
I have the Central boiler 750 Edge.
https://forestryforum.com/board/index.php/topic,92218.0/all.html#top
Done! Thanks for tip!
side question:
How is fishing in the Great Lakes area?
The G200 is a downdraft gasification type boiler, with power exhaust bypass to allow indoor or outdoor installation. The P&M you mentioned is an updraft conventional type unit, outdoor only. The Heatmaster MF or C series would be similar at a lower price too.
The Heatmaster units are Stainless, P&M are mild steel.
Basically if you read up on them you see they are different type units. P&M makes a downdraft gasification type unit too.
Hope this helps.
We went through literally exactly the same thing last year. Only it was the P&M Egr 250 vs the G200. Ended up with the g200 which we love so far (although only been a year).
I really liked several feature from both manufacturers, in our case a local dealer was a large factor. I was told by a friend , and have experienced that the g200 is about the most forgiving of the gassers, although that is purely my opinion.
Heating our 2600-ish ft2 house, a large 2 car garage and all domestic hot water. (Despite the fact that I am the one that cut/split wood, I take by far the shortest showers) we used a little north of 8 cords. Unit when firing hard with good wood, doesn't have a whisp of smoke, steam condensation when very cold, but no smoke.
Also, lit the unit oct 31- apr 1. If that helps.
Thanks mf40diesel!
do you mind if I send you a PM for more info??
OWBnoob... Don't mind at all... PM away! I'll answe what I can for sure .
