General Forestry => Chainsaws => Topic started by: caveman on September 27, 2017, 09:32:17 PM
Title: Used Chainsaw parts
Post by: caveman on September 27, 2017, 09:32:17 PM
Where do you recommend getting used chainsaw parts?  There was once a forum sponsor who had them.  Specifically, I need a case half for a Husqvarna 359 (Chain side).  If any forum members have a 359 for parts, I would be happy to pay a reasonable price and contribute the appropriate % to the FF.  This saw was given to me several years ago by a family friend who purchased it to deal with a tree after Hurricane Charlie and continues to run well but it needs some love and attention.
Thank you
Title: Re: Used Chainsaw parts
Post by: thecfarm on September 27, 2017, 09:43:25 PM
This might be him.
https://store.chainsawr.com/collections/efco
Post by: caveman on September 28, 2017, 11:12:14 PM
Thanks Ray,
He had the part listed but was out of stock.  I may buy a whole used case off of Ebay.
Post by: Ianab on September 29, 2017, 12:23:53 AM
Quote from: caveman on September 28, 2017, 11:12:14 PM
Thanks Ray,
It might be worth still sending him a message and asking. He gets in bulk lots of old saws, and probably enters the parts into stock as he strips them and checks what parts are still good. He might actually have the part you need "out back" in the inwards bin, and just hasn't got to it yet. If you ask, maybe he can dig one out, and get the part in the next couple of days.
Worst case is he says, "Sorry we don't have one".
Post by: Al_Smith on October 01, 2017, 07:28:17 AM
If you give Scott a "heads up "  on a part he will get a hold of you if he finds one .
On the subject of parts there must be a hundred or more on the net ,then factor in e-bay .Certain items such as Stihl are easy to find but parts for say a model 7 Mall  might be another thing .You about need to know about how much they are worth and new parts for Stihl often are cheaper by just going through a dealer I've found .
Restoration of saws or any thing old is not for everybody because the wait for parts might be long on certain things .Given enough time they usually show up .
Post by: caveman on October 01, 2017, 08:33:29 AM
Ian and Al, thank you.  I need to probably let some folks know what parts I need.  I am making do with my 50cc saws, which are fine for bucking logs and most of the hurricane debris at my place is finally on the ground awaiting disposal-so I have time to locate parts.
Also, if I can fix the saw, I will learn a little more about chainsaw repair.  If I mess it up, I will chalk it up to paying for education-sometimes education is expensive, sometimes not so much.  The 359 still runs well and starts from cold on the second pull so I don't mind giving it a shot.
Post by: thedoublejranch on October 01, 2017, 03:49:13 PM
I'm looking for a ignition module for a Sachs/Dolmar 133, seems to be a common problem, made out of unobtanium too. Trying to fix it for a buddy, at the timber farm, my workhorse is my Stihl 026AV
Post by: Maine372 on October 01, 2017, 04:24:28 PM
do you have a part number for that case half? I have some orange orphans here that are as of yet unidentified.
Post by: caveman on October 03, 2017, 10:11:48 PM
Thanks Maine 372.  I sent Chainsawr an email and he had the part and suggested other items that I would probably need. They are ordered.  I will probably be asking more questions when they arrive about how to repair it properly.
Post by: caveman on October 21, 2017, 08:34:20 PM
We reassembled most of the saw this afternoon but decided to try to run it without the bar and chain to see if it would.  It did and I slung the clutch and bearing off.  We looked for the bearing and found it all crumpled up (I suppose we stepped on it).  Another is ordered.  On a positive note, the saw seemed to have good torque and ran well.
If you do not pay special attention when disassembling, it is quite a puzzle to reassemble.  Some threads are fine, some are coarse and the oiler and chain break have some unique bolts.  I think this 359 will cut wood again-relatively soon.  I had previously purchased the intake to cylinder boot.  We installed it today.
Post by: sawguy21 on October 22, 2017, 03:14:29 AM
Yeah, I learned not to run a saw without the bar and chain the hard way too.  :D
Post by: ZeroJunk on October 22, 2017, 04:06:11 PM
Quote from: sawguy21 on October 22, 2017, 03:14:29 AM
Me three.
Post by: caveman on October 22, 2017, 10:12:29 PM
I was glad it started up.  I finished the puzzle today (found places for all of the pieces).  I need one more coarse threaded handlebar mounting bolt-evidently used one in place of a fine thread in plastic somewhere.
We used a heat gun to warm the crank bearing and it allowed the case half to go together with very little effort.
The homemade case puller did well separating the case.
 (https://forestryforum.com/gallery/albums/userpics/22883/image~440.jpg?easyrotate_cache=1508085036)
 (https://forestryforum.com/gallery/albums/userpics/22883/image~441.jpg?easyrotate_cache=1508085037)
If I have previously posted these pictures, I apologize.  A two jaw puller was used to pull the bearing off of the crank.  Hopefully when I return from Indy next Saturday the clutch bearing will be here waiting on its installation.
 (https://forestryforum.com/gallery/albums/userpics/22883/image~438.jpg?easyrotate_cache=1508085030) The piston and cylinder looked good to me.  There were no scuffs or scratches, only some carbon on the top of the piston and cylinder.
Post by: thedoublejranch on October 22, 2017, 11:36:43 PM
Thanks Ray,
Thats probably your best option, because the left and right side cases are torqued together and the crank bore is machined, so technically, they are usually not sold as halve but a pair. With precision machining, even is mass produced items like the Husky chainsaw, they are very precision and would probably work just fine using a half from a donor vs a matched case set. But not ever sold that way normally.
Post by: caveman on October 29, 2017, 01:07:34 PM
After slinging the clutch bearing off and inadvertently smashing it like a bug under a fat man's foot (either mine or John's) I ordered another.  When I got home from Indy last night, it had been delivered.  It was installed and the saw ran well for the few minutes that I ran it this morning.
At the FFA convention, I was given a new Stihl hat which I have been wearing since all of my Husqvarna hats are worn out.  I don't have anything against Stihl, with the exception of their fuel caps, I just don't own any.  Anyway, I do appreciate them sponsoring the National FFA Nursery and Landscape CDE (Career Development Event).
 (https://forestryforum.com/gallery/albums/userpics/22883/image~447.jpg?easyrotate_cache=1509295852)
 (https://forestryforum.com/gallery/albums/userpics/22883/image~448.jpg?easyrotate_cache=1509295854)
Again, I appreciate all of the help and suggestions.  Without the encouragement, I would not have attempted to repair this saw.
Post by: sawguy21 on October 29, 2017, 10:47:00 PM
 8) Great. You are now the offishyall Forestry Forum Husqvarna chain saw surgeon.  :D Seriously, you learned a lot and we had fun following your project.
Post by: caveman on November 01, 2017, 06:47:43 PM
I had one leftover fine threaded screw with a tapered point on it.  It looks like it may adjust something but I cannot find where it goes.  Chainsawr sent an extra one just like it with the clutch side case half.
I suspect some of you gurus know where it belongs.  If so, I would appreciate the enlightenment.
 (https://forestryforum.com/gallery/albums/userpics/22883/image~459.jpg?easyrotate_cache=1509576028)
Post by: celliott on November 01, 2017, 08:15:18 PM
Pretty sure that's a case bolt, one that holds the two halves together. Are you absolutely positive you installed them all? Sure it's the spare chainsawr sent?
Post by: caveman on November 01, 2017, 09:59:20 PM
The case halve are bolted together with all of the holes filled with fine threaded bolts.  This one is different than the others.
