General Forestry => Timber Framing/Log construction => Topic started by: Darrel on October 04, 2017, 11:25:05 PM
Title: My make do with what you got pump house
Post by: Darrel on October 04, 2017, 11:25:05 PM
I have some Doug fir 4x8x16' taken from a house last summer, a whole bunch of tree tops and small logs I was too cheap to throw out, a mix of ponderosa pine and juniper.  Plenty of 1" blue pine I sawed last summer. A need to get this thing covered before the snow flies.
I'm leaving it a dirt floor as it is going to be replaced next summer and I'll be moving it onto a foundation with floor.  Will be bolting it together for easy disassembly when the weather warms up next spring.
I live off grid so I pump a 1550 gallon tank full about once a week and use gravity flow to my RV.  The small pump you see in the pic is for fire suppression. I use my Hobart stick welder to power the pump in the well.
Anyhow, here is what I have so far.
(https://forestryforum.com/gallery/albums/userpics/35121/image~24.jpeg?easyrotate_cache=1507173161)m
Title: Re: My make do with what you got pump house
Post by: thecfarm on October 05, 2017, 08:31:17 AM
That wheel barrow helps on on the size of thing. Going to insulate the walls?
Post by: Darrel on October 05, 2017, 02:06:08 PM
It is 12' X 14' and the roof will have a 3/12 pitch. I plan to insulate it with foam.
Post by: Darrel on October 13, 2017, 09:21:16 PM
Well the pump house project got put on hold because my wife wants a mud room next to the RV. So Vera and Grandson Ike helped me cut shiplap on the table saw and we nailed it down to a juniper foundation.  Juniper because even though I'm using concrete pier blocks it is still very close to the ground and pine won't hold up too long.  I will get back to the pump house as soon as I finish the mud room.
 (https://forestryforum.com/gallery/albums/userpics/35121/image~29.jpeg?easyrotate_cache=1507943795)
Post by: Darrel on November 03, 2017, 07:12:38 PM
Ok, I've made some progress.
(https://forestryforum.com/gallery/albums/userpics/35121/image~34.jpeg?easyrotate_cache=1509749755)
(https://forestryforum.com/gallery/albums/userpics/35121/image~31.jpeg?easyrotate_cache=1509749738)
Inside looking up.
(https://forestryforum.com/gallery/albums/userpics/35121/image~32.jpeg?easyrotate_cache=1509749744)
View from laying on my back on the roof.
  (https://forestryforum.com/gallery/albums/userpics/35121/image~35.jpeg?easyrotate_cache=1509750211)
Inside 5th wheel looking out.
(https://forestryforum.com/gallery/albums/userpics/35121/image~33.jpeg?easyrotate_cache=1509749746)
I leveled one side of the rafters on the mill and sawed a flat on the top side for nailing the sheathing to. Some of the rafters are Pondarosa pine and some are western juniper.
Got plastic on the out the outside of it yesterday and the snow is flying today.
