General Forestry => Forestry and Logging => Topic started by: skidinmetimbers on December 27, 2017, 11:50:38 PM
Title: HELP 518 cat cable skidder NO CRANK
Post by: skidinmetimbers on December 27, 2017, 11:50:38 PM
skidder wont start seems to have power  ran fine now wont start back up  no crank at all
Title: Re: HELP 518 cat cable skidder NO CRANK
Post by: starmac on December 28, 2017, 02:08:58 AM
Won't start or won't crank?
Post by: coxy on December 28, 2017, 04:21:46 PM
what year 518
Post by: mike_belben on December 28, 2017, 11:17:37 PM
Get your meter out and verify
1. the batteries are charged
2. there is battery voltage at the starter solenoid input lug.
Have someone turn the key and see if you get battery voltage on the solenoid output side.. i.e.. Is the solenoid contacting or is it not.
If its not closing the circuit across the two main lugs, figre out why.  Either it has lost ground, or has lost control voltage or have failed.
Report back your findings and well go from there.
Post by: mills on December 29, 2017, 04:16:37 AM
I've been through a couple of starter motors in mine. The first one was pretty much worn out, but showed signs of moisture getting in. The second was a CAT rebuild, and lasted only two years. It also had moisture damage. Never pressure washed it with direct spray, but now I avoid as much over-spray as possible. This last one is now going on it's fourth year. Another thing is to check your cables, especially where they cross the winch drive shaft. Follow Mike's advice and it should lead you to the problem.
Post by: mike_belben on December 29, 2017, 10:17:49 AM
Starter motors can usually be broken down and cleaned up enough to revive them.  If the carbon dust from the brushes packs into the commutator segments then they will all have continuity and the rotor stops.  The donkey catches up to the carrot on the stick so to speak.   The only other starter fail i typically see is broken magnets inside the housing from people smashing on them.
But first, verify you have juice past the solenoid and to the starter.  If not we have to troubleshoot the solenoid.
Post by: Corley5 on December 29, 2017, 12:30:09 PM
Check your grounds  ;) ;D :)
Post by: snowstorm on December 29, 2017, 12:40:49 PM
And ground disconnect
Post by: pulpco1993 on December 31, 2017, 11:42:06 AM
Look near the injection pump. The fuel shut off solenoid is sticks off. Has wire running to it. Cut key on. Listen for it to click. If it doesn't it is bad and machine want start. It has a button on the back/end that you can manually push in to shut it off or pull out do bypass the electric part and crank it. If i remember correctly.  I know you push it in to manually shut it down
Post by: pulpco1993 on December 31, 2017, 11:43:45 AM
You need to people. One listen one turn on ignition.  Get a test light check for power on that wire feeding fuel shut off
Post by: coxy on December 31, 2017, 07:18:05 PM
every 518 iv been around shuts off with the fuel peddle
