General Forestry => Sawmills and Milling => Topic started by: Peter Drouin on December 28, 2017, 09:24:05 PM
Too cold to saw. So I put the heat on for 20 min, The place is insulated.
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1701.JPG?easyrotate_cache=1514507022)
I put on a red marker ink at the weld and on top of the teeth. Gives me a place to start.
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1700.JPG?easyrotate_cache=1514507042)
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1699.JPG?easyrotate_cache=1514507057)
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1698.JPG?easyrotate_cache=1514507078)
I put my blade on the setter and try not to ben the tooth the wrong way. :D :D
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1705.JPG?easyrotate_cache=1514507140)
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1707.JPG?easyrotate_cache=1514507187)
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1709.JPG?easyrotate_cache=1514507206)
set them all at 30 +.-- ;D
I use the same oil that the CBM runs in to oil the blade on the setter.[just the bottom]
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1713.JPG?easyrotate_cache=1514507235)
This is where the red ink comes in for me, I can't see as good as I use too.
So when I line up the CBN and blade, Then turn on the oil and CBN wheel. I will have a small adjustment to make so all the ink is gone in the gullet beween the teeth, Then you Know the CBN is centered to the tooth so I can grind evenly.on the blade.
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1717.JPG?easyrotate_cache=1514507341)
I run it by a little to get where I had it set.
When I done I hold the rag and blade with my right hand, Spind it with my left to the left. All extra oil comes off on the rag. Where all my oil gose.
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1714.JPG?easyrotate_cache=1514507304)
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1711.JPG?easyrotate_cache=1514507409)
Run around 6.
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1718.JPG?easyrotate_cache=1514507364)
Box or two left. Going to be -2°
(https://forestryforum.com/gallery/albums/userpics/22511/SAM_1702.JPG?easyrotate_cache=1514507445)
I box them.
1¼x55x7
Hopefully it's -2 F, not -2 from vertical 😄😄😄
That heater looks like an eyeball.
I don't like it.
Delete it! :D :D :D
The Eye of Sauron😂😂😂
eye yi eye . :D
Quote from: POSTONLT40HD on December 28, 2017, 09:59:39 PM
I don't like it.
Delete it! :D :D :D
David mine burns off road fuel 175 thousand btu's gives a big red eye :)
I don't like it.
Delete it! :D :D :D
You have to climb Mount Doom and throw a goat in.
Once the picture gets in the post its here foreverrrr. :D Banjo
I leave my bands at the Pack N Ship. FedEx brings them back next week. Works at any temp. :D
Quote from: terrifictimbersllc on December 28, 2017, 09:44:45 PM
-2° from vertical is what I thought it was going to be, too. :-\
-2F :P
