General Forestry => Chainsaws => Topic started by: Sprucegum on August 31, 2005, 02:06:09 AM
I was working it , but not real hard- 18" bar, sharp chain, ripping 10' of 8" aspen. When I let off the trigger she died and stayed dead.
Took it in for warranty(5 months old) and was told
"Your piston is scored from lack of lube and your gas looks like there is not enough oil in it."
I put 3 ounces in a gallon and call it 50/1, right?
This batch was mixed about a month ago and I could have sworn it looked normal (blue-green) then but now it is kind of orange. Could sunshine on the can have faded the color? And wrecked the gas? And wrecked the warranty?
My brushcutter and my little Homelite also ran on this mix with no apparent harm BUT...cross my fingers and run a richer mix?
Hello, you are not the only one that seems to be having this trouble. My friend just went thru this. He used the Husky mix for 2.5 gal and mixed it into 2 gals. So it should of been closer to 40:1. It was used in a Rancher 55 and it did the same as yours and he was told the same thing, the oil did not stay mixed in the gas. Wonder if Husky has some bad oil mix. Only thing driffrent is his still looked green. He is now really shaking the can before filling. I have been using the Stihl oil and it seems to stay mixed but i do shake the can and the saw if any gas was left in it. If you sill have the gas that was mxed. I would not let them off so easy and get the mix tested. If it shows that you mix it right then they should replace the saw as you did everything correct. Good Luck
Don
get the mix tested
Who does this and how is it done?
Hello Kevin, I'm not sure who could do the testing but there must be a way to do it. Guess you can always think that you now have a parts saw. Hope someone does know were or how you could get the gas tested.
Don
:( Sad story, but I thought it was common knowledge that regular gas mixed with oil should be used in a few days and given a good shake before usage.
That is one of the reasons that I exclusively use Aspen 1:50 premixed alkylate fuel on my saws.
It can be stored for a long time without decline in quality, and it stays mixed...
Sprucegum,
Their explanation doesn't seem very good, "gas looks like the there is not enough oil in it"
You followed thier instructions to the letter using their oil so how can it "look like" there isn't enough oil in it? How can anyone tell by looking anyways?
Also I'm pretty sure it doesn't say anywhere on the bottle that you shouldn't use your mix if its older than a certain date... It may be "common knowledge" but its not common to everyone unless they wrote it on the bottle...
Also when I got my 372 the carb needed rebuilding almost immediately, it started to run lean and I'm glad I trusted my gut and took it instead of just running it.
I guess what I'm trying to say is that you may have had a lean siezure while using not ideal gas, therefore they are blaming the gas and you, get a second opinion and hopefully they will come through for you.
Good luck,
Thanks for the advice and support.
The dealer has sent the scored piston to Husky to get his opinion confirmed.
My can of gas is up in the bush so I won't have time to get it till the weekend. Then I will see if it "looks like" the right mix and try to get my opinion confirmed.
I am thinking at this stage of the learning curve, with my mechanical skills, I should have stuck to the cheaper "throw-away" saws.
I have no problem agreeing to that, in spite of what I said in my last post!
What is "common knowledge" is not an excact science, and of course not relevant in a warrancy issue.
Good luck, Sprucegum!
...... This batch was mixed about a month ago.......
:P Just in case you are not aware of it, the Husky 357xp/359 operators manuals says:
"Do not mix gas for more than one months use at a time" (or something like that).
Bingo , saw troll. Mix is only good for bout a month. Ethanol cuts new hind end in chainsaws too. Read fine print n see you should use "super" gas instead of regular.
I made a post a few months ago about my husky 346xp that I melted down. Fresh gas, Premium non-ethanol, 40:1 mix. That was the dealers immediate explanation, "you used ethanol gas and it broke down your oil". I said "no, this saw has had a lean bog from day one and you told me you couldn't do anything about it." I'm pretty sure it had an air leak,it wouldn't respond to the air screws being adjusted. I knew it was a serious problem but what can you do if the dealer thinks you're imagining things? anyhow, I was pretty irate, they ended up covering it under warranty and rebuilding it. Since then I have only got to run it for about 5 minutes, can't tell if it is cured or not yet. Good luck, don't be afraid to get tough with the dealer and let them know how mad you are about the situation and you expect them to make it right if they ever want any more of your business.
Barbender, I was just about mention your thread; you're dealer got quite a few folks here really riled up. Sprucegum, sounds as though you might be able to make a case to get your saw repaired under warranty. Best of luck!
I bought a Husky 3120 xp and it was covered for 2 years non-commercial use. For this reason alone, I bought Husky over Stihl.
After 18 months I took it to the dealer (not where I bought it but an autherized Husky dealer) to fix the following:
1. chipped stop/start switch from recoil handle snapping back
2. blown out exhaust manifold gasket
3. broken chain brake band
I figured they may not cover the switch but guessed they would cover the other items. I was very wrong. First of all the dealer was questioning why I had such a big saw ( non issue), said I had miss used it because the decal on the clutch cover was burned. He said I had run it with the chain brake on (yeah right!). Finally they pointed to the owners manual where it says that the owner should periodically check for loose fasteners and if I had done that I would have prevented the exhaust manifold gasket from blowing out.
End of story is: the repairs cost $100 and warrantee paid $00.
If I had not bought the saw at a discount through Canada I would feel ripped off . As it is, I lost a lot of respect for Husqvarna and will try Stihl the next time. My guess is that they will find a way to NOT pay for your saw repairs. But let us know the outcome.
Tim
in NYS
That is what I think also. They will get out of paying!
You should e-mail this thread, along with the dealer's ID to Husqvarna.
Tim
in NYS
Tim, you offer a few interesting perspectives.
First, if you knew that the stop switch was chipped from the recoil handle snapping back, why would you expect that to be covered under warranty?
Second, are you saying that it isn`t the end users responsibility to check all fasteners for tightness on a regular basis? Would the exhaust gasket have blown out if the screws were adequately tight?
Third, how did the decal on the clutch cover get burned if the saw wasn`t run extensively with the brake engaged?
My fourth and final question. Assuming that the dealer whom you took the saw to for repair did actually wrong you, how does that reflect on Husqvarna as a company, Husqvarna`s quality, or justify buying a Stihl next time?
Russ
I'll apologize in advance to SG for taking your thread off onto the topic of Husky vs. Stihl because I know that was not what your posting was about. But what is important here is how manufacturers in general and in my case Husqvarna specifically manage to tout excellent warrantee coverage at marketing and sales time but be very reluctant to live up to those promises if a claim is actually filed, let me explain.
Chipped on/off switch
This happened under normal use. It happened when the pull cord handle slipped out of my hand snapped back. I am sure this has happened to every saw that has a pull cord starter. As such it does appear to be a design flaw that the switch is exposed to the path of the returning pull cord handle. This is a well known situation. The product design team is supposed to anticipate and correct these problems in the evolution of the saw. Part of the price of the 'best of class' is to pay for R&D that designs around such occurances. That switch when its in the 'ON' position is hanging out there at the edge just waiting to be hit. Replacing it under warantee is a judgement call and Husqvarna (or their parent company Electrolux) chose to say No to a $18 switch.
Blown Out Exhaust manifold gasket
My thought on this one was that in order to maintain the warrantee, I should not be getting under the shrouding and doing things. Actually the muffler was not loose so I didn't know what it was at first. If I followed the manual to the letter and checked and tightened all the screws on the saw would I have prevented this ? Perhaps, but I may have caused other problems by opening up and accessing all those fasteners to begin with. Its a subtle point and its not really clear from the manual which "nuts and screws" the operator is supposed to check. The manual doesn't say and its a subtle point that lets Husqvarna off the hook for a lot of damage claims because they can always counter the customer and say the screws and nuts were not checked on a daily basis. Who can argue with that? This was another judgement call and again Husqvarna chose to reject paying $4.95 (retail) for an exhaust manifold gasket.
Broken chain brake band
The dealer claimed that this must have happened due to the saw being run with the brake on. Let me point out that in the process of milling the 3120 is generating a lot of heat for 10 minutes straight. This is what this saw was made for - heavy cutting. I also can't imagine the chain even moving if the brake was on let alone pulling the ripping chain through 30" of wood. The clutch is working hard and heating up, in addition, there is a lack of ventilation when the cutting gets near the ground and its very possible that the decal heated up from this. I have used this saw to mill 30" red oak and that takes a lot of power and makes a lot of heat. The decal situation is a symptom of heat thats for sure but its a guess as to what it came from. As appears to be the pattern, Husqvarna decided it was once again a case of operator error. Cost of new band $14.
What ticks me off about the situation is that Husqvarna would not, in any of the above cases give the customer the benefit of the doubt and kick in any of the parts. Even though I had bought their top-of-the-line saw and was in for my first and probably only warrantee claim (since 18 mos had passed), they refused to compensate me for a exhaust manifold gasket that probably cost them 50 cents. This treatment from the Authorized dealer and Husqvarna Customer Support strikes me as arrogant. Their treatment sent me the message that they don't really care if they get my repeat business. For this reason, they wont. As they are not the only game in town, I am more than willing to give Stihl a try, they couldn't do much worse.
The bottom line is that if Husqvarna is going to be so careful and reluctant about compensating customers for warrnatee claims, then they have no business offering a 2 year warrantee to begin with. Its misleading and dissappointing to those of us who bought their products thinking that the warrantee had some substance.
Partial update:
I checked my oil and it is not "Husqvarna oil", I had grabed the outboard oil instead so end of warranty :-[ :'(
Meanwhile the dealer's head mechanic has quit and then his partsman quit, its a small outfit, just him and a salesman left. I may not see my saw for a while unless I can go in and put it together myself.
Just another high-priced lesson in life :D
Tim,
Did the brake band "break" or "wear" through?
The dealer that had my 3120 didn't get the band on right and it wore through one of the two halfs before I caught it.
When I put it back together, I learned how hard it was to get it on right and you REALLY have to look for it.
Warranties on tools and small power equipment are really there to protect the manufacturer not the customer.
Warranty lengths mean nothing. When you look at the dealers warranty administration manual it is more important to look at what is not covered versus what it is, that will tell the true story as you will find lots more not covered than really is covered.
The dealer does have the option of talking to the manufacturer and obtaining policy coverage for his customer.
Sprucegum,
Did you use outboard injection oil? It probably isn't dyed blue. I'm still having a hard time believing your saw was killed due to old gas and oil.
I guess if you did the worst case scenario, outboard injection oil, 87 octane gas, let it settle for a month, and then didn't shake the can before you poured it, that might kill your saw...
So next time its new 91 or 93 octane gas, husky oil or better, mixed less than a week, shaken the first time mixed and every time you gas up your saw.
Its abit late for this saw but madsens has a tuning guide that will help you in the future so you'll know if your saw is running too rich or lean just by listening. The only thing you have to check is if your saw has a rev limiter, some new ones do, if yours does then you shouldn't use this method. http://www.madsens1.com/sawtune.htm
Tim,
Thanks for you suggestion about the brake band being properly installed, I'll watch for it.
I seem to recall that the break in the Brake was in both bands and that it was not worn through to thin metal. Are you saying that its not easy to get the new brake band mounted correctly OR are you saying that its hard to get the brake band properly slipped over the clutch. I had always assummed that if the chain/clutch cover goes on properly then the band is in place. In any case, the first band was put on at the factory and the second one was put on by the dealer.
Yes :-[ I did the worst case senario :-[
The dealer gave me the final blow today - absolutely no warranty and he wanted $385 to repair the saw. It was only $600 new!
I said "no way" and took it home in pieces. A good book, some jobber parts, a cold winter night and I bet I can get it working.
I saw a chainsaw repair manual featuring Stihl, how much of that info could be applied to Huskies? Or would you recommend a different book?
I haven't said it before but I really appreciate your interest and advice, Thanks to all
That's what I was saying.
Mine sure looked like it was on, so I had no reason to check it.
The clutch cut through one of the two bands and would have cut the second.
I now take a light and flat screwdriver and double check. Kinda a pain though.
What I can gather from this thread is that Huskies aren't what they used to be and Husky dealers are pretty much a bunch of shysters. If you have to baby these saws get something that can handle real use. My old Stihl will run great on year old mix and has never had a serious problem in thousands of hours of hard use..including "chipped" parts and switches breaking. *DanG..doesn't any company make a decent product and then back it up anymore?
I suspect the biggest change (and I have similar experience with my 'old' '75 Stihl) is the influence of the 'greenies' and the EPA regs that make it tough to engineer the new saws. I don't expect my new MS361 to have near the stamina and performance that my old Stihl had (and still has). For many, they won't know the great performances of the old Huskies and Stihls, and probably what they don't know, won't bother them. Just a thought of what is happening. I think each of the companies are trying to make the best saw on the market, or at least just a bit better than the competition.
Interesting perspective given that Sprucegum admitted that he ran outboard oil, which is formulated for much lower temperatures, and old gas through his saw. I feel very badly for Sprucegum because he obviously didn`t realize the risk in what he was doing, but why should Husky or a dealer hold the bag on this breakdown?
If you have to baby these saws get something that can handle real use. My old Stihl will run great on year old mix....
Bet it doesn`t on modern gas left to get stale!
Now your just talking incredibly,
.......and has never had a serious problem in thousands of hours of hard use..including "chipped" parts and switches breaking.
I doubt that any manufacturer has had more broken switches than Stihl with their Master Control Lever.
Both Husky and Stihl still do, they just don`t want to pay for user abuse and mistakes. Why should they?
Russ
Solo has the best warranty in the business, and they are easy to deal with if you don't mind doing business over the phone and through the mail. (Assuming you aren't near a Solo dealer).
Solo is virtually unknown here because dealers are almost non-existent. Which is why our pros will never use them. Service is king.
Warranty is meant to cover defects in workmanship and materials. It is not intended to make up for operator error or abuse. Maybe a larger dealer with better trained mechanics and a more customer oriented attitude could have covered it but who knows. FWIW, Husky does not insist their oil be used during the warranty period, unlike Stihl. They do, however, recommend it as they know it works and there are a lot of incompatible oils available.
To clear up any misunderstanding, at least in the U.S., a manufacturer cannot insist on a specific brand of oil as a condition of warranty if there are suitable substitutes available in the market. If a manufacturer makes an oil brand mandatory in order to obtain warranty coverage, the manufacturer must supply the lubricant free of charge to the customer for as long as the warranty period is in force.
My cloud has a silver lining:
When I couldn't get what I wanted from my dealer I took my saw home in parts. I found a guy who said he could clean the cylinder good-as-new and went shopping for a new piston, which I found at a new dealer across town.
This dealer wasn't new, he'd been around a long time and cared about his product - cared enough to stand me in the corner and yell at me til I understood the importance of using the right oil in fresh premium gas. ;D ;D
He didn't just look at the gas he sniffed it and told me how old it was. Tricks like that impress the heck out of me.
Long story short: my 359 is running again for $191.56
Just to be sure I also bought a saw at Sears for $192.36 ;) ;) :)
I don't think that makes any sense and it's probably offensive to some of our Husqvarna dealers here.
I think 50 to 1 for milling isn't enough. I melted a 3120 in a 30 in oak ,paid for the repair (cause I bought it used) got it back and smoked it in the same log a week later. The dealer ended up covering it on his repair waranty it but tried to blame me at first for dirty gas said there was sawdust in it and the gas filter clogged therefore leaning it out. Well' I know my gas was new, my filter was new and I watched the tech drain the gas ,the sawdust came off the saw itself. I told him I dust the fill caps every time i open them with a paint brush . I dont use my chain mill much since I got a band but if I do its 40 to 1. The dealer said milling may void the waranty but the wording is not there to say that.
D.Martin, here are two excerpts from the standard Husky warranty stating that Husky may not cover the costs associated with a failure.
The first, from the warranty section "OWNER`S WARRANTY RESPONSIBILITES"
"As the small nonroad engine owner, you should however, be aware that Husqvarna Forest & Garden may deny you warranty coverage if your small nonroad engine or a part of it has failed due to abuse, neglect, improper maintenance, unapproved modifications or the use of parts not made by the original equipment manufacturer."
And the second, entitled "WHAT IS NOT COVERED".
"All failures caused by abuse, neglect, or improper maintenance are not covered."
subsection "ADD-ON or MODIFIED PARTS"
"The use of add-on or modified parts can be grounds for disallowing a warranty claim. Husqvarna Forest & Garden is not liable to cover failures of warranted parts caused by the use of add-on or modified parts."
Since Husqvarna doesn`t market a chainsaw mill, a chainsaw mill is an add-on part which exempts them from warranty coverage. Even Jonsered who markets a chainsaw mill would find exemption unless you were using their mill. Chainsaw milling could also be considered deliberate abuse because chainsaws aren`t made for milling, they are made for crosscutting.
Stihl`s warranty has similar disclaimers within. I`d suggest that anyone planning any chainsaw milling with a saw under warranty should cultivate a good relationship with their dealer.
Russ
Stihldoc, that is interesting. Here, the Stihl warranty policy states that if their oil is used in certain products for consumer use, they will offer a two year warranty. Otherwise, it is one year. They say nothing about supplying free oil. Do they offer different warranties outside the USA? I know it is a scam to market their oil and have taken some flack from customers over it but Stihl Canada is very strict about warranty claims. They also refuse claims if the product was not registered.at the time of sale which is questionable.
I am not familiar with the warranty laws in Canada. The "extended" warranty if you purchase STIHL oil would not be a violation of warranty laws in the U.S. since there is warranty coverage without purchasing a specific oil, you just don't get the extended coverage.
Hi all, new guy here. I've been reading and learning a lot for a year here so finally got registered. I find these warranty issues especially interesting since I live in a small 1 dealer (Stihl) town and may make future purchases online. The dealer used to have Husky and I think Redmax but didn't sell enough of them to keep them around he said. I think it's just like a car dealership, if you've spent a lot of money there or the dealer just happens to like you, they can do more for you than they would otherwise. This dealer has a sign that says "we service what we sell FIRST, others when we get around to it" I'm not knocking the concept but it is now a Stihl or nothing to get top service.
It doesn't look like Husqvarna is opposed to milling in general or should use that as a reason to deny a warranty claim. If they do it would look like a double standard since you can get a 3 year warranty on a 385 if purchased with the Logosol mill. At $999 it's more than some places but I think that includes bar, chains, sharpener and some other add-ons for the mill.
small links are best (http://www.logosol.com/webb/customerservice/1100a-webshop.php?go=webshop/sawmillpowerheads.htm&menue=powerheads)
Hi woodmakr,
Welcome to the forum.
In your quoted statement, who exactly offers the extended warranty? It`s not Husky, it`s Logosol, so I`d say that your conclusion that "it doesn't look like Husqvarna isn`t opposed to milling in general" isn`t well founded.
As I said before, cultivate a good realtionship with your local dealer and in all likelyhood he will side with you on warranty issues where he has any latitude.
Russ
