Where can I find the serial number on a Timberjack skidder?
Started by Oliver05262, May 20, 2014, 01:33:59 PM
Oliver05262
  Trying to find the serial number on a Timberjack 240A skidder. Cable machine; Deutz engine. The usual tag in the step area is missing; just four nibs are left where it was riveted or spot welded. Is there any place else on the frame or whatever where the number might be stamped into the machine?
  Really sure the machine is not stolen. It was bought used from -- or through -- a dealer several years ago, and no issues were brought up. Any help on this would be appreciated. Cell phone number is 802-five five eight-8161 if you'd rather call.
  Thanks.
Oliver Durand
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
Neilo
No, I don't think so. You may be able to date it off id plates on parts.
timberjack26
up in the cab...on front....or down below your feet.....or send me a pic of it, i will come close....5187757619my number...
roadrunner36
On my timjack which is a 77, the serial number is stamped into the metal right about where your right calf is sitting in the seat.  if they machine has been repainted you may need to scrape the paint off to see it
tj240
you may be able to get the info if only very little from the motor serial #
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
