Building a Rite Leg Walnut Slab bench
Started by WDH, January 06, 2015, 09:14:05 PM
I am building a walnut slab bench using the Rite Leg Company's Alissa style bench legs.  This walnut slab is 5' long and from 14" to 16" wide.  Here is a pic of the raw slab.  It has a nice feather crotch on one end.  I de-barked the slab with a draw knife and a chisel being careful to leave the natural live edge.
Here is the slab after some initial shaping using a jig saw set on a 30 degree angle to mimic the angle of the natural live edge.
I was careful to leave all the knobs and protrusions on the live edge as well as the natural texture.  I also left some of the tight inner bark for contrast.
The legs have to be leveled so that the bench will sit solidly on the floor without rocking.  To do this, you turn the slab upside down, and place the legs on the slab upside down.  Then you take two stickers and place them across the feet of each leg.  These are called winding sticks.  You sight down the sticks to see if they are exactly parallel (they never are  :)).  If not, then raise the side of the leg that is lowest so that the winding sticks are perfectly parallel.  Then measure the distance that you had to raise the leg and cut a shim to raise that side of the leg.  Now the bench will sit solidly on the floor without rocking.  Here is a pic of the winding sticks on a pecan  smiley_devil bench that I made a few days ago.
Here is a pic of the legs attached to the bench with 1/4" lag screws.  Note the leveling shim in the foreground.
Here is the bench with just the two legs and no middle stretcher.  You can have just the two legs, or you can add a stretcher.
I like the middle stretcher, so here is a pic with it added.
Hind sight is 20:20.  The stretcher would look better if it had the same curve as the slab top.  Oh well, I can always replace it with a curved one  :-\.
I put the first coat of 100% pure tung oil mixed 50:50 with mineral spirits on the top this evening.  The change is dramatic.  The oil really brings out the beauty in the walnut, especially the feather crotch.  I will take a pic of the bench when the oil finish is complete.
These legs are a pleasure to work with.  They look great, too.
DanG it!! That does it!!
I'm gettin some legs... after 50 years of hanging on to this walnut slab trying to figure out how to put legs on it, and where to put it... it's getting legs. Fresh coat of Watco oil too.
Thanks Danny         Looking at the Logrite Legs, and not finding this style in the 13-14" for coffee table height. So dilemma time.
fishpharmer
Impressive slabs, enhanced by impressive craftsmanship.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Tam-i-am
Wow Danny that is a beautiful piece!  And thanks for the step by step instructions.
Beenthere - we can build them to be 14" I just need to know what color or finish you want.  Powdercoat black gloss or wrinkle or one of the platings.
Get Stuff Moving Today!  www.bluecreeper.com  www.facebook.com/Bluecreeper
Tamiam
8)  Then I am back in. That is great.
I'd like the same black finish as WDH, if I may. 14" Allisa style will do great.
PM details of how to make up the order.
thank you
Tam-i-am
Beenthere
your legs are built just have to go to powder coat.
Tammy
Looks good Danny.  How thick was that Walnut slab?
2 & 3/8" rough.  Planed out at a full 2".
scsmith42
Looking good Danny.  My legs shipped out today and I'm looking forward to putting something together with them.
I might be calling you for some design advice!
Tom's 3638D Baker band mill
Bench is finished.  It has three coats of tung oil.  Sits very nice.
Looks very nice too. That blue is different.
tule peak timber
Some mighty nice looking business on this thread  8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
Is that really blue, or just reflected light in the photograph on the dark wood that makes it look blue?
Just reflected light.  The blue would have been a nice touch, though.
This one is a little closer to the true color, but still a little reflected light blue.
WmFritz
Quote from: thecfarm on January 20, 2015, 08:17:33 PM
I thought you were going for a Log-Rite blue finish also.
Very nice work there.
~Bill
2012 Homebuilt Bandmill
Tam-i-am
