Toe board for my HFE-21
Started by 21incher, August 07, 2015, 05:04:37 PM
21incher
Just finished up adding a toe board to my little mill and I know how everyone likes pictures
First I fabricated some parts to add to my log support brackets.
Next I picked up a 2 ton jack for lifting.
Then machined some UHMW guides.
Plasma cut and welded on a handle extension for the jack release.
Made a handle for the jack to extend out from under the frame.
Plasma cut the toe board and welded it to the jack screw. Here is a video of cutting the part on my plasma table if anyone is interested https://www.youtube.com/watch?v=8GiMvHj-bX8
Started assembling. Mounted the pads to slide the assembly on the frame.
Added the top guide for the jack ram.
Added the pivit for the new handle.
Mounted the jack to the frame.
Added the toe board, return springs and anti rotation guides.
Added the handle and new linkage.
The finished toe board assembly with the adjustable log supports.
21incher
Here it is sitting in the frame.
Dropped in the frame toe board down.
Toe board up.
View from underneath.
It can be placed anywhere in the frame for different log lengths.
Bruno of NH
You do great fab work !
Did you own a fab shop at one time ?
Wish I could learn some metal fab so I could do work like you .
Jim/Bruno
fishfighter
Nice clean build. Myself, I'm still using a wood block and jack. ;D
21incher
Quote from: Bruno of NH on August 07, 2015, 05:33:24 PM
Jim/Bruno
Thanks Jim. I bought a old milling machine and welder about 10 years ago that got me started. It is just like wood working with different tools. Start with small projects and each one gets easier. :)
You have a way of making even the simplest of task look professional.   smiley_thumbsup smiley_thumbsup
Lazy logger
Nice work, and great addition. Beats the heck out of my scissor jack.
I know the voices in my head aren't real,but sometimes their ideas are just absolutely awesome!
Now that is the cat's meow! (old saying).
Ga Mtn Man
Very nice work!  What's the purpose of the saw-toothed edge?
deadfall
Real pretty work.  Don't you get it dirty or scratched up.
Oh yeah, nice engineering.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
21incher
Thanks everyone.
Quote from: Ga Mtn Man on August 07, 2015, 08:43:26 PM
When you place a log over 18" diameter on my little mill it is to big for the dogs so I rely on gravity to keep it from moving when taking the first slab off. The 2 threaded shafts on each end stabilize the log but sometimes the log slides around when trying to position it for the first cut. I am hoping the little teeth will grab the bark and  keep it from moving to make the setup a little easier. I won't know if it works untill I try it. :)
justallan1
Great build. I recognized the reasoning on the 2 bolts right away and think they're great. I've used wedges only at times and know for darned sure that your idea will be bunches more solid and lots easier on funny shaped logs. Great job.
21incher
Quote from: justallan1 on August 08, 2015, 08:43:38 AM
Thanks. I tried the wedges also and the logs still rocked which could stop the blade from moving. The angle brackets that came with the mill are a pain to use also. I think the main problem is that there are very few round or straight logs that I mill and many are to big for the mill so it is time consuming to position them.l can see why you went with a bigger mill. :)
Bill Gaiche
Kbeitz
I went the other way and pit a roller on my toe board.
Love machine shop work
and Wood work shop work
And now a saw mill work
fishfighter
Quote from: Kbeitz on August 09, 2015, 02:42:56 PM
I like that idea. Like the KISS. ;D Once I get phase two built on the camp, I will start building my trailer for my mill. Looking t add things when I do.
21incher
I wanted to be able to easily move the toe board to anywhere on the trailer for different types of logs so I kept it as light as possible and moveable. I may make a couple of rollers to snap on it to help rolling the log. :)
