New Member Intro
Started by FloridaMike, January 14, 2017, 06:37:32 PM
FloridaMike
Hello from West Central Florida,
I started my saw-milling experience in 1980 right out of High School.  I went to work at a lumber yard, that soon decided to get into the sawmill business.  Which led to the purchase of a very tired Frick 00 52" circle mill. I ended up rebuilding the track frame and head saw frame (Pine 4" x 10"s & 4" x 12"s), forming and pouring the concrete bases and setting the whole thing up, with a 100 hp JD diesel (4" flat belt drive).
After doing some OJT at some local mills, I was sawyering at the ripe old age of 20.  Sawed a few 100K BF of mostly cypress and SYP, with a little red ceder, oak and hickory mixed in.  Ran the mill until they sold out a 3 years later.  The land had become worth a lot more than the sawmill.  Left with all 10 fingers!
Fast forward 33 years later, I recently retired from the Fire Department after 32 years (paid) plus 4 as a volunteer while I was sawing.  I feel the call of sawdust, so I'm building a bandsaw mill.
I will do a build thread (with pics), but the stats are going to be: 21 hp Honda powered, all steel, 1.5" blade, 24" tire mill with a 42" throat span, 16 hp hydraulic feed, chain turner and dogs with 12v head height adjustment and 28' of track.  I just finished the cutting head sliding frame, getting ready to start the track frame and rolling head frame.
Mike Nickerson
Floral City Florida
Mike
paul case
Welcome to the forum, Mike
I hope to see pictures of your progress.
PC
pc
Peter Drouin
Chuck White
Welcome to the Forestry Forum, Mike!
breederman
Welcome mike . My father and brother live in Floral  City !
Together we got this !
Sixacresand
Welcome to the Forum.  I look forward to the photos of the mill build.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
I have a 20hp honda on my mill. 28 feet of track? Are you moving the head or the log?
Welcome to the forum.
Bruno of NH
Welcome will be nice to follow the build
york
Welcome-sounds like you have plans for a good mill,but why use tires??
Albert
slider
Welcome Mike looking forward to your build.al
al glenn
FloridaMike
Thanks for the warm welcome!  Re: Questions - saw head will be moving and tires was just a personal choice.
Mike
Mike
Ox
Welcome to the FF and I look forward to your future posts as do many others!
Ljohnsaw
Welcome!
popcorn_smiley smiley_thumbsup
Will this be your sawmill build thread or will you start another one?  Inquiring minds want to know (old saying?)
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
TKehl
Welcome.
Where are the pictures?   :)
bucknwfl
If it was easy everybody would be doing it
dgdrls
Welcome FlaMike.
great folks and lots of help to be had,
D
FloridaMike
Quote from: ljohnsaw on January 15, 2017, 12:14:04 PM
No Sir, I will start a new thread.
Mike
redprospector
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
Raider Bill
Welcome to the FF. I ride up your way every so often. Used to stop in Sleepy Hollow for the $6.95 steak dinner on the weekends.
The First 72 years of childhood is always the hardest.
FloridaMike
Quote from: Raider Bill on January 16, 2017, 09:02:25 AM
They reopened, with new owners and higher prices.
Mike
Raider Bill
Quote from: FloridaMike on January 16, 2017, 09:54:17 AM
And a loose gravel parking lot too I heard.
bkaimwood
Welcome, Mike! 42" throat? Do you mean 42" between the guides, capable of cutting 42" wide boards?
bk
FloridaMike
Quote from: bkaimwood on January 16, 2017, 06:21:50 PM
No, I thought about that after posting.  It's 42" between the uprights, which will make it approximately 36" between the guides.
Mike
bkaimwood
Thanks for clarifying...still going to be a feat though, on rubber tires. Widest I ever made on rubber tires was 32-33"...
bk
FloridaMike
Quote from: bkaimwood on January 16, 2017, 09:00:00 PM
Agreed... I designed with the mind of upgrading wheels and engine hp later, without having to do major frame modifications.  I will be happy with a practical maximum 32" cut width (with tires and 20.8 hp).
More to follow with the build thread & pics.  I will work on that tomorrow.
Thanks again for the warm welcome and info!
Mike
