Solar Kiln build
Started by Kbeitz, June 11, 2017, 05:40:30 PM
YellowHammer
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
LeeB
Quote from: YellowHammer on July 18, 2017, 09:16:59 PM
That looks sharp!
Of course it does. It's pointed at the top.  :D
scsmith42
That came out really nice.  I too like the latch.
Tom's 3638D Baker band mill
Kbeitz
I'm now doing the wiring. The tar mix is all but dry. Only a few spots that
is still sticky to the touch. I had 188F with it all closed up yesterday.
I got fans coming from E-bay... My store for almost everything.
Today I bought 130 lbs of #14, 12 and 10-2/G wire for the kiln and my shop
from the kunkyard. It all looks in great shape. I got if for $1.00 per lb.
Love machine shop work
and Wood work shop work
And now a saw mill work
btulloh
K, you and I should have built our kilns during the cooler season.  :)
HM126
GeneWengert-WoodDoc
I am still concerned about the lack of vents on the rear wall.
Kbeitz
Quote from: GeneWengert-WoodDoc on July 22, 2017, 11:13:00 PM
My rear wall has a vent at the top.
My plane is 4 fans. Top vent fans in.
The two side vents fan out.
One large inside fan to keep everything moving.
Kbeitz
Today in this hot weather I dug a 25 foot 2 feet deep ditch to my kiln
for the electric... Fun fun... But hey... I got it finished...
GeneWengert-WoodDoc
So, the air comes in, goes through the collector along with other air in the kiln and then the air goes out the side vents before it goes through the lumber pile?  This is my concern.
Kbeitz
I'm sure I will loose some air but .... What would you do ?
50 Acre Jim
Quote from: Kbeitz on July 23, 2017, 06:05:31 PM
That just doesn't seem like all that big a deal....     from inside my air conditioned trac hoe...  :-)
Go to work?  Probably Knott.  Because I cant.
Kbeitz
Quote from: 50 Acre Jim on July 24, 2017, 07:15:41 AM
My problem was that the ditch was 99% rock. So I could not just scoop it back in.
I had to shovel dirt on top of the conduit until covered and hand pick the bigger
rocks and lay them so it would not damage the conduit. Then I could finish up with
the tractor. Hot hot hot.
Ljohnsaw
Quote from: Kbeitz on July 24, 2017, 08:05:03 AM
I can relate...
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
50 Acre Jim
You guys got nothin...  :-)  The ground here was so rocky I had to haul sand in from the other side of the property.  Uphill.  Both directions.
Kbeitz
We have the rocks...
btulloh
Roofing material, just layin' around in the ground.  Free for the taking.
HM126
I don't really see any rocks.
ljohnsaw had A rock. Now my place would have about 6-7 that size and about 40 more smaller ones than that.
Kbeitz,looks like your will at least break up for ya.  ;D Not many flat ones around here
50 Arce Jim,now that looks like what I have.
The only trench I dug was for the outdoor furnace lines. I hauled off what I dug out and put in sand.
I was dumb enough to have a trench dug down to the garden for a water line.  ::)  Why I did not just bury it a few inches deep,hindsight in 20/20. It's all down hill,I just drain it each year.I am surprised the line is still good. I just backfilled with what was dug out.
Ljohnsaw
Quote from: thecfarm on July 24, 2017, 09:25:02 PM
Well, there is a bigger rock at the bottom of the picture that I couldn't move at all.  What you don't see is further up the hill on both sides of the "road" are rocks that size that the backhoe guy managed to pull out of the trench.  Ok, here are some "rocks" I had to deal with when making my footings:
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
GeneWengert-WoodDoc
Can you run a duct from the side vent to the rear of the lumber stack so you get the air after it has gone through the pile?
Kbeitz
Sleepless night... So I worked up my fan control.
Rocks and a solar Kiln.  :D
When he dug for my foundation alot got buried on the sunroom side. Than I had to call in the dynamite guys in to do some blasting for me. He was doing good until he got to the bedroom.  ::)
Kbeitz
I got the underground electrical run and got the fans in.
btulloh
Ready for liftoff?
10
9
8
HM126
Kbeitz
I got my controller built today. If the rain holds off I will have my first load of wood in tomorrow.
btulloh
That's quite the controller Kb.
What are you going to run for your first load?  Green or air dried?
HM126
