My arm is outta whack!
Started by Deese, August 21, 2017, 08:25:39 PM
Deese
Adjustable blade guide arm, that is. I was playing around with the board return for the first time the other day and didn't raise the blade before returning. Slammed the blade into the log pretty hard and it jacked up the adjustable arm. Lots of play in all directions. I got WM to email me the manual and I believe I know what to do. The outer, lower bearing was loose, so I raised it by loosening the jam nut and turning the cam bolt. Tightened that bearing, so now there is no up/down movement. But, the flange is literally touching the back of the blade. The manual says to adjust the two inner upper and lower roller bearings outward to move the arm away from the blade (common sense). I've got some 15/16" sockets but they won't fit because the bolt heads somewhat "inset". Do I need to get a thin-walled 15/16" socket?
Then I've got to check and adjust the blade deflection and adjust it by moving the outer rollers up/down, right?
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
4x4American
Let the fun begin!!  iirc I used a wrench to get it just the tip to break it loose it's an awful time.  You might as well take the guides right off, keep the blade on at full tension, bring the arm in and out and measure the guard to the blade on the back and on the top to make sure it goes in and out evenly.  Except when you have it in all the way you want to make it so that it pushes down approx 1/32" vs when it's all the way out.  Also get your head tilt idk I run mine flat but some say 1/16" up on the outside so that when the blade is spinning it brings it level.  Make sure that some buckin arm is real tight and then slap your guides back on and make em push down on the blade 1/4" and then set them flat and I run the distance about 1/16" from the back of the roller flange to the back of the blade and with a slight sideways tilt so that when the blade is pushed up against it the flange pulls the blade up into the flange.  A wm tech set mine backwards so it pushed the blade away and that didnt work out too well for me.  And if those guides are wore out or real old I reckon now is as good a time as any to replace them.  Have fun!
Boy, back in my day..
drobertson
not sure the damage, you did not mention that today,, sorry to hear its this bad,,
4x4American
One thing I always do before I drag back is in that little nick of time just before or as the blade exits the cut, I bump the guide arm out a piece just before bumping the head up before the drag back drops so that the guide arm isnt right up in it when you are draggin back.  Sometimes boards or slabs can get cattywampus on that return shot and hit the ever so sacred movable guide arm.
YellowHammer
I use a 15/16" wrench.  The blade guide arm is the most delicate and unfortunately, usually the most aggravating thing on the mill to adjust.
Are you sure you didn't bend the cam bolts?  I did, and caused twisting of the arm, and also uneven, unpredictable adjustments.
Also, get a beer and enter a quiet Zen state for these adjustments.  They can be very frustrating.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Percy
What yellow said and 4X4 as well. I did the same on my 97 lt40 and couldnt get it right till I replaced them bolts. The LT70 has a much more user friendly adjustment system that Woodmizer should put on the 40's IMO. Regardless, persistance will get that puppy aligned again...and some cussing.... :D
Oh no!  You must not have been wearing MY lucky shirt  :D.  I wrecked mine really good  :-\.
One learns what one must not do.
Deese
Thanks everyone. I bought a socket that should fit, and a 1 1/8" wrench this evening. I will tackle this tomorrow. I'm afraid I bent the bolts a tad. Not sure. The fun begins tomorrow.
Cooks AE4P Edger
Deese
Danny, I should have been wearing the shirt. Guilty as charged.
Cooks AE4P Edger
4x4American
Danny did you bend you blade tensioner there too or is that just an optical conclusion?
If the threaded portion of any eccentric bolt is bent I would replace it.
Bob_T
Quote from: 4x4American on August 22, 2017, 10:07:29 PM
Pretty sure he's taken the bolts out of it and it's hanging on angle.
1959 FWD Model 286 Dump Truck
1955 Allis Chalmers HD-6G Crawler Loader
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
Bob_T
When I got my "low hours, well maintained" LT30 one of the first things I noticed was that the blade guide arm was real loose and flopping around.  Tuned out the previous owner had some sort of a wreck between the arm and a log.
The arm went "thump" when moving it in and out, turned out one  of the rollers that the arm rides on had a good sized dent in the flange.  The arm itself had some dings in it that I fixed with a file.  One of the cam bolts was bent, actually the heavy sheet  metal structure it bolts to was bent, making it seem like the bolt itself was bent.  Per a thread somewhere by Marty Parsons I straightened it out with a cheater bar over the bolt end.
I kept getting confused trying to figure out which way to turn the adjusting cam bolts.  A center punch would've worked just as well, I took a Dremel engraver and marked the high point of the cams on the bolt heads, that made it a lot easier to know which way to turn the bolt.
Last and least, the inboard  fixed guide roller mount was also bent.  Not so bad that I couldn't still adjust it so I left the repair for another day.
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
4x4American
I've broken that inside guide roller mount right off before lol from dragging a board back that slide over and whacked it
Quote from: Bob_T on August 22, 2017, 10:45:45 PM
Yes, that is exactly right.
MartyParsons
Hello,
  I posted some alignment tips last year. Check out here https://forestryforum.com/board/index.php/topic,86877.0.html.
Hope this helps.
Marty
gmmills
      That arm sure can be a pain. These make the job quite a bit easier.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Chuck White
I've been going to get those wrenches, just in case, post the sizes please!
YellowHammer
15/16" is what my mill uses.  The bolt heads are under the bandwheel covers, and difficult to get to.  I also do as someone else suggested, mark the point of max eccentricity on the bolts with a Sharpie so I know where it is high and low when I'm turning them.
There is definately a feel to it, I watched a WM service tech adjust them in about a minute.  Not me, I've taken much longer to get them right.  One of the tricks is to get the locknuts on pretty tight to take all the slack out of the eccentrics, then start gradually tuning them, that way the bolts don't shift when the locknuts are tightened.
YellowHammerisms:
gmmills
    Top wrench is 1 1/8" Bottom is 15/16"
Sawing since 1995
terrifictimbersllc
Quote from: YellowHammer on August 22, 2017, 12:01:22 AM
Somebody said earlier go to the bathroom first if you have to.
drobertson
As with any adjustment on these mills,, all it takes is patience, small adjustments, and at all cost avoid getting rammy,
All the adjustments are easy enough,, you gotta like getting in the saw dust on a few, not the blade guide. Once done and crashes are hopefully over,, these adjustments hold for a long time,,
YellowHammer
Quote from: drobertson on August 25, 2017, 06:12:27 PM
No doubt, this is the best incentive and motivation to never crash or damage the blade guide arm again.
YellowHammerisms:
Most crashes happen when you are doing something different from your normal routine.  At the end of a sawing day, I went to the back and removed the blade.  I did not raise the head back up and for whatever reason the clamp was higher than the guide arm.  I found out that the guide arm will not stop the sawmill on it's return to the front of the sawmill.   ::)  I think that it broke everything that was not bent.   :-X
4x4American
Quote from: YellowHammer on August 25, 2017, 10:06:57 PM
This is the reason why I don't let anyone run my mill, cause I ain't about to adjust that guide arm on someone elses account!
